84 cj 7.5 lcog - Page 11 - JeepForum.com
 1Likes
post #151 of 1130 Old 10-10-2013, 08:00 PM
holliewood61
1981 CJ7
Yeah $2500 seems like a bit much
You could buy the tube and figure out what ya wanna do then have a muffler shop bend it up
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #152 of 1130 Old 10-10-2013, 08:21 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
You could do just a custom back section. Nice work on the rebuild.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #153 of 1130 Old 10-10-2013, 08:34 PM Thread Starter
84jeepcj7rock
That was the original plan but it is covered in line x and I have already discovered how much I hate grinding and welding around that stuff. I could strip all of it off but in the end I would just end up with a pieced together cage. The middle is stock. The front is an OR Fab kit and the seats mount to a custom rack.
84jeepcj7rock is offline
post #154 of 1130 Old 10-14-2013, 03:20 PM Thread Starter
84jeepcj7rock
The original measurements before the latest build was 21.75" clearance under the belly pan and 29.75" under the rockers. Those measurements were taken with worn 37" MTRs, SOA front w stock height springs and a custom 3 link rear. I'm gonna take the new measurements tonight. I'm hoping for around 19" belly pan clearance. Also had a 1" BL originally.
post #155 of 1130 Old 10-15-2013, 03:31 PM Thread Starter
84jeepcj7rock
Wow. Belly pan clearance is now 16.5". No wonder it handles so well on the road. It's as low as a go cart. I'm only running 4" of up travel w 14" travel shocks so ill bump them up a little
post #156 of 1130 Old 10-17-2013, 10:31 AM Thread Starter
84jeepcj7rock
Anyone going to Adventure Offroad Park this weekend near Chatt, TN? Should be a fun event.
post #157 of 1130 Old 10-18-2013, 07:16 AM Thread Starter
84jeepcj7rock
Picked up this serpentine belt conversion kit from Bull Tear for my AMC 360. Looks sweet in billet.
post #158 of 1130 Old 10-18-2013, 07:39 AM
holliewood61
1981 CJ7
Nice. Hope that didn't come out of the cage fund.
08 WK bone stock
00 WJ daily driver
60 CJ5 tore down
post #159 of 1130 Old 10-18-2013, 09:38 AM Thread Starter
84jeepcj7rock
Just don't tell my wife and everything will be ok
post #160 of 1130 Old 10-18-2013, 09:48 AM Thread Starter
84jeepcj7rock
GenRight sent the wrong corners. They will ship the correct ones out no problem. I was supposed to receive the LJ blanks. I put these up to see how things would line up. The LJ rocker is much longer which leaves a gap in front of my rear wheel well. Also, a LJ is 15" longer than a CJ, YJ or TJ. I only stretched my body by 12", so I will have to trim 3" out of the door opening and re drill the flared holes for the counter sunk hardware.
post #161 of 1130 Old 10-18-2013, 09:57 AM
holliewood61
1981 CJ7
Mine is always home when brown santa drops off the box. No hiding it from her, but then again she couldn't care less.
08 WK bone stock
00 WJ daily driver
60 CJ5 tore down
post #162 of 1130 Old 10-18-2013, 10:19 AM
twinstickd20
1979 CJ7
A little radius trimming and add some to the rocker and that will look good.
My Build Thread
twinstickd20 is offline
post #163 of 1130 Old 10-18-2013, 11:05 AM Thread Starter
84jeepcj7rock
When I get the blanks, I'll cut out the wheel opening and use that material to fill in the rocker
post #164 of 1130 Old 10-18-2013, 11:16 AM Thread Starter
84jeepcj7rock
Another pic with the steel flares
post #165 of 1130 Old 10-18-2013, 11:17 AM Thread Starter
84jeepcj7rock
I can't wait to have flares again
