82 cj7 "eugene" - Page 2 - JeepForum.com
post #16 of 23 Old 04-30-2011, 05:21 PM
djflyy
Looks really good so far man!
djflyy is offline
post #17 of 23 Old 05-08-2011, 03:59 PM Thread Starter
nshefbuch
1982 CJ7
was able to get out and test the suspension out this past saturday. every year there is a jeep relay for life event to raise money for cancer so its a great time to test things out and for a good cause. the suspension did very well and when coming off a large object it lands soft like a coil spring jeep. i was surprised on how well it did.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #18 of 23 Old 05-13-2011, 08:20 PM Thread Starter
nshefbuch
1982 CJ7
well i finished my axle swap besides anti wrap bar and am now clocking the tcase up flat and building new skid plate.
post #19 of 23 Old 05-15-2011, 04:13 PM Thread Starter
nshefbuch
1982 CJ7
here is the new crossmember/skid plate. just need some plating for the bottom. i welded coupler nuts so the skid plate can be removed to access the tcase oil pan.
gained about 6 inches in making my own skid plate
post #20 of 23 Old 05-27-2011, 07:58 PM Thread Starter
nshefbuch
1982 CJ7
well i got new tires mounted and put on rocker guards too. next is some fender trimming and using TJ flares.
had to cut the run flats off so i can keep the dual beadlocks.
post #21 of 23 Old 09-17-2011, 01:07 PM Thread Starter
nshefbuch
1982 CJ7
Here is what it looks like as of now. I'm working on hydraulic clutch kit now and just bought a ram assist steering kit complete for $150.
post #22 of 23 Old 09-22-2011, 06:23 PM Thread Starter
nshefbuch
1982 CJ7
installed a hydraulic clutch linkage kit from novak jeeps. pretty easy install. the hardest part is drilling a hole through the pedal. i wanted to do this with out removing the steering column and pedal assembly. so i purchased a right angle drill and had just enough room.
post #23 of 23 Old 02-04-2012, 04:30 AM Thread Starter
nshefbuch
1982 CJ7
Installed ARB air locker replacing the Lincoln locker I had and put on the free cover it came with.
amc360 , cj7 , full width , h1s , t18a
TJ's with Rubicon Flares, 4" lift, with 33" or 35" tires HANKiE Jeep Picture Requests 12 05-08-2012 09:23 AM
Some call it "Dolores", some "Misery" mikes_muse Jeep Builds 5 10-18-2009 12:36 PM
Longshot but does anyone have... (TJ w/ 3.5" lift, 1.75" coil spacers, and 36" Iroks) Daylan Jeep Picture Requests 0 08-27-2009 01:58 PM
2"-2.5" suspension lift+ 1"bl with 31" tires bmboll Jeep Picture Requests 5 03-29-2006 12:28 PM
My new "Sahara Edition" Liberty...package "S"... Liberty-4-All Jeep Builds 19 06-06-2002 10:41 AM
