82 cj7 "eugene" - JeepForum.com
post #1 of 23 Old 03-28-2010, 10:56 AM Thread Starter
nshefbuch
1982 CJ7
82 cj7 "eugene"
bought this jeep in may of 09 with a ton of rust and a knocking amc360 , rebuilt T18a , and d300. leaking radiator and power steering gear box. stock axles and generic 33"
i had motor rebuilt, replaced power steering gear box, got a yellow top optima, aluminum radiator, rugged ridge steering box frame reinforced mount, bought full width axles for it, h1's on 36" wranglers. headman headers, flowmaster 44's. twin sticks, put my own choke cable and made tranny cover.
front drivers side floor
twin sticks installed(JB CUSTUMS)
rear floor truck bed lined
driver side rocker panel
rear driver side corner
rear driver side frame broke
another weak spot on the frame i boxed in
i don't have the full width axles installed yet as i don't have the funding yet. right now i'm still finishing up the rear frame and crossmember. next i will repair the tailgate.
thanks for looking
nshefbuch is offline
post #2 of 23 Old 03-28-2010, 10:58 AM Thread Starter
nshefbuch
1982 CJ7
rebuilt amc 360 , 30 over and mild rv camshaft installed. got a universal jegs aluminum radiator for $200 including mounts. yellow top optima for $90
result of rebuilt motor, to strong for stock driveshafts
decided to upgrade axles to a d44 3/4 ton setup with high steer
rear axle is FF 14 bolt both with 4.10 gears. picked up a set of 36" wranglers on H1 rims on the cheap.
this last picture is the H1's mounted on the rear 14 bolt compaired to the width of my 62 cj5 with 2.5 backspacing 15x10 rims
this is the jeep as it sits now before i started repairing the frame. i switched the rims and tires around with my 62 cj5.
post #3 of 23 Old 03-28-2010, 11:03 AM
DIX03TJ
looking good so far
DIX03TJ is offline
post #4 of 23 Old 03-29-2010, 02:35 AM
WtrHamer97
WtrHamer97's Avatar
Looking really good. Nice job on all the rust repair. Looks a lot better!
It is what it is...
WtrHamer97 is offline
post #5 of 23 Old 09-22-2010, 06:37 PM Thread Starter
nshefbuch
1982 CJ7
this is a hard top with full doors that was given to me for free. the sunroof leaks really bad so i decided to patch it for winters.
post #6 of 23 Old 03-13-2011, 03:37 PM Thread Starter
nshefbuch
1982 CJ7
getting ready to start the full width axle swap. here is a couple pics i took with the rear 14 bolt mounted with h1 rims/tires compared to how the cj sits now. not much wider
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
post #7 of 23 Old 03-24-2011, 04:47 PM Thread Starter
nshefbuch
1982 CJ7
took the rear axle out
post #8 of 23 Old 03-25-2011, 08:57 PM
Sfisher
Sfisher's Avatar
1984 CJ8
Keeping an eye on your build. Are you going spring over (i assume) and what kind of springs are you going to end up using?
Nice to see a CJ build as opposed to the "hey I did a body lift to my TJ" builds that are basically a dime a dozen.
Sfisher is offline
post #9 of 23 Old 03-26-2011, 02:03 AM Thread Starter
nshefbuch
1982 CJ7
I am running yj stock leafs in soa setup. I thought about running an add a leaf but want to keep the cog low and I'll trim fenders to make the tires fit. I ordered a clocking ring for the d300
post #10 of 23 Old 03-27-2011, 06:10 AM Thread Starter
nshefbuch
1982 CJ7
Got these frame out riggers for the front axle. Had to modify one for the steering box where it mounts to the frame. In one pic you can see the large hole through the frame where the steering box gets clamped to the frame.
post #11 of 23 Old 04-02-2011, 07:04 PM Thread Starter
nshefbuch
1982 CJ7
Snapped a few once I got it sitting on all fours. Before I had a 4" lift and now it sits 2 3/4" higher
image-2338132942.jpg   image-2698944592.jpg   image-2685486673.jpg   image-1103667418.jpg
post #12 of 23 Old 04-12-2011, 08:03 PM Thread Starter
nshefbuch
1982 CJ7
re-worded the shock mounts. used f 350 shock towers and modified them for the front mounts.
rear
post #13 of 23 Old 04-12-2011, 09:48 PM
honda250ex
1987 YJ Wrangler
Looking good, good luck with the swap
It's better to live one day as a lion than a hundred years as a lamb.
http://www.jeepforum.com/forum/f12/honda250exs-buildup-860712/
honda250ex is offline
post #14 of 23 Old 04-17-2011, 02:49 PM Thread Starter
nshefbuch
1982 CJ7
finally able to pull it out of the garage and measure for shocks
post #15 of 23 Old 04-30-2011, 05:10 PM Thread Starter
nshefbuch
1982 CJ7
finally got it out and did the test drive. bolted up the new shocks. bilsteins 5125. no room for reservior so i got these instead. i love them. it took all my strenght and weight to compress them to bolt them in place. rides nice with the stock wrangler springs.
amc360 , cj7 , full width , h1s , t18a
TJ's with Rubicon Flares, 4" lift, with 33" or 35" tires HANKiE Jeep Picture Requests 12 05-08-2012 09:23 AM
Some call it "Dolores", some "Misery" mikes_muse Jeep Builds 5 10-18-2009 12:36 PM
Longshot but does anyone have... (TJ w/ 3.5" lift, 1.75" coil spacers, and 36" Iroks) Daylan Jeep Picture Requests 0 08-27-2009 01:58 PM
2"-2.5" suspension lift+ 1"bl with 31" tires bmboll Jeep Picture Requests 5 03-29-2006 12:28 PM
My new "Sahara Edition" Liberty...package "S"... Liberty-4-All Jeep Builds 19 06-06-2002 10:41 AM
