81 cj7 rebuild - Page 6 - JeepForum.com
post #76 of 197 Old 03-23-2013, 12:28 AM Thread Starter
nixer600
You can't tell but second picture is bare steel
nixer600 is offline
post #77 of 197 Old 03-23-2013, 07:49 AM
lovett86
those are cool
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #78 of 197 Old 03-23-2013, 03:48 PM Thread Starter
nixer600
Almost got the engine out today but the rain started so we aborted mission.
image-3026707035.jpg   image-1336893868.jpg   image-2734390019.jpg   image-321251252.jpg
nixer600 is offline
post #79 of 197 Old 03-24-2013, 01:28 PM Thread Starter
nixer600
Got it out today, just need to pull the motor mounts and paint the frame.
nixer600 is offline
post #80 of 197 Old 04-09-2013, 09:20 AM Thread Starter
nixer600
Haven't been feeling well lately, but I took this time to order some small items I needed to finish the frame off. We hope to get back to it soon. We want the hard stuff done before it gets hot outside.
nixer600 is offline
post #81 of 197 Old 04-10-2013, 03:10 PM
87yellowyj
Hope you feel better. Poison spyder makes some sweet stuff. Best of luck.
87yellowyj is offline
post #82 of 197 Old 04-10-2013, 04:52 PM Thread Starter
nixer600
Waiting on some small tools and metal to come In so I can make the final burn ins on the frame.
So I decided to turn my attention to the amc360 at first I was gonna reman the heads, all new gaskets, new cam kit, springs, lifters, double roller chain , new chain cover new Intake and carb.
But since money is tight and the engine runs good we will just drop it in as is.
Problem was a broke header bolt, broken off down in the head I first welded a small washer to it carfuly not weldin the bolt to the head, then i welded a nut to the washer and took my time easing it out. Took about 30 minutes not to bad and now I don't have to pull the head and pay a machine shop to do it.
It's funny how the easiest jobs can turn out very difficult, and the tough jobs can turn out very easy.
image-2312652230.jpg   image-1710086290.jpg   image-3987183279.jpg   image-1396572065.jpg
nixer600 is offline
post #83 of 197 Old 04-18-2013, 02:55 PM Thread Starter
nixer600
Amazon is slow on shipping this time.
nixer600 is offline
post #84 of 197 Old 05-04-2013, 10:19 AM Thread Starter
nixer600
And I'm stupid, non ferris metals is metal without iron.
Needless to say the bad saw cut 1/16 of am inch before the blade was spent.
I used the chop saw with metal cut of wheel to cut what I needed it was tedious and difficult to keep the angles straight and accurate.
I tacked up some supports to the frame and I'm getting close to final burn in.
nixer600 is offline
post #85 of 197 Old 05-04-2013, 10:21 AM Thread Starter
nixer600
Some parts showed up. These will be altered some before bolting on In Order to fit the wheel base better. I might also add flares.
I got a new grill in as well.
nixer600 is offline
post #86 of 197 Old 05-25-2013, 09:42 PM Thread Starter
nixer600
Late night start, but my brother Inlaw, Rod Whitaker came over to start the final welds, he finished up the front end and a few roll cage tie in points, Monday he will finish weld the rear spring stays.
Thanks Rod.
nixer600 is offline
post #87 of 197 Old 05-29-2013, 02:19 PM Thread Starter
nixer600
I finished up the structural welds on the rear. Time to strip and paint the frame. Then Fit the tub and bolt in the engine.
nixer600 is offline
post #88 of 197 Old 06-02-2013, 08:57 PM
lovett86
that's looking awesome, keep up the good work
its a rusty one
lovett86 is offline
post #89 of 197 Old 06-04-2013, 03:44 PM Thread Starter
nixer600
imageuploadedbyag-free1370382222.945689.jpgimageuploadedbyag-free1370382234.322985.jpgimageuploadedbyag-free1370382246.256466.jpg
Need a little more stripping. Easy but slow going.
Sent from AutoGuide.com Free App
nixer600 is offline
post #90 of 197 Old 06-04-2013, 06:42 PM Thread Starter
nixer600
imageuploadedbyag-free1370392606.692152.jpgimageuploadedbyag-free1370392745.285440.jpgimageuploadedbyag-free1370392834.519951.jpg
She felt like using the flap disc and wire wheel. I wanted to apply stripper one more time but she wanted to use the power tools.
nixer600 is offline
