81 cj7 rebuild - Page 5 - JeepForum.com
post #61 of 197 Old 03-17-2013, 06:39 PM Thread Starter
nixer600
Removed The rear amc 20, and had Christine dougherty do most the work today.
nixer600 is offline
post #62 of 197 Old 03-18-2013, 07:35 PM Thread Starter
nixer600
It was critical to keep the axle flat, so that the caster angle stayed true to 6 degrease. I was carful to check this as I mocked up the front axle
nixer600 is offline
post #63 of 197 Old 03-18-2013, 07:38 PM Thread Starter
nixer600
After the first mock up I noticed the jeep did not have enough up travel in its suspension to give a comfortable ride. I moved both the front, (pictured here) and rear spring hangers down, again making sure the axle stayed level.
nixer600 is offline
post #64 of 197 Old 03-18-2013, 07:40 PM Thread Starter
nixer600
Once the front was done it was time to move on to the rear.
nixer600 is offline
post #65 of 197 Old 03-18-2013, 07:41 PM Thread Starter
nixer600
Removing the rear.
nixer600 is offline
post #66 of 197 Old 03-18-2013, 07:43 PM Thread Starter
nixer600
Set the rear pinion angle for the new cv shaft
nixer600 is offline
post #67 of 197 Old 03-18-2013, 07:45 PM Thread Starter
nixer600
81 cj7 rebuild
Notice the front approach angle after the 3 Inch stretched front wheel base and 41.5 inch tires
nixer600 is offline
post #68 of 197 Old 03-18-2013, 07:47 PM Thread Starter
nixer600
I stretched the rear about 7 inches, this also improved departure angle,
nixer600 is offline
post #69 of 197 Old 03-18-2013, 07:49 PM Thread Starter
nixer600
Factory wheelbase was 93.5 it's now 104
nixer600 is offline
post #70 of 197 Old 03-18-2013, 07:50 PM
Crazyantix_TJ
Nice build
Crazyantix_TJ is offline
post #71 of 197 Old 03-18-2013, 07:53 PM
lovett86
awesome progress
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #72 of 197 Old 03-18-2013, 07:53 PM Thread Starter
nixer600
Thanks I don't get many comments in here, and I was thinking about not posting any more, but hey maybe some one will find this useful.
nixer600 is offline
post #73 of 197 Old 03-18-2013, 08:33 PM
87yellowyj
Looks awesome, love the build.
87yellowyj is offline
post #74 of 197 Old 03-21-2013, 03:58 PM Thread Starter
nixer600
My tie rod and drag link was to long so I cut out what I needed to, beveled the edges, sleeved the tube with the only thing I could find, and welded it up. No I am not a welder, but I think it will be strong enough to hold together.
image-1242612619.jpg   image-1818108252.jpg   image-3443211622.jpg   image-2903582229.jpg   image-1502796453.jpg
nixer600 is offline
post #75 of 197 Old 03-23-2013, 12:27 AM Thread Starter
nixer600
Dosent look like much, but I didn't have much in me today. I don't feel well most of the time. Anyways I took the rock sliders steadily brushed on gel paint stripper, let it soak lightly scrape, brush on lightly scrape 5 times. Then pressure washed, a now plain steel. I will DA them to ruff them up and the etching primer and raptor coat them
nixer600 is offline
