76 cj5 350 sm465 205 full width axles. - JeepForum.com
post #1 of 6 Old 11-24-2015, 12:51 PM Thread Starter
ElyTodd
Getting ready to start my project. Any good build threads I should take a look at? How far will I need to strech it out? Planning to use yj springs. I want to build my own shackle perches so any ideas there would help. Have found several motor mounts which is the best bang for my buck. I am on a limited budget but not in a hurry to get it done. Off road use only. I'm sure I will have a lot of questions to come but for now any advice from people that have done a similar build would be greatly appreciated. Thanks
ElyTodd is offline
post #2 of 6 Old 11-24-2015, 07:39 PM
levergun
1979 CJ5
So, I have a slightly similar build. 79 cj5, Chevy Dana 60 front, Chevy 14 bolt rear, amc 401, ford t18, Dana 300.
Which axles are you running?
I would not run the 205. Way to big for a jeep. Unless you want a 6" tcase skid drop.
The picture is the best I currently have (dark and cold where the jeep is) but shows my outboarder spring hangers
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #3 of 6 Old 12-05-2015, 07:28 PM Thread Starter
ElyTodd
thanx!! looks great. i have the 44 in front and 12 bolt out back im planning on putting under it. as of right now im trying to decide how far forward i can move my motor mounts. if i run the radiator in the back like i was planning anyways it looks like i can come forward 4 inches and still have room to work with. is 4 inches too drastic? reading all of the builds i can find everyone stays under 2 inches.
ElyTodd is offline
post #4 of 6 Old 12-10-2015, 11:44 PM
levergun
1979 CJ5
The issue usually isn't in the radiator area. It's in the steering box/oil pan. If you go more than 2" forward with the engine you start getting the axle to oil pan clearance really tight. Especially under bump. So, You stretch the axle forward. Now The steering isn't inline so you have to stretch the steering box fwd. Also, now your shackles are hanging out the front so you don't gain any approach angle. Also moving the engine that far forward will put the shifter for the trans under the dash, so you'll have to build a Z shifter.
So I guess the question is what are you attempting to accomplish by moving the motor forward? Also rocks or mud?? I'm guessing mud from the radiator mounting. And what size tires?
levergun is offline
post #5 of 6 Old 12-16-2015, 06:31 PM
lovett86
looking forward to some pics of the progress
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #6 of 6 Old 12-17-2015, 02:48 PM Thread Starter
ElyTodd
Have been working up on the slope so havnt gotten anything togeather yet. Be home next week and going to start in on it. Would it be worth the hassle to spend the money for the adaptor to run the dana 300 transfer case? It would save me a lot of room but that 500 that could be use elsewhere
ElyTodd is offline
