6in Lift and 33's? - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 6in Lift and 33's?
Engo winches available at www.rockridge4wd.com! Free shippSwag Off Road BIG-HIT TJ-YJ Rear BumperCyber Sale on RUBICON EXPRESS - Short Arms, Long Arms, Tra
Unread 11-27-2013, 08:07 PM   #1
Rapterlined
6in Lift and 33's?
Okay im trying to figure out what a 6in lift would look like with 33's. im very curious. I know most people run 35's but u JUST bought new tires so im just seeing if anyone is running them. Pics would be helpfull
Rapterlined is offline   Reply With Quote
Unread 11-27-2013, 08:09 PM   #2
sjones26573
GO GOATS!
sjones26573's Avatar
I can say that will look terrible, plus there is no good reason to run 6" of lift.
Also this is posted in the wrong place.
sjones26573 is offline   Reply With Quote
Unread 11-27-2013, 08:13 PM   #3
JustJeepin85
bahahaha, i have 4.5 in SA lift + 2 in BL and MC overlines. i run 37's, i wouldnt even consider anything smaller then 35s. on a yj go with 33s and a 2.5" SA lift itll look "normal" and handle much better then any 6" combo you may think of.
JustJeepin85 is offline   Reply With Quote
Unread 11-27-2013, 08:25 PM   #4
Rapterlined
Ok we'll right now I have a 2in shackle, so should I try to get another 2 inches to have a 4in lift? Also if I get a suspension lift does that add to my shackle or what? I know just about everything about my jeep other than lift wise
Unread 11-27-2013, 08:30 PM   #5
JustJeepin85
Why not go with tube fenders? Prolly cheaper then going the lift option.
I'll be honest I can't help much with yj suspensions
Unread 11-27-2013, 08:37 PM   #6
Rapterlined
You think they will give the flex room I need?
Unread 11-27-2013, 08:41 PM   #7
JustJeepin85
Look up metalcloak.com or aev high line or some of the other options out there.
I ran 33s on stock suspension + Mc arch tubes with no issues in the front and slight rubbing in the rear.
Metal cloak will tell you on sight what's possible with what they have and if you have questions, call Matson he'll answer anything he can.
Unread 11-27-2013, 08:45 PM   #8
Rapterlined
Ok! Thanks for the help I appreciate it!
Unread 11-28-2013, 10:21 AM   #9
tjcj
Your 2" shackle lift only gives you 1" of actual lift . Yes new lift springs will add to the overall lift of your Jeep . 4" springs + 2" shackles = 5" of lift.
Sent from my XT881freeze ray gun using JeepForum
Yakima Valley Mountaineers. PNW4WDA[QUOTE=Willu;14149473]Finally you understand that every item sold by currie was hand made by the gods[/QUOTE]
tjcj is online now   Reply With Quote
