6 Day TJ Daily Driver, sorta, Build... - Page 6 - JeepForum.com
post #76 of 131 Old 02-01-2014, 09:33 PM
jherrington
Originally Posted by theGiantPanda
thanks.... those look spray tinted?
Light coat of plasti dip. Cheap, I know I know.. I just wanted to see how it would look.
jherrington is offline
post #77 of 131 Old 02-02-2014, 04:12 AM Thread Starter
theGiantPanda
Swap This...
theGiantPanda's Avatar
Well it Worked!
I used the stock lights from Betty in the Hemi build so it's down to clear or smoked... 51% smoked
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #78 of 131 Old 02-02-2014, 08:23 PM
jherrington
Is cruise control a capable option with the 5.3 swaps?
post #79 of 131 Old 02-03-2014, 12:22 AM Thread Starter
theGiantPanda
Swap This...
Yeah but I haven't dealt with that yet. None of the swap jeeps I used as donors had it. Lol
the new shop...
shop email....
adding more daily
post #80 of 131 Old 02-04-2014, 11:20 PM Thread Starter
theGiantPanda
Swap This...
ok so I ordered a set of clear fender lights, they were 20$ cheaper than a set of smoked. My buddy has a can of the spray tint stuff from doing his TJ. I am going to hit the [2] fender lights with that and go with it.
did a little more clean up wiring work today regarding the battery and pdc area. I need to order a spool of 6g cause it appears that I am out LOL.
heres where I made most of my connections to the gm harness, passenger side at the firewall.
then I swapped power supply wires out of the quick relay pack I threw together over the summer to run all the aux lights. streamlined it a bit.
got rid of this
for this, with a remote fuse pod
'crappy cell pic-sorry- but you get the idea
remounted the relay pack and the [2] fuse pods that supply all the power needs for the LS systems
the np231c mega short SYE kit with GM VSS port is on the way. hopefully it shows in the next few days here. I would like to get it installed in the tcase and have it installed up under the jeep, so i can knock out more of the little stuff like 4wd linkage etc and then I can get the rear DS made and the front modified.
the new shop...
shop email....
adding more daily
post #81 of 131 Old 02-05-2014, 12:47 AM
zerocool1
That's a very clean relay assembly
When all else fails... Hit it with a hammer!
zerocool1 is offline
post #82 of 131 Old 02-05-2014, 03:22 AM Thread Starter
theGiantPanda
Swap This...
Thanks. And for the record after I saw the pic I went back and straightened up the black fuse pod lol... OCD ehhh !
the new shop...
shop email....
adding more daily
post #83 of 131 Old 02-06-2014, 11:44 AM Thread Starter
theGiantPanda
Swap This...
this is the part I have always disliked. I pretty much have it squared away now, but still daunting...
new lower done. the uppers is done as well but appears I didn't snap that.
the new shop...
shop email....
adding more daily
post #84 of 131 Old 02-08-2014, 09:52 PM Thread Starter
theGiantPanda
Swap This...
well it started with my buddy dropping off a piece of aluminum tube, couple left overs tig'd together. then I got to making the intake. I needed to get 'up and over' the waterneck/upper radiator hose on this LS motor. the orientation is different and makes it a slight more bit of a challenge. no quick shot over to the fender and done in this case.
I needed a spacer to take up the gap between the air filter and the MAF. the 3.5 to4" spacer in the kit was too thick. as the MAF is something like 3.62 or something. anyways, I cut down the stock rubber grommet to what I needed. a spacer.
starting the mock up process..
once I was happy with the position and orientation, I bent a piece of aluminum bar sock then located my mounting holes
made the mounting bracket and got it bolted to the AF and then, mounted the assembly to the fender.
ending up with something like this...
heres the clearance between the AF and the grille support..
now im off to shorten the MAF wires, I cut almost 3+ feet out of that circuit
the new shop...
shop email....
adding more daily
post #85 of 131 Old 02-15-2014, 02:16 AM Thread Starter
theGiantPanda
Swap This...
cleaned up some more of the engine compartment. I have to take care of a few small trinkets and that should be all set-other than fuel lines.
today was np231c SYE install day and work on a cable shifter set up day
enter [1] np231c out of a mid 90's s-10 series. check out the looooong output shaft....
tailshaft extension off
popped the rear case half off. found the common 1.25" chain and further investigation revealed the common chevy 4 planetary gear set. ehh its not the 6 but better than the 3 in the 231J
the short shaft next to the stock shaft
short shaft installed and rear case half back on...
new tailshaft bearing housing installed... do you know how much of a pain in the tail it is to get 200ft torque on a nut, whilst sitting on a bench... lol
the np231c I have, has the same shift pattern as the np231J however, the lever is inverted. it needs to be on the bottom to work correctly with the jeep's 4wd shifter, let alone a push/pull cable shifter.
I grabbed a shift lever off another 231J case I have on the shelf. looks like it would work. I did have to clearance out one of the case ribs alittle...
wanted to angle it in towards the case some. I put it in the vice and gave it a few wacks. when I looked at it, the lever had stress factures where it bent. sweet. I ground them out and threw a bead of weld in.
threw on a spare transmission adapter to start mocking up the cable shifter mount
knocked out the tub side mount for the cable shifter
then a paper template to start....
turns into this... I had to cut reliefs in the bracket where I wanted the bends. I cut it out before I bent it, so if I had tried to bend it in the brake, it would distort the profile because of the removed material. I just ran a bead of weld in the reliefs and good to go...
and a quick test fit...
tomorrow, I am hoping to get the 231C installed up under the tunnel and the tub bracket mounted as well. I am going to order up another shift cable and get that on its way.... I have to do [2] other jeeps.. making the transfer case side bracket for the 545rfe/np231J set up is going to be fun too...
the new shop...
shop email....
adding more daily
post #86 of 131 Old 02-15-2014, 11:49 AM
contdevelop
nice work!
contdevelop is offline
post #87 of 131 Old 02-15-2014, 07:01 PM
jherrington
Woo! I've been waiting for your plans on the shifter linkage. I followed your lead and picked up a range rover shifter cable too.
post #88 of 131 Old 02-20-2014, 04:07 PM
phil823
plan on making a few of those Shifter Brackets since you have a template lol?
my list of things to buy from you are going steadily!
phil823 is offline
post #89 of 131 Old 02-20-2014, 06:45 PM
G Beasley
Nice clean work on the shifter cable ...
G Beasley is offline
post #90 of 131 Old 02-20-2014, 07:23 PM
Ryanw10
I really like the intake work but is that going to clear the hood? Im running the stock intake from the truck and it comes about an inch away from my hood even with a 1" body lift
Ryanw10 is offline
