4BT Cummins Swap Build Thread, PICS! - Page 4 - JeepForum.com
 1Likes
post #46 of 234 Old 10-14-2011, 11:14 AM Thread Starter
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
No I have not seen that thread....
That shop was at my school, and very very limited in machinery and tooling, our pride and joy was a HAAS CNC minimill that the shop manager did nothing to take care of and was getting pretty rough.
All my motor mount stuff I designed on Solidoworks and sent the drawings to a laser cutter/bender, and they did it for me. They were laser cut from 3/16" steel, and they have some type of automated bender to bend stuff up, then I welded them together.
I would say like 2.5" high, 24-30" long, somehwhere around there
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #47 of 234 Old 10-14-2011, 12:18 PM
ninjakid
1987 YJ Wrangler
http://www.jeepforum.com/forum/f7/10...-read-1234308/
Some don't seem to honor it while others do.
Every little bit saved helps.
Save a little on a battery or two.
CNC mills are pretty neat.
Wish we had one.
But machinery doesn't last long without maintenance.
I picked up a kwik way model f boring bar for $350 to bore my 258, he was selling it because he was getting to old to work on engines anymore and his hands couldn't hold anything steady anymore.
I am pretty sure that machine has been dropped at least once because the rod that spins the cutter is bent and there was no oil in the transmission when we bought it.
It still runs well considering it is at least 50 years old but occasionally it starts acting strange on us.
When I have some free time I'll try to make up a template for the sticker and see if I can make a sticker that looks good and send it to you.
24" is the max it can go across so it might be a little smaller than you would like, I'll see what I can do.
Hmm guess I need to ask a couple other questions.
If I can get it to work and make a good template, do you want flat or shiny in black or white?
Also you just want a plain font or a military stencil font?
Once I get a good template I'll use a roll of paper and a pen in the machine and have it sketch out what it would look like.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #48 of 234 Old 10-14-2011, 05:20 PM
Drix
Yea, I do not want to mount my motor on a 10 deg angle
I have no idea about the deactivation, I don't think it does. If it did it would be some internal mechanical set up, but I really do not know.
Its computer controlled it just turns off te injectors.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline
post #49 of 234 Old 10-14-2011, 08:12 PM
dodger889
That is for a common rail system with electronic injectors. The tb4 is fuel pump (mechanical) controlled injectors. Now he could do a compression release but then the would require a lot of work.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #50 of 234 Old 10-14-2011, 09:12 PM
Drix
AHH I see now.
USMC Jeep Club #6
Drix is offline
post #51 of 234 Old 10-16-2011, 12:22 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
yea these motors are completely mechanical, the only thing they need to run is power to the fuel shutoff solenoid, no computers or anything.
This thing fires right up, I do not thing I am going to have any starting issue with it. I read somehwere that it is rated to start normally at like -10 degrees F, assuming the fuel is not frozen haha.
post #52 of 234 Old 10-16-2011, 01:47 PM
Spuznick242
Sweet! I'm so glad to see this finally on here! Thanks for the help with planning my 4bt swap and it's so much nicer to see some pics.
But I'm going to look at another YJ this weekend that we might buy that I can do the swap on and yet still have my YJ as my DD...right after I rebuild the trans in it. As soon as I get my jeep solid for a DD then I'll really hunker down with the projects and get some black smoke and spoolin turbo.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #53 of 234 Old 10-17-2011, 06:05 AM
Spuznick242
Btw, I dont remember what you said you were going to do for vaccume pump to create usable vacume...I'm thinking about going with an electric one, at first I was going to go with a serpentine system but it's just not worth it, free up some power and fuel milage and make it a bit easier with the brackets.
post #54 of 234 Old 10-17-2011, 06:15 AM
oldtime_ironman
Actually there's an easier way to do the brakes if you got some good junkyards nearby. Mainly, use the power steering instead. A lot of RV's and buses do that - they tap off the power steering pump into a special brake booster. Lots of diesel pickups from the 1980's and 1990's do that too. Look for anything with dually rear and diesel and it'll have what you need. Like an old school bus or something.
oldtime_ironman is offline
post #55 of 234 Old 10-17-2011, 06:39 AM
Collin89Sahara
Do you have the paint code for the sahara green by any chance?
Collin89Sahara is offline
post #56 of 234 Old 10-17-2011, 07:31 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
I used a vacuum pump kit just like this one:
http://www.ebay.com/itm/New-SSBC-Ele...sories&vxp=mtr
post #57 of 234 Old 10-20-2011, 06:36 AM
ninjakid
1987 YJ Wrangler
Sounds like a pretty good plan you got going there.
175 sounds reasonable for custom motor mounts for a heavy 4 cylinder diesel engine.
Hope it all goes well.
It'd be pretty cool if JD started using yours for their swaps.
ninjakid is offline
post #58 of 234 Old 10-20-2011, 07:00 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
I would not mind working with JD, maybe I will get in contact with them, They are not too far from my hometown, but I want to try things on my own for a bit.
post #59 of 234 Old 10-20-2011, 07:00 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
I would actually really be interested to see if my mounts reduce vibrations over theirs.
post #60 of 234 Old 10-20-2011, 09:17 AM
Spuznick242
Wow, $175 is a steal. I would love to get a set, I might even buy a set ahead of time before I really get into my project. If your making and selling the mounts how about you supply other hardware and parts needed to do a 4bt swap, like let the customer pick their own 4bt to save costs and the transmission as well as transfer case but supply the brackets and odds and ends to mount it all up so you could just supply the cheaper stuff and let the customer shop for the more expensive parts.
But have you thought about propane or even methane injection? I would imagine its possible on the 4bt but I'm not sure, I dont see why it wouldnt, my uncle's powerstroke V12 has it and it's a real power booster when tuned in well with the turbo.
What's the boost run at stock? I heard 13lbs but what turbo is mated to it? Sorry for all the questions, normally I research it but it's been crunch time for me at school.
90 4.2 to 95xj 4.0 Swap Build Thread yjcrawlr YJ Wrangler Technical Forum 284 03-31-2017 09:24 AM
My 8.8 build/swap thread SeanWilliams YJ Wrangler Technical Forum 54 11-16-2011 07:17 PM
8.8 Swap Into TJ Build Thread GreenJip TJ Wrangler Technical Forum 154 04-14-2011 04:30 PM
4.0 Swap Walkthrough, Build Thread all in One !!!! cevans87 YJ Wrangler Technical Forum 10 03-09-2010 11:20 AM
D35 swap to Ford 8.8 build thread. northjeep YJ Wrangler Technical Forum 9 02-01-2007 08:08 PM
