4.7 Baja stroker - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 4.7 Baja stroker
The Original 3/8" Ruffstuff Diff Cover!The Ruffstuff NOT Universal 4 Link Kit!Flush Mount LED Bumper Lights, CREE
Unread 06-17-2014, 12:58 PM   #1
neverover
1994 XJ Cherokee
4.7 Baja stroker
I recently installed atks 4.7 Baja stroker an I'm needing to tune my computer to the new engine it's for a 1994 jeep cherokee is there anyone who has had something similar down that could help ??
HP: 275HP
TORQUE: 320TQ
Engine Type: AMC Straight 6 Cyl
Displacement (cu.in):242
Block: Cast 549, 341 or 499
Bore / Stoke: OE .040-.060 Bore
Crankshaft: 258 CI /2.125 Snout .850 Pilot Hole
Rods: 258 CI
Pistons: Forged
Rings: Moly
Camshaft Type: HYD. Flat Tappet
Camshaft Lift: Lift .484 x .507
Camshaft Duration @.50: 213 x 220
Cylinder Head Type: 91-98 Cast#630 Ported
Rocker Arm Type: Aluminum Roller Rockers
Sheet Metal: O/P, V/C & T/C
Recommended Fuel: 92 Octane +
Max RPM: 5300
neverover is offline   Reply With Quote
