37s on a 4 inch lift? - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 37s on a 4 inch lift?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Clayton Off Road JK Short Arm Suspension Kits
Unread 09-16-2014, 08:10 PM   #1
NickClark333
Okay guys I've been researching forever and I would greatly appreciate some advice on 37 inch tires on my 4inch lift. I hate to be that guy but will it fit? And maybe pics?
NickClark333 is offline   Reply With Quote
Unread 09-16-2014, 08:30 PM   #2
BRC_1980
On a JK? Yeah. No idea what you have tho...
BRC_1980 is offline   Reply With Quote
Unread 09-16-2014, 08:33 PM   #3
84jeepcj7rock
84jeepcj7rock's Avatar
You can fit 37s on a stock JK just by taking the fender flares off. You may have to grind down the pinch seams.
84jeepcj7rock is offline   Reply With Quote
Unread 09-16-2014, 09:06 PM   #4
NickClark333
No not a jk, I currently have a 97 tj
Unread 09-16-2014, 09:09 PM   #5
NickClark333
no it's a 97 tj
Unread 09-16-2014, 09:12 PM   #6
Jonathanjr1
With a lot of trimming, tube fenders, and some new axles.
Jonathanjr1 is offline   Reply With Quote
Unread 09-16-2014, 09:15 PM   #7
NickClark333
I have trimmed fenders and d44 axle
Unread 09-16-2014, 11:02 PM   #8
ccoor
Junior Member
ccoor's Avatar
Tube fenders with 37" will work on TJ might be a little tight with stock fenders.
ccoor is offline   Reply With Quote
Unread 09-17-2014, 12:10 AM   #9
tkfx
Wrong section, id post this in http://www.jeepforum.com/forum/f9/ . After that fill out your jeep profile so we know what you got to give you better answers.
My Build Thread:
http://www.jeepforum.com/forum/f22/tks-yellow-krait-ljk-buildup-2337401
tkfx is online now   Reply With Quote
Unread 09-17-2014, 07:51 AM   #10
dayriesw
dayriesw's Avatar
Yes you can do it. It will take a bit more than a 3 or 4 inch lift kit and a lot of trimming here and there to tweet you stock axles to handle 37s as well as fit them on a shorter lift.
Since photobucket doesnt want to work right, I cannot upload a photo so show you. I drive a LJ (TJ) with 37s and 2 inches of lift and 1" body lift totalling 3 inches. Does well on road and off and is low enough to keep my feeling planted while off camber.
Impact Orange LJ - DD...sitting low, flat bottomed, fully armored and locked on 37s
dayriesw is offline   Reply With Quote
Unread 09-17-2014, 08:43 AM   #11
monsonman
monsonman's Avatar
off camber like this?
'98 TJ- build: http://www.jeepforum.com/forum/f22/m...build-1461959/
monsonman is offline   Reply With Quote
Unread 09-17-2014, 08:49 AM   #12
kinggatman
Made in USA
kinggatman's Avatar
2010 JK Wrangler
Maybe this will help a bit:
http://www.jeepforum.com/forum/f96/faq-will-rub-610856/
2010 Black JK Sport
"Daisy"
Made in USA
kinggatman is offline   Reply With Quote
Unread 09-17-2014, 09:17 AM   #13
dayriesw
dayriesw's Avatar
exactly.
Unread 09-17-2014, 01:14 PM   #14
NickClark333
Thanks for all the help I've almost decided on 36s with maybe a body lift
Unread 09-17-2014, 01:52 PM   #15
monsonman
monsonman's Avatar
heres mine with about 4" and 36 irocs. they measure to 36.8" but they are aired down in this picture. i just added a 1.25" body lift so it sits just a wee bit taller now
