311LJ's UNLIMITED Build - Page 15 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 311LJ's UNLIMITED Build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 11-14-2012, 03:42 PM   #211
Jeeper69
Originally Posted by 311LJ View Post
Well I got the fuel pressure regulator in...
Attachment 507189
Starter installed
Attachment 507190
And a new battery in
Attachment 507191
Pretty good for 3 hours of work in the snow
What's it like driving on slick or icy roads with your auto-lockers?
Jeeper69 is offline   Reply With Quote Quick reply to this message
Unread 11-14-2012, 11:53 PM   #212
311LJ
311Popo
311LJ's Avatar
Well to be honest I have never had an issue. In the WJ I had a limited slip up front and an Aussie locker in back and this jeep has been lock rights/Spartans and now full Detroit's. I haven't had the pleasure of driving in the snow with Detroit's yet and I'm betting they will be more noticeable, but the other lockers have been fine. I have never had any problems and even have been able to pull people out of ditches and stuff. Maybe I'm just accustomed to snow driving but as long as you plan ahead, snow is easy.
John
04 TJ Unlimited, GenRight Armor, 37's Unlimited Build Thread
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY* WJ Build Thread
*UTAH JEEPCREW #01*
I ♡ John
311LJ is offline   Reply With Quote Quick reply to this message
Unread 11-15-2012, 12:03 AM   #213
BLACK04WJ
ya snow isn't bad at all. then again I have Vari-lok front and rear with AWD
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline   Reply With Quote Quick reply to this message
Unread 11-16-2012, 12:27 AM   #214
Jeeper69
1.Is it true you need to let of the gas on turns for auto-lockers, and that they only engage with acceleration? Because if that were the case, my Jeep would probably go EXTREMELY slow.
2. How is driving the Jeep on windy(wine-dee) roads? Can you still gas into and out of turns?
3. How bout roads in the rain?
Unread 11-16-2012, 01:09 AM   #215
311LJ
311Popo
311LJ's Avatar
Well the entire job of the locker is to lock. So of coarse it is going to do its job when ever the conditions allow/require it too.
So the difference with open and autolocker in a turn.
With an open dif, the power goes to the outside tire or the tire turning the fastest. The power of the vehicle goes to the point of least resistance. That's why open difs spin a tire in the mud or the air.
An auto locker is the opposite. The locker will not let a tire turn slower then the power coming in. So when you are going around a turn with an auto locker, you are essentially powering the inside tire. The locker is "allowing" the outside tire to turn faster then the tire receiving power. If you apply torque and there is enough to spin your tires, it will spin the inside tire.
So to answer your questions
1. No you do not have to let off the gas in a turn. You just have to remember that you are powering the inside tire. If you put power to the ground you are going to spin that inside tire and that is where you could spin out or loose control. I have never had an issue. It is very easy to chirp the inside tire whenever I want tho.
2.windy roads are great. You can apply as much power as you want, just Keeping in mind that at lower speeds its easy to spin the inside tire.
3. Wet/slick roads are easier to spin your tires just like in any other vehicle.
Hopefully that made since lol
John
89 XJ Laredo, 31's
*UTAH JEEPCREW #01*
I ♡ John
Unread 11-16-2012, 01:29 AM   #216
Jeeper69
It did, thank you very much. Given that I have a Dana 30 front, and a Dana 44 rear, if I had to choose between getting a front auto locker and a rear one, what would be better?
Unread 11-16-2012, 01:40 AM   #217
311LJ
311Popo
311LJ's Avatar
It really comes down to the type of wheeling you do (rock/dirt/mud) and if you plan to drive in 4wd on the pavement.
John
89 XJ Laredo, 31's
*UTAH JEEPCREW #01*
I ♡ John
Unread 11-17-2012, 02:06 AM   #218
Jeeper69
Just 4wd on the pavement the few times I decide to go up to snowboard and there's snow or ice on the road.
Also, do Detroits wear down the surrounding components in the axles and the drivetrain components due to the torque actions in the locker of constant daily driving? As well as wearing down tires faster?
The lockers themselves...do they wear out from daily driving?
Unread 11-17-2012, 08:12 AM   #219
311LJ
311Popo
311LJ's Avatar
Well I'm sure any parts in a vehicle will wear from use, but the Detroit's have a reputation of withstanding the test of time. They will wear your tires faster if you drive aggressively
If you plan on driving in 4wd on the road, then I would not put an auto locker in the front. You can't really turn on dry/wet pavement with an autolocker.
Plus the d44 locker will be able to hold up to some more bashing then the d30.
John
89 XJ Laredo, 31's
*UTAH JEEPCREW #01*
I ♡ John
Unread 11-17-2012, 12:49 PM   #220
AngryTJ
nice LJ! Your fenders and corner armor look great since you powdercoated them. Deep down I was hoping you were going to body match your front fenders but they still look good
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 11-17-2012, 01:19 PM   #221
311LJ
311Popo
311LJ's Avatar
Thanks! I will body match the entire jeep soon enough! I just wanted to get them coated so I can work on all the other projects this jeep needed.. Plus the Powdercoating was a steal at <80$
John
89 XJ Laredo, 31's
*UTAH JEEPCREW #01*
I ♡ John
Unread 01-20-2013, 04:00 PM   #222
311LJ
311Popo
311LJ's Avatar
Well Quinn and I went and visited Chris and did a little work on the LJ
Attachment 547149
Attachment 547150
Before
Spartans and 4.56
Attachment 547151
Attachment 547152
Attachment 547153
Attachment 547154
After
Detroit and 4.88
Attachment 547155
Attachment 547156
John
89 XJ Laredo, 31's
*UTAH JEEPCREW #01*
I ♡ John
Unread 02-14-2013, 06:29 AM   #223
clgielin
2003 WJ
How's the front shaft coming along?
Chris
2003 WJ 4.7L
Build Thread Here: 2003 WJ
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is online now   Reply With Quote Quick reply to this message
Unread 02-16-2013, 09:18 AM   #224
Tuffjeeper
What Chris said...
The Tuff Jeep Build Thread
Originally Posted by plrbear View Post
Destroyed it somehow..... It went wobble wobble wobble boom
Tuffjeeper is offline   Reply With Quote Quick reply to this message
Unread 02-16-2013, 09:42 AM   #225
311LJ
311Popo
311LJ's Avatar
Ha ha well... It hasn't been dropped off yet lol.. I'll let you know when u can get to it. This is my last month of working 70hrs a week before the new job starts can't wait for free time and actually having money lol
John
89 XJ Laredo, 31's
*UTAH JEEPCREW #01*
I ♡ John
