290tjjeep's 98 TJ build - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 290tjjeep's 98 TJ build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGibson WK HEMI 3" Catback - 5 Day Special!The ULTIMATE "Selectable" Locker System! Brough
Unread 03-16-2013, 04:15 PM   #31
290tjjeep
Picked up an anti-rock sway bar and installed it last night! Ended up shearing off a bumper bolt so I'll have to get that out so I can put my steering box skid and winch back on. Overall impressions of the anti-rock is that offroad it's a major difference! It's much more stable and I have better control. On the road is not as bad as I thought. There is a little bit more sway, but less that being fully disconnected. I suppose having a low center out gravity helps!
290tjjeep is offline   Reply With Quote Quick reply to this message
Unread 03-24-2013, 04:12 PM   #32
McChillen
Do you have the ultra-high clearance ucf skid? If so how does the cat fit and how much room is there between the tub and the t-case? I'm looking at doing the same set-up but with no body lift, so just curious on how the clearance is on yours. Sorry for all the questions. Jeep looks great! I really like the flares and wheels!
McChillen is offline   Reply With Quote Quick reply to this message
Unread 03-24-2013, 04:58 PM   #33
290tjjeep
I have the ultra high clearance UFC skid! I had to trim the heat shield above the cat, it would make contact and rattle. By the way I have a 1.25 body lift which helps a lot.
Unread 03-29-2013, 02:56 PM   #34
290tjjeep
Some pictures from the last week!
Unread 03-29-2013, 02:57 PM   #35
290tjjeep
Unread 04-21-2013, 05:18 PM   #36
290tjjeep
Added a skid plate to the Dana 35! Perfect for jeeps with small lifts. Any other type of cover would hit the gas tank skid.
Unread 04-30-2013, 08:32 PM   #37
290tjjeep
Photos from jeep beach!!
Benefits of having a tummy tuck!
Unread 06-14-2013, 08:10 AM   #38
290tjjeep
Finally got my Gen-Right tube fenders in! Finished putting them on a few days ago and going to take them to get powder coated this weekend!
Unread 06-14-2013, 11:43 AM   #39
jeepwrangler97
They look awful....please take them off....send them to me....& the rear flares too....
Sent by a messenger bird
jeepwrangler97 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2013, 07:29 PM   #40
290tjjeep
You should at least wait for me to powder coat them!
Unread 06-23-2013, 06:12 PM   #41
290tjjeep
Got the fenders back from powder coat on Friday! Also I wired up the LED turn signals too!
Pictures from today
Unread 06-23-2013, 09:55 PM   #42
jeepwrangler97
Ok....now I'll take them
Unread 06-26-2013, 07:47 PM   #43
290tjjeep
Finally decided it was time to get new O2 sensors for the jeep. Kept getting check engine codes for the jeep the past year. I went with NGK O2 sensors because they are the OE ones. Install was easier than I thought. The hardest part was figuring where to find room for the ratchet.
The front was causing the codes
Back one looked okay but I decided might as well replace both at the same time.
Then took it for a ride to test the difference and I can tell I've gotten some loss power back (at least I think). Also it's much smoother between shifts too!
Also while taking it out for a test ride I took it up to 85 mph haha
Unread 06-30-2013, 04:27 PM   #44
290tjjeep
Bump for weekend wheeling!
Unread 07-20-2013, 07:11 PM   #45
290tjjeep
Went to the 5th annual Matanzas Jeep Club show and shine. Awesome turn out and helped Badfish Powder coating display their work from my jeep! Also got to see Kraken in person, it's big... really big!
