2012 build. awinski - Page 6 - JeepForum.com
post #76 of 122 Old 02-09-2013, 12:11 PM Thread Starter
awinski
UPDATES: well the quest for a good junk yard axle still continues. seems like the electronics will be the hardest part, aside from finding dana 60s wit 4.56 gearing. so i have an updated plan, ive also been reading up on building the stockers, i know a d30 will never be as strong as a 60, but im sure i can make it strong enough for 37s. artec truss, and gussets, custom 1/4 skids across the bottom, cromoly shafts, CTM u joints, and a regear. really want to get 60s but if i can't find any in order to get it done by late fall then ill be going with this plan.
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #77 of 122 Old 02-10-2013, 01:05 PM Thread Starter
awinski
not that anyone cares. but ive been retalked into devoting this next 9months on my axles. have a lead on an 05super duty axle. this is the ideal axle too!
awinski is offline
post #78 of 122 Old 02-10-2013, 04:24 PM
Tanimal
I care! I was sad to see that you were going to just build your Dana30, personally I'm just waiting until mine breaks to justify upgrading Glad that you might have a lead and hopefully it's something promising!
Learning as I go and it's worth every penny!
Tanimal is offline
post #79 of 122 Old 02-10-2013, 04:39 PM Thread Starter
awinski
haha thanks for caring tanimal! yea d 60s up here are a dime a dozen, thats not the problem, the problem is making it (jk compatible) i wasn't just building it, the vision i had it would've been the most monsterous d30 in history, but the thought that i could have two 60s for same price or less. i can't pass it up, by the end of the year my tires will be worn, the 60s should be done, ill bolt them on with the new set of tires and wheels. i didn't want to get that involved, then i remembered, i have atleast 9months.
awinski is offline
post #80 of 122 Old 02-12-2013, 08:55 PM Thread Starter
awinski
helping a friend this weekend in his shop with his cummins build, after that im gonna whip something up for my tire carrier, ive bought everything and it will be rattle free and no metal rusting hopefully. also will be wiring up reverse lights, and license plate lights if there's time! should be fun! update pics on sunday hopefully
awinski is offline
post #81 of 122 Old 02-21-2013, 07:58 PM Thread Starter
awinski
got the reverse lights wired. the cummins work took longer than expected. anyways, heres a crappy cell pic. not bad for $3 off amazon
awinski is offline
post #82 of 122 Old 02-26-2013, 05:59 PM Thread Starter
awinski
will be tucking the rear bumper/ cutting the frame rails this weekend, debating upon two different ideas, one requires lots of cutting, and the other requires lots of cutting and some welding, we'll see how this works out.
awinski is offline
post #83 of 122 Old 02-27-2013, 01:45 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Good lookin rig...side note, the above video link doesn't work.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #84 of 122 Old 02-27-2013, 02:53 PM Thread Starter
awinski
thanks tomb! i know, dumb youtube deleted the vid because of the music used, a friend did all the taping, its a shame because he rode along for the really epic parts, like where i school both of my buddies two doors in a muddy hill climb . once the better two parts are uploaded ill put links
awinski is offline
post #85 of 122 Old 02-27-2013, 04:57 PM Thread Starter
awinski
got some work down on the rear bumper, trying to get everything perfect so it sits almost flush with the pinch seam, will only stick out about 2" now. this means the tire carrier will also be closer, how much i will tuck that is still undecided. but the TC should be done in the next month.
awinski is offline
post #86 of 122 Old 03-03-2013, 03:15 PM Thread Starter
awinski
finished up the rear bumper today, only sticks out about 2", used the plasma cutter to remove the rear cross member, and to cut the correct shape out of the bumper, then it was just simple drilling from there to remount it.
plasma cutting.jpg   no crossmember.jpg   who needs a crossmemeber.jpg   body mount fixed.jpg   sanchezi finally home 006.jpg
awinski is offline
post #87 of 122 Old 03-03-2013, 04:58 PM
BigBlue7
2010 JK Wrangler
You want to make me a rear bumper?!? Looks good!
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline
post #88 of 122 Old 03-03-2013, 05:00 PM Thread Starter
awinski
haha i didn't actually make the bumper, a shop in reading did, i just modified it to my liking. i could do it, if you're ever in pennsylvania lol
awinski is offline
post #89 of 122 Old 03-03-2013, 05:14 PM
TheBoss
So are you going to use the tire carrier again? If so are the mounting bars going to be lengthened to get the tire to fit in it? It looks much better sucked in by the way.
TheBoss is offline
post #90 of 122 Old 03-03-2013, 05:27 PM Thread Starter
awinski
right now the main concern is getting this bumper sanded, and repainted, im still debating on tire carrier, the tire should now only sit about 1" from the tail gate now, so i shouldn't have to lengthen anything, used to sit about 4-5" away. and yea i like the look alot more, im gonna take the 1/4" piece of steel i cut out an weld/bolt it on underneath for even more strength.
awinski is offline
2012 jku build , awinski , offroad evolution , rock krawler , trimmed fender flares
