2006 Rubicon TJ Wrangler from stock. - JeepForum.com
post #1 of 26 Old 02-22-2013, 10:49 AM Thread Starter
JustinBooth52
2009 JK Wrangler
Im 18 and I had a 98 Wrangler I traded with some cash and another vehicle for my new Jeep 06 Rubicon. It has 101,000 miles and is bone stock except for the running boards that the last owner added on. I started this so I could post pics over the next few years as I build this beast.
JustinBooth52 is offline
post #2 of 26 Old 03-03-2013, 08:02 PM Thread Starter
JustinBooth52
2009 JK Wrangler
101000 miles and I just changed spark plugs, oxygen sensors, air filter and heater resistor pack.
2009 Red Rock JKU building it my way, one bolt at a time, with out instructions.
post #3 of 26 Old 03-28-2013, 07:59 PM Thread Starter
JustinBooth52
2009 JK Wrangler
first major problem: [QUOTE="JustinBooth52"]okay so any time I get on the gas hard from a dead stop or late rate of speed, also if I climb a hill a low rate of speed and really make the engine work the check engine light comes on and the jeep goes into limp mode and won't rev past 2250. the RPMs just bounce between 2000 and 2250. it resets itself when I turn it off and back on. the CEL code is P0206 which is open circuit on injector 6. I took it to the dealer and they diagnosed it with a bad PCM and estimated 800 to fix. I took it home and bought the PCM off line for 300 and I'm gonna install it my self. it comes plug and play ready(preprogrammed). but this didnt fix the problem. I returned the PCM and took it back to dealer. after a full day of working on it the came back again with PCM. I know that was false so I told him to keep it and keep working on it. the next day I call because I decided I was going to pick it up and take it somewhere else and he said hold on the think they found it and they are out testing it. about ten minutes later they called back and said the think they found it but can't tell because it only had a little fuel in it so they couldn't test to much. I said I would be right over. got there and he showed me how the wiring from the injector was running hard on the AC compressor cause it to short losing fuel input at injector 6 causing it to go to limp mode. he moved harness and showed me two other places it was doing it. I'm gonna go over it all but as for right now it seems the problem is fixed! I am so happy I have my RUBI back!!!!!!
post #4 of 26 Old 03-28-2013, 09:01 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Pretty bad that the vehicle pointed you right to it..... well the "dealer", and they still just wanted to throw a new ECU at it. One thing about these Chrysler vehicles is that they are actually pretty smart.... and WILL tell you whats wrong and be pretty darn accurate. I've been very impressed with that aspect of my TJ. Let this be a lesson to you..... stay away from the Dealer. Figure it out on your own, or find a mechanic you can trust. OH... NICE JEEP!!!!
gst95dsm is offline
post #5 of 26 Old 03-28-2013, 09:06 PM Thread Starter
JustinBooth52
2009 JK Wrangler
thanks man and yeah I probably won't be going back to dealer. I just couldn't find anything on the injector and what not but I was to nervous to get into the harness and mess something up so I took it in. the guy seemed a little dumb. he said my wrangler was super fancy and the engine compartment was crazy with wiring and sensors. I have worked on a few others and wranglers aren't near as bad. from now on it will be my own garage not the dealers.
post #6 of 26 Old 03-28-2013, 10:10 PM
gst95dsm
gst95dsm's Avatar
That is hilarious because as far modern vehicles go it doesn't get much more simple than your Jeep. Anyways, I too would have been hesitant to get into the harness, but you just have to look at things in their simplest terms until you understand them. Keep doing research until you understand what you're dealing with and you will be fine.
gst95dsm is offline
post #7 of 26 Old 04-10-2013, 07:45 PM Thread Starter
JustinBooth52
2009 JK Wrangler
replaced my thermostat.. small but needed since it was running at 155 and now is running at 210 like it's suppose too!
post #8 of 26 Old 07-12-2013, 06:33 PM Thread Starter
JustinBooth52
2009 JK Wrangler
my new summer jobs requires me to have clothes for 1-4 days, flame retardant clothes, booths and tools at all times. plus I have my emergencies stuff and as you know there is no room in the back of my jeep for all that but I hate to have stuff laying around up front so I made a wood shelf. three bed slats braced together resting on the wheel wells painted black!
post #9 of 26 Old 07-12-2013, 06:40 PM Thread Starter
JustinBooth52
2009 JK Wrangler
added a ham radio in the roof with a bracket that i made that screws into the door jam holes on the role cage. I like it it I'm thinking of a hole over head custom console system.
post #10 of 26 Old 07-12-2013, 10:45 PM
G Beasley
Good looking Rubi , I think red just looks good on a Jeep . What are you doing that requires flame resistant clothing ? And whats the next mod on the list ?
G Beasley is offline
post #11 of 26 Old 07-13-2013, 08:37 AM Thread Starter
JustinBooth52
2009 JK Wrangler
I'm installing monitoring systems on Natural Gas wells. I can't decide what my next mod will be. either a high rock 4x4 front bumper with chrome grill guard or 2in coil spring spacer lift. I want the lift so bad but I'll be leaving for college in August and I'll need all the gas mileage I can get. I'll probably do some small thing inside like the drake off road accessories.
post #12 of 26 Old 07-13-2013, 09:02 AM
G Beasley
A motor mount lift and 1.25" body lift would make for a good solid start . Once those are installed you could add a tummy tuck which opens up a whole new can of worms.
post #13 of 26 Old 07-14-2013, 07:37 PM Thread Starter
JustinBooth52
2009 JK Wrangler
I have also looked in to that because once I get out of college and start making the big bucks and can afford another vehicle this project is going to take off and it would be a step I have to take for all my plans anyways. the 2in BB lift would be thrown away after college.
post #14 of 26 Old 07-14-2013, 07:38 PM Thread Starter
JustinBooth52
2009 JK Wrangler
got the power hooked up to my ham radio today. anyone know any good channels in charleston WV.
post #15 of 26 Old 07-14-2013, 07:40 PM Thread Starter
JustinBooth52
2009 JK Wrangler
list of future mods to come...
