2006 Rubicon First Jeep - Page 4 - JeepForum.com
 1Likes
post #46 of 587 Old 05-06-2012, 11:21 AM Thread Starter
Hunter7158
Ok, thanks. Yeah money is always tight naturally. What are your thoughts about the LoPro? needed? or unnecessary? 1" BL and 1" MML enough room for the UCF Ultra High Clearance Skid?
Hunter7158 is offline
post #47 of 587 Old 05-06-2012, 11:41 AM
Jeffro06
Jeffro06's Avatar
You keep talking about getting the parts to make 35's fit, and always mention the tummy tuck. You do know you don't need a tummy tuck to make 35's work, don't you? As mentioned before a TT will require a new drive shaft, or two and adjustable control arms. You may be able to get on 35's with the lift you have and adding a body lift.
Jeffro06 is offline
post #48 of 587 Old 05-06-2012, 12:01 PM
AngryTJ
Originally Posted by Red93yj View Post
line up a 35 with one of your tires.see if it clears pretty good and go from there. i have a yj that has a 3 bl on it ant only rubbed sometimes with 33s. if anything try a 1inch body lift,with 35s
Whatever you do please dont run a 3in bl
Originally Posted by gspup View Post
Looks good. But don't even worry about the steering until you start getting into rocks. It will give you $500 to use elsewhere on your build.
You will know when you need a beefier steering setup. Until then stock will be fine.
I respectfully disagree. If you plan to come to Rausch with us it is like 85% rocks so I highly recommend a steering upgrade.
With a rubicon tcase you cannot fit a ucf ultra high clearance skid without a minimum 1" BL and lopro mount. It simply is to big and will not fit. If you want to make it easier on you get the extra clearance skid that requires 1" bl only. Still provides lots of clearance compared to stock.
EDIT* And like jeffro said you will need adjustable control arms to set your pinion angle if you do a tuck
AngryTJ is offline
post #49 of 587 Old 05-06-2012, 12:31 PM
gspup
Fair enough, Colorado is 100% rocks and I won't upgrade steering until I bend it. But it is a great upgrade.
And it looks like you can almost fit 35's, if not a 1" BL should clear them and you can setup bump-stops accordingly.
gspup is offline
post #50 of 587 Old 05-06-2012, 01:14 PM
AngryTJ
very true, I just think its a great upgrade especially if upgrading to 35in tires
AngryTJ is offline
post #51 of 587 Old 05-06-2012, 01:25 PM Thread Starter
Hunter7158
Alright just got underneath the jeep in my driveway to try to decode the current lift. I have stock front UCAs, new lowers, adj. rear uppers, and new rear lowers. I found a chart on here to see how much lift you have by measuring coils. I believe it is a 3" but the 31" tires make it look like more. I have so much room. Thanks angrytj about the extra clearance. I'll change my plans accordingly. I guess I'm asking. How should I spend my money to best outfit my jeep. Buy a whole different lift to replace the worn out lift? Piece it out?
post #52 of 587 Old 05-06-2012, 01:29 PM
Jeffro06
Jeffro06's Avatar
What makes you think the current lift is worn out?
Jeffro06 is offline
post #53 of 587 Old 05-06-2012, 01:37 PM Thread Starter
Hunter7158
Alot of squaek coming from the rear. probably shocks. Just so overwhelmed with what route I should take. If it is a 3" suspension lift. Should I go 1" BL, 1" MML , Driveshaft, TT while im at it and throw on 35's? I want to wheel it as it sits now. So angryTJ and KevKaos can help me diagnose my current lift. See what I want to upgrade and what I can wait on. and just get alot of opinions in person. AngryTJ and my jeep are basically twins. And I want to put on 35's like him. So I think wheeling with him will help me make up my mind...
post #54 of 587 Old 05-06-2012, 02:12 PM
AngryTJ
You just need to determine what order you want to do upgrades and how your budget will allow it. You have a lift so if you want get some tires and just come wheelin before spending any money.
AngryTJ is offline
post #55 of 587 Old 05-06-2012, 03:08 PM
Jeffro06
Jeffro06's Avatar
Yep. Buy your 35's, adjust from there.
Jeffro06 is offline
post #56 of 587 Old 05-06-2012, 04:33 PM
gspup
Exactly.
gspup is offline
post #57 of 587 Old 05-07-2012, 06:22 PM Thread Starter
Hunter7158
Alright. Here is what I'm working with suspension wise and armor wise. PO put on engine skid. Warn differential skids. Looks to be a 3" or 4" suspension lift. And a pro comp steering stabilizer.
image-1469639706.jpg   image-3154054468.jpg   image-667729702.jpg   image-2507019055.jpg   image-2934580545.jpg
post #58 of 587 Old 05-07-2012, 07:25 PM
KevKaos
Ok hunter, where to start? We chatted in text already but lets recap based on what we see here. Like I said earlier, armor up. That the best advice I ever got, but it took awhile for it to set in with me. The good news is that you already have an engine skid, and it is tied into your belly skid. Man, I forgot how far down those stock skids hang. The best news is that since your skids are tied together like that, you won't have the same shovel effect as if they were not tied together. You will want a gas tank skid, but who am I to talk, as I don't have one yet. If you are thinking of doing a BL at some point, you might want to hold off on the gas tank skid in hopes that you may be able to raise it up a bit more. AngryTJ has a nice tank skid you should check out. I noticed that you don't have a steering box skid, so that's a cheap upgrade you can do now. If it were me, and you really think you are going to be into wheeling (of course you will) you should look at getting a rear bumper with a recovery point. If you are unsure exactly what you want to do for bumpers long term, I would look online (used or new cheap) for a basic bumper with either D rings or a trailer hitch receiver. I have a Warn bumper that has a hitch receiver. Then I bought a Harbor Freight recovery point that slots into the receiver. Works great. BTW, I mention the recovery point as a priority because I believe that all vehicles being used at Rausch are supposed to have recovery points.
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #59 of 587 Old 05-07-2012, 07:43 PM
KevKaos
If you actually have 3-4 inches of lift, there is a good chance that the previous owner already put in a double Cardan driveshaft. If not, one is likely needed. Do a search door double Cardan driveshaft to see one, but the quick way to tell is if you have two universal joints, you DON'T have a double Cardan, but if there are three univsal joints, you DO. It will make sense once you look at one. I have what I think are some good pics from when I did mine on my build thread. The thing to keep in mind is that if you are going to be doing a MML, a BL, and a really shallow TT, all those things can make a difference in your driveline angles. It looks like you have aftermarket rear control arms, so you should be able to adjust your pinion angle.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #60 of 587 Old 05-07-2012, 08:01 PM
KevKaos
Lu raised a good point on the steering. I would look into upgrading your steering to either the way cheaper ZJ setup, or the more expensive Currie steering setup. You could go for the even more expensive Ultimate steering setup. We can talk about the pros and cons of each, but if you are going to play in the rocks (which is most of what we do here on the east coast) you will probably want upgraded steering sooner rather than later. Ask me how I know. And now that I think about it, there are a coup,e other things you can do in regards to steering.
Also in the category of ask me how I know, upgraded axles shafts.
And lastly, to everyone seeing all my multiple postings in a row and wondering who the heck does this clown think he is. I'm nobody special. It's just that Hunter texted me and we had a long conversation which via text is kind of hard and I am just filling in the gaps of our conversation.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
