2006 Rubicon First Jeep - Page 14 - JeepForum.com
 1Likes
post #196 of 587 Old 10-10-2012, 07:44 AM Thread Starter
Hunter7158
Yes so glad I went straight to 35s. I got new wheels too and backspacing 3.75. So no rubbing. More pics to come and still a long list of things I need to do. Thanks for watching.
Hunter7158 is offline
post #197 of 587 Old 10-11-2012, 05:48 AM Thread Starter
Hunter7158
Some more pics from the side. These pics don't do it justice. It looks so badass. Will get some more better pics later.
post #198 of 587 Old 10-11-2012, 09:16 AM
bmosing
Very sharp looking man
Now go wheel that B****!!!!
My Jeep:
bmosing is offline
post #199 of 587 Old 10-11-2012, 09:24 AM Thread Starter
Hunter7158
Thanks man I'm so excited.
post #200 of 587 Old 10-13-2012, 06:12 PM Thread Starter
Hunter7158
Retapped a cross threaded body mount bolt. And got that all fixed and torqued today. Also ordered new 33 tooth speedo gear and O ring. And new fuel filler hose the 15131046 GM hose so it doesn't overflow when refueling. Just need it longer because my body lift. Still selling rocker guards. Still looking for lug nuts and center caps also.
post #201 of 587 Old 10-13-2012, 07:35 PM
Scotts05Rub
Are you sure the 33 tooth speedometer gear is what you want... The rubicon speedometerm is electronic and dosnt use the gear like a normal tj...
Scotts05Rub is offline
post #202 of 587 Old 10-13-2012, 08:01 PM Thread Starter
Hunter7158
Uhh. Didn't know that. Back to the drawing board.
post #203 of 587 Old 10-16-2012, 07:37 AM Thread Starter
Hunter7158
Thanks for such a quick response. I only did a little research. And all I found was on the TJs themselves not rubis. But I canceled the order in time. And now know about the rubis using electronics for the speedo. So that's lower on my priority list. Got a new fuel tank filler hose with the flapper valve ordered so I can cut this one longer so the cap will fit on with the BL. Still looking for lug nuts and wheels.
post #204 of 587 Old 10-31-2012, 11:20 AM Thread Starter
Hunter7158
No major updates. Hurricane sandy just came through and I've been running a bunch of calls at the firehouse. Put on the new fuel filler hose and cut to size so that's all buttoned up. Now figuring out what route to go with my front driveshaft rebuild. Will this work ? http://www.dennysdriveshaft.com/p108...reaseable.html
post #205 of 587 Old 10-31-2012, 11:23 AM
jeepinhokie
i believe that is the exact kit I used to rebuild mine. Keep in mind you will need one more 1310 Spicer U-joint to complete the rebuild.
HOKIES UNITED!
jeepinhokie is offline
post #206 of 587 Old 10-31-2012, 11:49 AM
STRATTON
nice ride bro ! looks great.
cant wait to do 35s myself when my 33s wear down.
stratton.
STRATTON is offline
post #207 of 587 Old 10-31-2012, 11:55 AM
jeepinhokie
a buddy of mine has a 05 or 06 LJ Rubicon with a Speed-o-healer installed. he said the install was very simple and he was able to calibrate his speed perfectly.
look into it
HOKIES UNITED!
post #208 of 587 Old 10-31-2012, 07:00 PM
06moneypit
I have a speedo healer and REALLY wish I did it sooner on my 06 Rubi. Beyond simple install and really easy to calibrate. Just pay attention to where the decimal place is. That messed me up the first time and cause the jeep to cut out.
Mark
06moneypit is offline
post #209 of 587 Old 10-31-2012, 07:04 PM Thread Starter
Hunter7158
It's on the list. Thank you guys for following my build means a lot. Took out the front driveshaft this afternoon so I can rebuild it soon. Adjusted my park brake so leaving it in gear is not a necessity. Want to do the speedo healer. And new bumpers and tire carrier combo.
post #210 of 587 Old 10-31-2012, 07:15 PM
jeepinhokie
One thought about the u-joint kit. Does the rubicon use a different front output yoke.
HOKIES UNITED!
