2005 LJ Rubicon Build: Daniel's money pit - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 2005 LJ Rubicon Build: Daniel's money pit
Borla Exhaust presents "Climber" at EJSTactical Recovery Equipment Soft Shackles!!!Ring & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 06-04-2014, 10:51 AM   #1
Ljcrawler05
Well after a year and a half of spending and modding I reckon it's time for a build thread... To start off I'll tell you a little bit about my background and Jeep timeline. When I turned 16 I got a 2003 Jeep Wrangler x, which is where the Jeep bug first bit me. I gave it a budget boost and 33's and quickly found out that there was a lot more to the Jeep than just throwing big tires on it. I kept it basically in this form other than some bumpers and other random items until I got rid of it for my current vehicle, which is a 2005 LJ Rubicon in the red flavor. When I got it, from my father, he had done a budget boost in the rear and ome 933s up front with OME shocks and a smittybilt winch, xrc bumpers front and rear, and smittybilt sliders, aluminum radiator, e-fan. It's had 33's on it since either me or him have owned the vehicle(40k miles) and has been a great vehicle for me to learn a little in the off-road world and also get me to NCSU for school and back home.
I have thoroughly enjoyed working on it and making it a more capable rig both on and off the pavement. So I guess let's get down to what I have done to the Jeep since the title has been in my name.
I have added the following things to the Jeep, not in this order necessarily, over the last year and half.
Savvy Under Armor
Metalcloak Upper control arms
Metalcloak Rear adjustable track bar
Tom Woods Rear Driveshaft
OME 934/949 Springs
Currie Anti-rock
ZJ V8 Tie-rod
Replacement Moog front trackbar
Drilled and slotted rotors(Was a gift) and upgraded pads
Spidertrax Wheel Spacers
Custom exhaust work to clear tummy tuck
CB Radio
That's all I can think of at the moment, but will update with any further modifications...
What's on the docket...
This friday I will be dropping the Jeep off to have some HD lower control arm mounts welded onto the front axle since I crunched one of them wheeling. I will have the metalcloak lowers installed at the same time as this.
Future Plans:
Metalcloak armor (painted to match vehicle, and will likely have the whole Jeep sprayed at this time
Savvy GTS
Savvy oil pan/engine skid
Chromoly front/rear shafts
35" tires w/new rims (preferably Hutchinson Rock Monsters in argent)
Possible regear to 4.56 if necessary
Eventually:
Hemi Swap
10369190_790797890945082_666748125638189973_n.jpg   1509788_750592058298999_1671900808_n.jpg   1920190_736313536393518_653052129_n.jpg   1512742_716530171705188_775644745_n.jpg
Ljcrawler05 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2014, 02:01 AM   #2
Jeep_Porn
Junior Member
Looks great but could really use though 35's! Keep it up though
Jeep_Porn is offline   Reply With Quote Quick reply to this message
Unread 06-05-2014, 02:10 AM   #3
Ljcrawler05
Thanks, and don't tempt me on the 35s... I'll be getting a new set of tires just don't know what yet. Probably gonna be mtr/k but not sure on 33 or 35s. Don't think I could get away with 35s with the current fenders
Unread 06-06-2014, 10:07 PM   #4
Ljcrawler05
Well had the metal cloak lowers installed along with the hd lower control arm mounts and all is well. The metal cloak arms take so much more of the vibrations from bumps and dips than the stock ones did. Totally different ride quite honestly and that was just with the addition of the front lowers.
Seems I'm now going to have to have another alignment done because it's pulling to the left and I've got a slight wobble and it's only gonna get worse until I straighten that out. Will post pictures tomorrow
Unread 02-24-2015, 08:10 PM   #5
Morethrottle88
Awesome LJ man. Keep it up. I'm about to start my build very soon.
Morethrottle88 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2015, 08:37 PM   #6
Ljcrawler05
Thanks man, totally forgot about this thread. I've done a little bit to it since this last post, but not too much.
