2004 LJ Rollover - Page 11 - JeepForum.com
post #151 of 295 Old 05-24-2011, 07:29 AM Thread Starter
jermeyg
Originally Posted by little_Jeep View Post
Sure doesn't look like 12 psi.
Yeah, I will try a little lower next time.
jermeyg is offline
post #152 of 295 Old 05-24-2011, 07:38 AM
little_Jeep
12 psi is pretty low for a non bead locked tire. Are you sure your gauge reads correctly? If you have air supply, you could try a little lower, if you pop a bead, you went too low
little_Jeep is offline
post #153 of 295 Old 05-24-2011, 07:48 AM Thread Starter
jermeyg
I aired down one tire with my guage to 12psi and then a friend let me borrow their tire deflators set to 15psi so i put them on all four tires. The one I did myself didn't release any air. So I thought I was at 12psi according to my gauge. I then deflator each tire to 12psi after the tire deflators were done.
I will pay more attention and double check with another gauge next time for sure.
jermeyg is offline
post #154 of 295 Old 05-24-2011, 07:56 AM
little_Jeep
It could just be my old eyes.....
post #155 of 295 Old 05-24-2011, 09:23 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Jermey,
Get an Currie or ARB deflator they seem to work the quickest and are pretty accurate. I think you know a guy you can get one from. LOL!
G
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #156 of 295 Old 05-24-2011, 09:34 PM
IEcrawlerTJ01
12 is not low for non beadlocked
I run 8psi on 35s with no beadlocks
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #157 of 295 Old 05-24-2011, 09:35 PM
Imped
Imped's Avatar
Nice pics man, I love that little rock garden. Try Purgatory yet? And yeah, air those things down to 8 and break them in good. The sidewall should bulge quite a bit more after that.
So, you gonna be making it to Attica any time in June?
OlllllllO
IndyORV
Imped is offline
post #158 of 295 Old 05-25-2011, 07:42 AM Thread Starter
jermeyg
Originally Posted by Savvy View Post
Jermey,
G
G, I am going to get my staun tire deflators and have them preset to 8psi. I have the ARB defator/gauge but its no fun waiting on each tire to get it right. I want to just hook it up and walk to the next one
Okay sounds like I need less pressure.
Dude, we did everything there. Spent the better of a full two days just wheeling the entire place. It was fun. I had a couple issues making up a few things, like the second steep wall near the creek. I was thinking it was tire pressure so I will try some lower air pressure and see what happens.
I would love to come out with you guys but we have a trip in Drummond in Juen and I have a wedding to attend I think the same weekend as you guys are going.
Should be making another trip out there in the fall though. Are you guys going anytime after June?
jermeyg is offline
post #159 of 295 Old 06-22-2011, 08:10 AM Thread Starter
jermeyg
Just got back from Drummond Island, MI and we had a good time.
jermeyg is offline
post #160 of 295 Old 07-15-2011, 12:53 PM Thread Starter
jermeyg
Need some help/advice
I recently starting getting a shimmy in my steering wheel at around 50mph and I thought it is related to my wheels out of balance again. I decided to first to check and see if all the bolts are tight since it started sometime after off roading. Well, I got everything all tightened up (nothing was really loose) and still had the shimmy.
Figuring its the tires I swapped front to rear and rear to front. I still had the shimmy. I did a steering check with a helper and looked for any abnormal movement and nothing seemed to be out of wack.
Then took my channel locks and clamped each tie rod end to see if there is any movement. I noticed that the draglink tie rod end on the steering knuckle had twice as much up and down movement than any of the other ends. I am not sure if this is my cause of shimmy or is that up and down movement normal. I can made a small video if that helps.
jermeyg is offline
post #161 of 295 Old 07-30-2011, 02:17 PM Thread Starter
jermeyg
Update, I have really figured out my shimmy issue yet. I came across another problem involving a crack Evap line so I had to fix that. I also got a Winch which I am really excited to use. I'll post up some pictures of it and a review of it.
jermeyg is offline
post #162 of 295 Old 07-30-2011, 02:53 PM
all_clear
Double check your wheel weights again. I was having issue with mine tossing a weight here and there too. Causing a shimmy/shake (not DW). A rebalance helped each time.
Did the rebalance on the DS get rid of the vibes? I have all new stuff to rebuild my front shaft and hoping that fixes mine.
2004 Jeep Wrangler, Auto Trans, LEDs throughout, 3" Lift, 35" MTZ's
Check out my official RE-build thread. Her name is Ilene
all_clear is offline
post #163 of 295 Old 07-30-2011, 03:28 PM Thread Starter
jermeyg
Yeah, I tried swapping wheels front and back to see if it would get rid of my shakes and it didn't. I got the DS back and there seems to be a slight vibe I get at around 45MPH but nothing else notable at higher speeds. I have a plan of action I think.
1. Make sure everything is tight...again
2. Perhaps play the pinion game in the front.
3. If nothing helps I make look into the front wheel bearings. I can't see any movement in them but it doesn't help that they have 100k on them either. Maybe they are on there way out?
Let me know if you get your vibes fixed as well. Seems like an impossible task...
jermeyg is offline
post #164 of 295 Old 07-30-2011, 03:39 PM
B52dude
Hey man, great build! A quick question, if you don't mind-- Where did you get the axle mounts for your front sway bar links? JKS makes some, but they don't look as strong as yours do.
Originally Posted by Ripper3494 View Post
i think we should chase him around with yjs, its like being chased by zombies, slow, crippled but for some reason still scary as heck lol
Red Jeep Club #614
B52dude is offline
post #165 of 295 Old 07-30-2011, 04:01 PM Thread Starter
jermeyg
Hey there, these are made by mr.blaine on the forum. Check out his site at http://shop.blackmagicbrakes.com/Rai...Mounts_c40.htm
jermeyg is offline
Rollover damage tavopunk Jeep Picture Requests 21 10-17-2013 09:54 AM
2001 TJ purchased after rollover drcustom Jeep Builds 7 09-24-2009 09:34 AM
Can I see some rollover pics? bigV Jeep Picture Requests 66 07-21-2008 04:31 AM
Roll Cages AFTER a rollover wenkebach Jeep Picture Requests 43 10-23-2006 03:38 PM
rollover pics strangler95 Jeep Builds 20 02-11-2005 09:28 AM
