2003X TJ Build !! - Page 55 - JeepForum.com
post #811 of 1158 Old 03-17-2012, 05:23 PM
djflyy
That rig is BEGGGGGGGGGGING to be wheeled.
Let's get to it.
djflyy is offline
post #812 of 1158 Old 03-17-2012, 06:34 PM Thread Starter
2003X
Let's get to it.
I know she is. The weather is supposed to be awesome this week as well.
My Build
2003X is offline
post #813 of 1158 Old 03-22-2012, 03:12 PM Thread Starter
2003X
My front diff cover has been leaking for some time now from the fill plug. I went out and got pipe joint compound. But first I went heavy on the plug with plumbers tape to try and stop the oil from leaking out. I used the tape before but not as heavy as today. So far today no leak.
My Build
2003X is offline
post #814 of 1158 Old 03-22-2012, 03:14 PM Thread Starter
2003X
Great pic.
My Build
2003X is offline
post #815 of 1158 Old 03-22-2012, 03:17 PM Thread Starter
2003X
Plasti-Dip my front grill and half of the front fenders with a flat black. I also hit the head light rings and guard. I used one can and probably went with 7 coats maybe a few more about 10 minutes apart. It was hot out today, 80 degrees, so it dried very fast and even. I cleaned the paint very good with Rustoleum's Wax and Tar remover. Started with some light coats then went to medium. The tip started to spit a little, shook it good, sprayed another top coast and it all dried evenly. The hardest part was getting into the slots of the grill with the winch and KC's. One tip is to pull the painters tape off after the last coat. The paint will stick to it pulling it apart a bit. After I realized this, I ran a small blade across the edge of the tape to separate it leaving a clean line. I am so pleased with the results.
My Build
2003X is offline
post #816 of 1158 Old 03-22-2012, 03:18 PM Thread Starter
2003X
Finished;
My Build
2003X is offline
post #817 of 1158 Old 03-22-2012, 03:23 PM
bobthetj03
That looks pretty darn good! Matches your flares real close! It's all the rage these days, plasti-dip that is.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #818 of 1158 Old 03-22-2012, 03:32 PM Thread Starter
2003X
It looks awesome in person. I am thinking of possibly doing the flares, because they need to be painted again.
My Build
2003X is offline
post #819 of 1158 Old 03-22-2012, 03:43 PM
bobthetj03
How well do you think it'll hold up to impacts typical with the front end of said Jeep? As well as say spray on bed line, ie Rustoleum?
Bob's boring build:
post #820 of 1158 Old 03-22-2012, 04:06 PM Thread Starter
2003X
Not sure, but it does feel tough. I am going to test it though and post the results here. Only $6 for a can. Whats nice is, you can pull it all off in one swoop if you don't like it because it is not permanent.
My Build
2003X is offline
post #821 of 1158 Old 03-23-2012, 09:06 AM
SaxManClay
I'll throw a brick at it. Good thing my aim sucks.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #822 of 1158 Old 03-23-2012, 11:56 AM
djflyy
Fastest way to lose a friend/famous last words.... "I'll throw a brick at your Jeep".
djflyy is offline
post #823 of 1158 Old 03-23-2012, 02:15 PM Thread Starter
2003X
Lol
My Build
2003X is offline
post #824 of 1158 Old 03-26-2012, 10:08 PM Thread Starter
2003X
Ordered new front parking lamps. Mine are cracked and faded, and the previous owner had drilled two large holes in them for strobes. I also ordered a 12" AMI Stubby antenna to replace the 30 + inch stock antenna that ruined my KC lights.
My Build
2003X is offline
post #825 of 1158 Old 03-27-2012, 08:30 AM
djflyy
Man I've wanted to grab one of those from AntennaX. The look B.A.
djflyy is offline
The Build! XJWren Jeep Builds 17 07-23-2014 11:27 PM
88 XJ Build up Giviner Jeep Builds 10 09-09-2009 10:20 PM
My TJ Build TellicoTJ Jeep Builds 7 01-08-2009 02:40 AM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
