2003X TJ Build !! - Page 51 - JeepForum.com
post #751 of 1158 Old 01-24-2012, 10:08 PM
iansavesday
Originally Posted by 2003X View Post
Pictures from 2005 in New Hampshire:
where is this in NH?
iansavesday is offline
post #752 of 1158 Old 01-24-2012, 10:19 PM Thread Starter
2003X
That was around Laconia NH.
My Build
2003X is offline
post #753 of 1158 Old 01-26-2012, 02:30 PM Thread Starter
2003X
Crown Automotive D-Ring Rubber Isolators arrived today from Quadratec.
My Build
2003X is offline
post #754 of 1158 Old 01-28-2012, 04:43 PM Thread Starter
2003X
D-ring isolators. They D-rings no longer bang around.
ForumRunner_20120128_174256.jpg   ForumRunner_20120128_174308.jpg   ForumRunner_20120128_174320.jpg
My Build
2003X is offline
post #755 of 1158 Old 01-28-2012, 05:04 PM
djflyy
Quite the mod.
djflyy is offline
post #756 of 1158 Old 01-28-2012, 07:55 PM Thread Starter
2003X
Originally Posted by djflyy
Quite the mod.
The banging off the bumper really bothered me.
My Build
2003X is offline
post #757 of 1158 Old 01-28-2012, 09:35 PM
bobthetj03
That would bug me too! Nice touch!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #758 of 1158 Old 01-30-2012, 09:13 AM
djflyy
I know exactly what you mean
We gotta meet up soon and chill/wheel/wrench
djflyy is offline
post #759 of 1158 Old 02-01-2012, 04:17 PM Thread Starter
2003X
For the last few days my KC's have not been working. I checked the switches, no power. Checked all the fuses all the way back to the battery, none were blown. I was stumped for a bit. I then checked the battery and noticed the main power wire that powers the switches broke free. I re-connected it and now all the KC's are working.
My Build
2003X is offline
post #760 of 1158 Old 02-03-2012, 05:49 PM
fdkss03
How troublesome was your LA upgrade?
I am doing mine tomorrow, and already have the 4" X-Flex kit, just want the better ride on the street, the 4" X-Flex SA lift is killer on the trail for what I do...
Do you really have to drop the springs and all if you already have 4" springs in there? I was reading the directions and it seemed thats if you dont have a lift at all.
#SavvyUp
#MCEFenders
#ClaytonOffroad
fdkss03 is offline
post #761 of 1158 Old 02-03-2012, 06:10 PM Thread Starter
2003X
No reason to take the springs out. If your only adding the long arms, just cut the stock brackets off and bolt up the new bracketry. Hardest part is just cutting the stock mounts off. Make sure you have the correct drill bits before you start. The holes for the large mount are a decent size. You will love the long arms, it rides so much better then their short arm kit. Always make sure you support the axle before removing the arms, it will slide away from you.
My Build
2003X is offline
post #762 of 1158 Old 02-03-2012, 10:05 PM
fdkss03
exactly what I thought...but had someone preaching to me saying they did the kit and HAD to take them out... i can see if its a different height or whatever, but not just the arm change.
im thinking of installing the center brackets first, then doing it one arm at a time.
#SavvyUp
#MCEFenders
#ClaytonOffroad
fdkss03 is offline
post #763 of 1158 Old 02-04-2012, 09:24 AM Thread Starter
2003X
Yes, Drop the skid plate, cut it to fit around the bracket then bolt it up with the skid plate, cut the brackets off, and adjust your new long arms. , Again just make sure you take correct measurements while its on the ground, or go by RC's measurements in the directions, but make sure you support the axles on jack stands. I was adjusting a rear lower arm and I was doing it just on the pavement, and the rear axle slipped away. What a PITA to try and push it back so I could get the bolt thought the joint.
My Build
2003X is offline
post #764 of 1158 Old 02-15-2012, 10:09 AM Thread Starter
2003X
Haven't done much lately.
My Build
2003X is offline
post #765 of 1158 Old 02-15-2012, 10:19 AM
bobthetj03
Pretty much the general concensus for most of us lately! I think most are waiting for the eagle to poop!
Bob's boring build:
The Build! XJWren Jeep Builds 17 07-23-2014 11:27 PM
88 XJ Build up Giviner Jeep Builds 10 09-09-2009 10:20 PM
My TJ Build TellicoTJ Jeep Builds 7 01-08-2009 02:40 AM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
