2003X TJ Build !! - Page 46 - JeepForum.com
post #676 of 1158 Old 12-06-2011, 10:11 PM Thread Starter
2003X
The Aussie is a seriously easy install.....took me two hours from start to finish on my first one. No reason to wait so long or even be afraid.
I wasn't sure what was involved with removing the carrier, ect. I read numerous threads on Aussie installs. Then someone on here said with 4.88s you have to "trim" the gear teeth to make the Aussie fit. Then I was told that was not true.
Now I have a couple buddies that will lend a hand with the install which makes me feel better about it.
My Build
2003X is offline
post #677 of 1158 Old 12-07-2011, 09:44 PM Thread Starter
2003X
Undercover Fabworks is offering 25% off all diff covers, so I ordered a D30 and Ford 8.8 cover for $152 shipped. Couldn't pass this deal up.
My Build
2003X is offline
post #678 of 1158 Old 12-08-2011, 10:32 PM Thread Starter
2003X
We had alot of rain here over the last three days, and my rear window on my hard top is leaking. It looks like the water is coming in on the corners of the rear glass and running along the side of the tub and down onto the rear floor pans. A big PITA. I have the rear carpet out and drying in my house.
My Build
2003X is offline
post #679 of 1158 Old 12-12-2011, 07:34 PM Thread Starter
2003X
Took her out to do some XMas shopping.
My Build
2003X is offline
post #680 of 1158 Old 12-12-2011, 08:32 PM Thread Starter
2003X
After I had my A/C installed, the A/C compressor was rubbing on the lower radiator hose. I checked it earlier this week and noticed it has been rubbing through the rubber. I checked various stores in my area for some kind of hose wrap, but came up empty. I searched tonight and ordered this: http://www.heatshieldproducts.com/productdetail/thermal-and-heat-protective-sleeving/hp-hose-sleeve/59/23 It is radiator hose wrap from Heat Shield Products. I just needed something to stop the compressor from rubbing on the hose.
My Build
2003X is offline
post #681 of 1158 Old 12-12-2011, 08:49 PM
rebolc
cool!
rebolc is offline
post #682 of 1158 Old 12-15-2011, 02:31 PM Thread Starter
2003X
Undercover Fabworks HPD30 and Ford 8.8 covers. These are solid and come with hardware.
My Build
2003X is offline
post #683 of 1158 Old 12-15-2011, 03:05 PM Thread Starter
2003X
Also recieved the radiator hose protector.
My Build
2003X is offline
post #684 of 1158 Old 12-17-2011, 07:09 AM
djflyy
Will that rear skid clear your gas tank at full flex? And the front clear your track bar? They look awesomely beefy, but also exceptionally bloated.
Glad you got a good deal at least
djflyy is offline
post #685 of 1158 Old 12-17-2011, 11:12 AM Thread Starter
2003X
Yea, I checked with UCF before ordering, and he stated his D30 cover is no bigger then the stock one and will have no issues with the Currie Steering or RC track bar. The 8.8 will work just fine, I talked with others who run it, no issues. I like the look of the welds, and I didn't want a cover that had a companies name on it, I like this look better.
My Build
2003X is offline
post #686 of 1158 Old 12-17-2011, 01:30 PM Thread Starter
2003X
Installed the radiator hose cover to stop it from rubbing against the A/C compressor. Drained the radiator and then re-filled it.
My Build
2003X is offline
post #687 of 1158 Old 12-24-2011, 09:42 PM Thread Starter
2003X
My Fiance got me a $100 gift certificate to Quadratec for my BDay today. I will more then likely use it towards a locker on there.
My Build
2003X is offline
post #688 of 1158 Old 12-24-2011, 10:07 PM
Nosights
Dear OP-
Where do the "Big Axles and Big Tires!" come in? I see it in your signature...just curious.
"Fender flairs"? Really? I'll let a combination of my sawzall, plasma cutter and hammer take care of the clearancing.
Nosights is offline
post #689 of 1158 Old 12-24-2011, 10:48 PM Thread Starter
2003X
Originally Posted by Nosights
Dear OP-
I dont know? I mean, is that joke or a serious question.
I consider the 8.8 a big axle, and 35" tires a big tire.
I see you have D60's, so im sure you consider that to be a big axle.
My Build
2003X is offline
post #690 of 1158 Old 12-25-2011, 05:28 AM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
Keep up the good work!
MERRY CHRISTMAS!!!!!!!
My newest build:
Necromancer_tat is offline
The Build! XJWren Jeep Builds 17 07-23-2014 11:27 PM
88 XJ Build up Giviner Jeep Builds 10 09-09-2009 10:20 PM
My TJ Build TellicoTJ Jeep Builds 7 01-08-2009 02:40 AM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
