2003X TJ Build !! - Page 45 - JeepForum.com
post #661 of 1158 Old 11-17-2011, 08:30 AM Thread Starter
2003X
Originally Posted by SaxManClay
This is what I would do if I were you.
-Use a thicker oil to "stop" your leak.
-Save your pennies, and then do a stroker swap.
Honestly, I think you spent more on your axles then you would to swap in a new engine. I saw on Steve's Jeep Country that he would install a Stroker for only $500, which is an absolute steal.
I am going to try the thicker oil first.
My Build
2003X is offline
post #662 of 1158 Old 11-17-2011, 12:13 PM Thread Starter
2003X
I am having a member on Wrangler Forum make a smaller Hi-Lift mount for my rear roll bar. It is going to be a 2.25", 2 piece clamp-on shaft collars from McMaster-Carr. He will drill and tap to accept a bolt. Add washers, lock washers and nuts. $75 shipped. The clamps alone are $14/piece plus shipping and the washers, nuts, ect. My current 4" muffler clamps work great, but sometime when I fold the soft top up/down, it will get stuck on one side.
This is how it will look:
My Build
2003X is offline
post #663 of 1158 Old 11-17-2011, 02:36 PM
evolution
looks good but what holds the other side? one clamp?
97 TJ, custom long arm, custom tri link rear, 44 front-9in rear, Detroit and Yukon lockers, 4:88s, 37" bfg's ,tube fenders and crusher corners, process never ends...
evolution is offline
post #664 of 1158 Old 11-17-2011, 02:46 PM Thread Starter
2003X
Yes. PM'd you the pic.
My Build
2003X is offline
post #665 of 1158 Old 12-02-2011, 02:20 PM Thread Starter
2003X
Received the homemade Hi Lift mounts today. Install pics to follow. Had them made by a member on Wrangler Forum. They are a 2.25", 2 piece clamp-on shaft collars from McMaster-Carr. He drilled and taped to accept a bolt. Add washers, lock washers and nuts.
How they look?
My Build
2003X is offline
post #666 of 1158 Old 12-03-2011, 01:06 PM
djflyy
Look good! How much did you pay for them? I'd be interested to see cause I'd like to get over bending my soft top frame to get it up around the exhaust clamps I've currently got going
Can you make the trail run on Dec 10?
djflyy is offline
post #667 of 1158 Old 12-03-2011, 02:30 PM Thread Starter
2003X
They were $75 shipped. The guy on wrangler forum ordered them and pressed the screws into them. He sent me all the prices of it broken down. He only charged me $20 to do it, the rest was parts and shipping. I like them alot, I will put them under the padding so you cant see them.
No, I wont be able to make it next saturday.
My Build
2003X is offline
post #668 of 1158 Old 12-04-2011, 04:24 PM
SaxManClay
I'll help you install your Aussie if you need to. I have experience removing a power trax from my D35 carrier, so installing one shouldn't be a problem.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #669 of 1158 Old 12-05-2011, 05:13 PM Thread Starter
2003X
The more help the better. I don't know what I am doing, and didn't feel that comfortable removing the carrier for the install.
It will either be right after XMas or the spring time.
My Build
2003X is offline
post #670 of 1158 Old 12-05-2011, 05:18 PM
Meep97
2009 JK Wrangler
Have you installed you Hi-lift and mounts yet? Pics?
Meep97 is offline
post #671 of 1158 Old 12-05-2011, 05:40 PM Thread Starter
2003X
No not yet. Havent had time, I hope to get them in this week.
My Build
2003X is offline
post #672 of 1158 Old 12-06-2011, 12:58 PM Thread Starter
2003X
Got some Bosh Micro Edge wiper blades and glass cleaner wipes. Also - I wanted to install the hi lift mounts today, but noticed that under my roll bar padding, there is thick plastic foam. I have to re-think the install now.
My Build
2003X is offline
post #673 of 1158 Old 12-06-2011, 05:25 PM
djflyy
Cut the foam off from the point you want to install it and below. The only reason that padding is there is so that when you roll over/crash, your passengers heads are padded from the steel roll bar. It won't matter not having it in the back lower portion.
djflyy is offline
post #674 of 1158 Old 12-06-2011, 07:58 PM Thread Starter
2003X
Cool, I am going to wait for a day when I got enough time to work on it.
My Build
2003X is offline
post #675 of 1158 Old 12-06-2011, 08:09 PM
Imped
Imped's Avatar
The Aussie is a seriously easy install.....took me two hours from start to finish on my first one. No reason to wait so long or even be afraid.
OlllllllO
IndyORV
Imped is offline
The Build! XJWren Jeep Builds 17 07-23-2014 10:27 PM
88 XJ Build up Giviner Jeep Builds 10 09-09-2009 09:20 PM
My TJ Build TellicoTJ Jeep Builds 7 01-08-2009 01:40 AM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
