2003X TJ Build !! - Page 16 - JeepForum.com
post #226 of 1158 Old 03-07-2011, 03:30 PM
tangotag
Great build thread.
I saw you post on the Street Side Auto pricing of the Rock Sliders shipped. I had to order a pair now that they are now re-stocked the same discount code still worked too. Having free shipping sweetens the deal even more. I got a Warn M8000 from them for a good price a few months back too.
Nice install pictures on the rockers. I for sure will cut a 2x4 for my floor jack to help install.
Any other tips, suggestions, afterthoughts for someone looking to install those rockers?
tangotag is offline
post #227 of 1158 Old 03-07-2011, 05:31 PM Thread Starter
2003X
Originally Posted by tangotag View Post
Great build thread.
Nice install pictures on the rockers. I for sure will cut a 2x4 for my floor jack to help install. Any other tips, suggestions, afterthoughts for someone looking to install those rockers?
They are awesome, very solid for the price. Have 2 people, it helps when some one is holding the rocker while you squoosh it between the tub. Soak the 3 body bolts good with WD-40, a large breaker bar helped a lot to loosen the bolts. It tells you to cut 3/16" off the stock rubber bushing, I didn't do it, and didn't notice a difference. I found it easier not to remove the bolts completely, just enough to slide the panel in between the tub and bushing. Also in the directions it will tell you that on each side, one bolt may be tough to get too and will require a 1" hole saw. In my pics you can see where I had to cut the tub from the inside, I just used a dremel and larger drill bit, made the hole just large enough from the inside to get the nut and washer on. Just torque the body mount bolts to 30FT LBS when done. You won't be disappointed, any questions send me a PM, they go right to my phone.
My Build
2003X is offline
post #228 of 1158 Old 03-07-2011, 09:22 PM
07wurubi
07wurubi's Avatar
Here is a side shot of mine installed along with the rear corners and front tube fenders. Actually took this pic to show the UHC skid installed and the clearance it has now.
Mike Fox
My Jeep:
00 Wrangler Sport 4.0L NV3550
4" RC LA
Bilstein 5100 shocks all around
axles (30,8.8) with 4.88 gears ARB F/R
SYE and CV rear driveshaft from Drivelines NW
Currie HD steering (Thanks Savvy, Awesome customer service)
Savvy LED tail lights (Thanks again Savvy)
GY MT/R Kevlar 35x12.50x15 on 15x10 American Racing
Bestop soft top with tinted windows
Smitty front and rear bumpers w/rear tire carrier
Smitty XRC8 winch w/synthetic rope
Smitty rear corners and rock sliders with step
Genrite aluminum 6" tube fenders front/rear
Dodge Durango steering box with Pure Jeep skid and M.O.R.E. steering brace
07wurubi is online now
post #229 of 1158 Old 03-07-2011, 09:53 PM Thread Starter
2003X
Looks awesome, nice work. With that skid plate did you have to add a MML or anything?
My Build
2003X is offline
post #230 of 1158 Old 03-07-2011, 10:25 PM
07wurubi
07wurubi's Avatar
I ordered a mml at the same time. So did both when it went in. Already had a 1" body lift. Haven't really driven it much since putting it in. Have noticed more vibrations in the cab than before. Not sure if something is rubbing underneath being all tucked up tight or if the drive line angle is more than the CV can handle at the T/C. May end up needing to get a SS SYE instead of the standard SYE I have in there if it is drive line angle. Weather hasn't been the best lately so I haven't had a chance to get under there and really look up in the tunnel area for any kind of contact with anything to cause vibs. Mainly happens when coasting versus under power. Tranny noise is much more noticeable having it up in there more. Specially under light throttle while at speed. Hard to explain that one, really.
Mike Fox
My Jeep:
4" RC LA
post #231 of 1158 Old 03-08-2011, 02:38 PM Thread Starter
2003X
Attempted the paint one mirror and came out all blotchy, so I stopped.
My Build
2003X is offline
post #232 of 1158 Old 03-08-2011, 02:40 PM Thread Starter
2003X
One of the fan speeds stopped working, so I replaced the switch first and it didn't fix it. Going to replace the resistor now and see if that fixes it.
My Build
2003X is offline
post #233 of 1158 Old 03-08-2011, 02:41 PM Thread Starter
2003X
Was nice today so I cleaned her up and took a few photos.
My Build
2003X is offline
post #234 of 1158 Old 03-08-2011, 03:03 PM Thread Starter
2003X
more...
My Build
2003X is offline
post #235 of 1158 Old 03-15-2011, 02:17 PM Thread Starter
2003X
Replaced the blower motor resistor and got all my fan speeds back.
My Build
2003X is offline
post #236 of 1158 Old 03-16-2011, 10:02 AM
Tmblack3
I have the same problem, where did you get the resistor and how much?
04 TJ Sport- Kicker System, Smittybilt XRC-8 Winch, Cherry Bomb 18" Glasspack, 3" Zone Hydro Suspension Lift, 33x12.50 BFG KM2, 15x8 Procomp 7069, Aussie Locker front Dana 30, JKS 1.25" Body Lift, 4 100w Hella 500s
Tmblack3 is offline
post #237 of 1158 Old 03-16-2011, 12:23 PM
APEDZ04LJ
awsome build! couple questions for ya a) how hard was it to pull the shafts and knuckles for the hpd30? I have an lj and im looking at swaping the front to the hp but ive never done axle work, im def. gonna guy with ecgs so it bolts right up and less work for me
APEDZ04LJ is offline
post #238 of 1158 Old 03-16-2011, 01:00 PM Thread Starter
2003X
I just went right to the Jeep dealer, it was $30. You can get them online for about $20, but they are not the mopar brand.
My Build
2003X is offline
post #239 of 1158 Old 03-16-2011, 01:07 PM Thread Starter
2003X
Very easy to swap in a HPD30, the shafts slide right out once you unbolt everything. Getting the hubs off gave me a challenged because they were frozen on. I recommend renting a slid hammer from auto zone, it is worth it. Just take your time and soak everything with a good penetrating oil. You can see in this pic, one the knuckle is freed from the ball joints, it just falls down.
ECGS is awesome. Awesome service, and fast shipping.
My Build
2003X is offline
post #240 of 1158 Old 03-16-2011, 03:16 PM
APEDZ04LJ
ok can you anwser these also? Whats a u bolt yoke? whats lca and unit bearings?
The Build! XJWren Jeep Builds 17 07-23-2014 10:27 PM
88 XJ Build up Giviner Jeep Builds 10 09-09-2009 09:20 PM
My TJ Build TellicoTJ Jeep Builds 7 01-08-2009 01:40 AM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
