2003X TJ Build !! - Page 11 - JeepForum.com
post #151 of 1158 Old 07-06-2010, 04:26 PM Thread Starter
2003X
Originally Posted by jbg1980 View Post
What all did you select when you had them set up your HP D30? Did you have new unit bearings installed? What axle shafts did you select?
This is what I selected,
Dana 30 High Pinion XJ,TJ, ZJ
Add U-bolt Yoke: New U-Bolt Yoke 1310 (+$42.00)
FINISH: Flat Black
Gear Ratio-Reman Unit: D30HP-488 (+$500.00)
- I will be re-using my stock shafts, knuckles and brakes.
Do yourself a favor, have him do the ball joints. Its a PITA. If I could re-order I would have selected that option for $175, its worth it.
My Build
2003X is offline
post #152 of 1158 Old 07-06-2010, 04:27 PM Thread Starter
2003X
Originally Posted by Capown View Post
If you dont mind me asking what did the axle setup setya back?? I wanna run 35s but Im scared the D30&D35 will take a dump...
Pm sent
My Build
2003X is offline
post #153 of 1158 Old 07-07-2010, 02:41 PM Thread Starter
2003X
Crown Automotive 39 Tooth Speedo Gear
My Build
2003X is offline
post #154 of 1158 Old 07-07-2010, 09:08 PM
Jay12
Does the hp30 come with used balljoints if you don't select new ones?
Jay12 is offline
post #155 of 1158 Old 07-07-2010, 09:21 PM Thread Starter
2003X
Yes, mine came with used ones, but they were no good. I can get a set up upper and lowers for $110, but I also have to rent the tool, so for the $175 its worth it to have them already done.
My Build
2003X is offline
post #156 of 1158 Old 07-12-2010, 05:00 PM
SaxManClay
It's about time you changed your axles! Let me know when you go off-road, and I'll tag along.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #157 of 1158 Old 07-15-2010, 02:26 PM
07wurubi
07wurubi's Avatar
Did you go with any lockers in the new axles front and rear or leave them open? I have an ARB to go in the front of my stock d30 that already has 4.88s in it. I was planning on using an Izusu d44 for the back but the housing I have is junk, only paid $50 for the whole axle. And I am thinking of going the 8.8 route now instead. I had bought detroit for the d44 before I knew the housing was junk. So I was thinking of ordering one of these 8.8s already setup like and having a locker put in at the same time.
How has the 8.8 been since putting it in? Notice any issues with the slightly skinny WMS from stock? I see your pick of how close the tire is to the springs. Have you taken it out and wheeled with the new axles? Sorry for all the questions. Want as much info from someone that has done this before spending the coin on it. Thanks for any info I can get.
Mike Fox
My Jeep:
00 Wrangler Sport 4.0L NV3550
4" RC LA
Bilstein 5100 shocks all around
axles (30,8.8) with 4.88 gears ARB F/R
SYE and CV rear driveshaft from Drivelines NW
Currie HD steering (Thanks Savvy, Awesome customer service)
Savvy LED tail lights (Thanks again Savvy)
GY MT/R Kevlar 35x12.50x15 on 15x10 American Racing
Bestop soft top with tinted windows
Smitty front and rear bumpers w/rear tire carrier
Smitty XRC8 winch w/synthetic rope
Smitty rear corners and rock sliders with step
Genrite aluminum 6" tube fenders front/rear
Dodge Durango steering box with Pure Jeep skid and M.O.R.E. steering brace
07wurubi is offline
post #158 of 1158 Old 07-16-2010, 01:08 PM Thread Starter
2003X
I left both the HPD30 / 8.8 open. I didn't have the extra cash to do the lockers. I will do those down the road. Though, if I could have re-ordered it I would have opted for the Limited Slip in the 8.8. If you got the cash now I would get a locker and have it done.
I have roughly 800 miles on 8.8 so far. No leak. Changed the diff fluid at 600 miles and no metal or chunks. Everything looked great. I am running 13.50 wide tires with 4" backspacing on the rims. We are running the same rims so you will be fine. I was concerned about rubbing but have had no issues. Obviously if you have a 12.50 wide you will have no issues at all. I can not even notice that the difference in width between the axles.
The guys at ECG really did a amazing job on the welds on the 8.8, the looks flawless and seamless. Every single bracket lined up with out any issues at all. The stock track bar bolted right up and I am running my stock drive shaft and upper control arms with minimal vibes.
I haven't installed the HPD30 yet, waiting on new ball joints for it. But that looks good as well.
Any other questions let me know.
My Build
2003X is offline
post #159 of 1158 Old 07-16-2010, 01:15 PM
07wurubi
07wurubi's Avatar
Thanks for the info. I think when I go to order I will go for the full detroit. Do it once and be done if I can. I am even thinking of doing the CCE kit when ordering but that part is still up in the air for me.
Did you go with the used brake parts when you ordered?
Mike Fox
My Jeep:
4" RC LA
07wurubi is offline
post #160 of 1158 Old 07-16-2010, 01:36 PM Thread Starter
2003X
Yes used pads and rotors which were fine, plenty of meat left. But I did get new e brake cables and e brake pads. I wanted the stronger shafts for the 8.8 and Chase talked me out of it. Said I didn't need to spend the money because he said hes had people beat on the 8.8 with stock shafts and 36s and never have a problem. Saved me a good $400.
My Build
2003X is offline
post #161 of 1158 Old 07-16-2010, 02:03 PM
07wurubi
07wurubi's Avatar
Good to know on the shafts. That is a $540 option I don't need to worry about then. I don't plan on going bigger than 35s anyways. I will definitely go with a full detroit now, used stock shafts and new e-brake shoes with cables.
Would it be better to call when I order and mention the forum or would that make any difference you think on price? I know, should ask Chase that probably.
Mike Fox
My Jeep:
4" RC LA
07wurubi is offline
post #162 of 1158 Old 07-16-2010, 09:29 PM Thread Starter
2003X
I didn't bother sending any emails. I just called Chase, told him I was on jeep forum and told him what I wanted. He sent me a invoice, I paid him same day and I had my axles 4 days later.
My Build
2003X is offline
post #163 of 1158 Old 07-19-2010, 10:50 PM Thread Starter
2003X
Installed the HP D30 today. Took about 9 hours, with a few trips to Sear's and Auto Zoo for tools and sockets. Any questions PM me.
My Build
2003X is offline
post #164 of 1158 Old 07-19-2010, 10:51 PM Thread Starter
2003X
HP D30 Continued:
My Build
2003X is offline
post #165 of 1158 Old 07-19-2010, 10:52 PM Thread Starter
2003X
HP D30 Continued, Only got 1 pic of finished product as it was late. Will take more with in next few days.
My Build
2003X is offline
The Build! XJWren Jeep Builds 17 07-23-2014 11:27 PM
88 XJ Build up Giviner Jeep Builds 10 09-09-2009 10:20 PM
My TJ Build TellicoTJ Jeep Builds 7 01-08-2009 02:40 AM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 11:41 PM
