2003 WJ Off-Road Minivan - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 2003 WJ Off-Road Minivan
CHASSIS SAVERô Labor Day 2 for 1 Sale!!!JKS Flex Connect in Actions!Introducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 04-21-2014, 06:41 PM   #1
JeepinAaron
2003 WJ
So I just recently sold my 2005 LJ because we recently had a child and I needed a 4-door. My goal with this vehicle is similar to my LJ build. The Jeep needs to be a solid daily driver as it will be 90% on-road, and a sleeper wheeler. When I decided I wanted a 4-door I couldn't decide between an XJ or WJ. I previously had an XJ but couldn't find one without a ton of miles. I test drove some 4.0 WJ's and they seemed under powered. Then I found this Jeep:
2003 WJ Laredo
Color: Granite
89xxx miles
4.7L V8
Selec Trac T-case
5 Speed Auto Transmission
D44a rear axle
Tow package (3.73 gear upgrade)
I feel like I got all the options with this Jeep that I wanted with the 4.7, 242 and 3.73 gears.
My first modification goal will be lift and tires. I plan on an IRO 3" lift and adjust the bumpstops for 32" tires.
The Jeep:
JeepinAaron is offline   Reply With Quote Quick reply to this message
Unread 04-21-2014, 06:43 PM   #2
JeepinAaron
2003 WJ
Modifications:
Suspension:
OME HD 3" Springs
Bilstein 5100 Shocks
IRO Adjustable front Trac Bar
IRO Rear sway bar links
Tires:
Goodyear Duratrac 245/75/16
Stock 16" Silverblade Wheels
Armor
Iron Rock Off-road T-case Skid Plate
Custom (designed by HCORE 4x4) Rocker Protection
Electrical:
USB Outlet purchased from Amazon.com
Blue Sea Systems PM 5028 Fuse Block
LED Lighting:
Interior: (Superbrightleds.com)
Under dash courtesy: WLED-WHP10
Map lights: WLED-WHP6
Cargo light and above rear doors: 4410-x9
Exterior: (Amazon.com)
Third brake light: Kolite "194"
Reverse light: Aaroncarled Samsung 60w
2003 WJ Laredo
http://www.jeepforum.com/forum/f22/2003-wj-off-road-minivan-2346505/#post22320625
Unread 04-21-2014, 06:52 PM   #3
redrelyt12
Looks good! I love this color
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2014, 08:58 PM   #4
G Beasley
Jeep-Owner.com
G Beasley's Avatar
Nice clean looking WJ , we have one very similar to yours . I have been thinking of putting some OME springs under ours , what made you decide on IRO?
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 04-22-2014, 03:13 AM   #5
JeepinAaron
2003 WJ
The IRO kit seems pretty complete. I think I will need the full 3" to squeeze 32's. The OME kit would need spacers to get me that tall. IRO kit is more for less money, and I've read good reviews.
2003 WJ Laredo
Unread 04-23-2014, 08:05 AM   #6
JeepinAaron
2003 WJ
I had the day off today and tinkered with the Jeep some. The struts for the hood and lift gate were shot so I replaced them, it took literally 5 minutes to do both. I took the mountain decal from my TJ and put it on the front fender. Also bug deflector is gone!
Yay for open hood.
2003 WJ Laredo
Unread 04-27-2014, 01:07 PM   #7
chilliwangler
I look forward to watching the progress. I am just starting my 2004 WJ build. I have ordered OME custom kit from Kolak and I just picked up a set of 5 2013 Rubi wheels to put on.
Len
Len
2004 Jeep WJ Laredo - Build Thread [URL="http://www.jeepforum.com/forum/f197/04-wj-build-north-49th-2493281/"]http://www.jeepforum.com/forum/f197/04-wj-build-north-49th-2493281/[/URL]
chilliwangler is offline   Reply With Quote Quick reply to this message
Unread 04-29-2014, 11:01 AM   #8
JeepinAaron
2003 WJ
Len
I've been wavering back and forth between just getting tires or getting a set of rubi take offs like you did. The only thing for me is I live in a pretty snowy environment and I think a set of bfg at will do better in snow and ice.
2003 WJ Laredo
Unread 04-29-2014, 12:41 PM   #9
chilliwangler
Yeah I am interested to see how the tire performs on wet roads and snow. Fortunately my WJ has been retired as my daily driver, so I am not too concerned. Once they are worn out I would probably go to the DuraTrac tires.
Len
Len
Unread 04-29-2014, 02:01 PM   #10
JeepinAaron
2003 WJ
I like the rubi take off wheels better, but I don't hate the silver blades so I will probably stick with them and spend the money I save on some rock rails.
2003 WJ Laredo
Unread 04-29-2014, 02:57 PM   #11
caronaxtr
Sub'd, can't get enough of WJ builds. That WJ looks really clean and rust free.
Like where this is goin....
caronaxtr is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 07:14 PM   #12
JeepinAaron
2003 WJ
Homemade disconnects:
Edited to ADD: This didn't work, I aborted it. The bolt hole in the brackets were too big and the sway bar clanked around too much. I will be going with JKS Discos.
Utilized a 1/2" pin. The interior dimensions of the sway bars are 0.47" so I had to grind the pin down some.
Parts:
Result:
Now I need to figure out something to do with the sway bar when it is disconnected.
2003 WJ Laredo
Unread 05-07-2014, 01:12 PM   #13
JeepinAaron
2003 WJ
Small update:
Nifty Catch All Floor mats
Next: replacing interior lights with LED's
2003 WJ Laredo
Unread 05-08-2014, 08:33 PM   #14
JeepinAaron
2003 WJ
Tonights Mod: beginning interior LED light conversion.
I got these lights from superbrightleds they have a nifty vehicle replacement guide. You can pick your make model and year, and they list the light locations and LED replacements. Note, the WJ is not a CAN BUS system, so do not pick those LEDs. I started with the rear cargo lights and the "courtesy" lights above the rear door handles. The lights are brighter than stock and they still perform correctly and dim when I close the doors.
Next I will replace the map bulbs and the under dash lights. I'm not going to fool with the backlights on the dash right now. I then intend to start on exterior LED's, as they have replacement LED bulbs for the stock taillight housings.
Before:
After: (Also I switched to my wife's camera to get a good shot, and ignore the hay in the back)
2003 WJ Laredo
Unread 05-09-2014, 06:03 AM   #15
redrelyt12
Wow that's awesome. I know my next mod!
