2002 TJ budget rebuild - Page 6 - JeepForum.com
post #76 of 748 Old 05-16-2012, 09:46 PM Thread Starter
Jankoid
Originally Posted by G Beasley
After the fun I had adjusting my pinion , I wish I had adjustable uppers . Though your still going to need to adjust the lowers to keep the wheel centered .
Should be okay considering I'm at stock height. I'll be getting lowers for it as soon as I redo the suspension on my LJ.
Jankoid is offline
post #77 of 748 Old 05-17-2012, 08:18 AM
G Beasley
Hopefully it wont roll too far forwards on you . I wonder if the additional strength of the new uppers will put additional stress on the stock lowers ?
G Beasley is offline
post #78 of 748 Old 05-18-2012, 07:31 AM Thread Starter
Jankoid
It rolled it back a little, but not enough to make a difference.
I got the arms installed yesterday. It was a total pain I the ***, but worth it in the end. I no longer get vibes at high speeds, though they weren't bad to begin with. Savvy no longer puts wrench flats on their uppers, which makes it a major pain in the *** to adjust them and an even bigger pain to get the jam nuts right. I don't see what the big hype about Savvy is, but whatever.
Jankoid is offline
post #79 of 748 Old 05-18-2012, 07:45 AM
Imped
Imped's Avatar
Where's the logic in that?
No wrench flats? WTF. That makes or breaks the difference of being a piece of cake or a PITA.
OlllllllO
IndyORV
Imped is offline
post #80 of 748 Old 05-18-2012, 08:00 AM Thread Starter
Jankoid
Yep. I emailed gerald because I thought maybe the arms were wrong or something, but he responded saying they no longer used wrench flats because "people were abusing them." Had I known that when I ordered I would have gone with currie instead.
Jankoid is offline
post #81 of 748 Old 05-18-2012, 08:08 AM
Imped
Imped's Avatar
Well, now that I think about it--just take a crescent wrench on both jam nuts simultaneously (both will want to rotate the arm the same direction) and give em hell. That will ensure that both are tight AND will ensure that both joints are concentric. Then just rotate the arm back to neutral and you're good to go. I guess the only problem is adjusting the arms. When I installed a set of these for a buddy, I used a jack under the pinion to set the axle where I wanted it and just had one end of the arms bolted up (frame end) with the other end resting inside the bracket. I rotated one so that I could just slip the bolt through and then did the same with the other one. Before you do that, you want the rig at ride height, the axle centered, and the axle square (using the lowers).
OlllllllO
IndyORV
Imped is offline
post #82 of 748 Old 05-18-2012, 08:26 AM Thread Starter
Jankoid
I only had one adjustable wrench with me so I had my dad hold the arms with a big pair of channel lock pliers while I tightened each of the jam nuts. Worked out okay, but wrench flats would have made it 100x easier.
Jankoid is offline
post #83 of 748 Old 05-18-2012, 08:52 AM
Sgt.Fuzz
My Rokmen uppers have wrench flats.
My build:
Sgt.Fuzz is offline
post #84 of 748 Old 05-18-2012, 09:00 AM Thread Starter
Jankoid
Where is that double flip-off smiley when you need it?
If savvy carried rokmen arms I would have ordered those instead. I used my TJotM discount to get these arms.
Jankoid is offline
post #85 of 748 Old 05-18-2012, 09:13 AM
G Beasley
The ease of adjustment is what differentiated their arms from others and made them the more logical choice ? I dont feel as bad now having stuck with the JKS arms that were a PITA to adjust .
It was merely speculation based on the uppers being so much stronger now and possibly putting more load on the lowers . Again just speculation .
post #86 of 748 Old 05-18-2012, 09:30 AM
Imped
Imped's Avatar
Sure, the uppers are stronger. That has no bearing on the lower arms, though. Just think about what they arms/links are actually doing.
OlllllllO
IndyORV
Imped is offline
post #87 of 748 Old 05-18-2012, 09:32 AM Thread Starter
Jankoid
I won't be recommending these arms to anyone, I am highly disappointed in them.
The uppers may be stronger than the lowers but the misalignment of the johnny joints will alleviate that issue, if there even is one.
Jankoid is offline
post #88 of 748 Old 05-18-2012, 09:53 AM
Imped
Imped's Avatar
Jank, I get the frustration....I'd be a bit frustrated at that as well. But you still got yourself a nice pair of 6061-T6 aluminum threaded arms with JJ's at both ends and that's what matters....and having two forged JJ's = more available adjustment. Much superior to anything with rubber bushings, regardless of the adjustment method. They removed the flats for a reason and it makes sense--cranking on it is way too easy and can cross the threads in the tube if there's too much of a load on the arm. And FYI, I made a LH/RH arm for my front upper link and I didn't put wrench flats in it--with my welding gloves on, I can turn it under load and I locked down the jam nuts exactly as I told you to.
OlllllllO
IndyORV
Imped is offline
post #89 of 748 Old 05-18-2012, 10:08 AM Thread Starter
Jankoid
I understand that they are good arms, and I was going with double johnny joint arms regardless, I'm just peeved that they changed their arms and didn't advertise it. Even the pictures on their website still show them with wrench flats. I didn't get the product I expected.
Jankoid is offline
post #90 of 748 Old 05-18-2012, 03:38 PM Thread Starter
Jankoid
Just scored a Detroit Truetrac for a D30 from the classifieds.
Jankoid is offline
nc guys , needs to clean the garage
My 2002 WJ then and now! Jeepers26 Jeep Builds 13 04-12-2010 07:36 PM
2002 Tj 6stringboarder Jeep Builds 16 02-02-2009 06:28 PM
My new 2002 TJ Troy591 Jeep Builds 9 11-20-2007 11:20 PM
My 2002 TJ elkfan2 Jeep Builds 4 04-09-2007 09:19 PM
2002 Tj GenXSlkr Jeep Builds 0 02-18-2003 08:26 AM
