2002 TJ budget rebuild - Page 41 - JeepForum.com
post #601 of 748 Old 09-28-2013, 11:45 AM
tyvanwie
The Barnes looks good.
tyvanwie is offline
post #602 of 748 Old 09-28-2013, 11:55 AM
JCJeep97
As usual I stole more parts from the LJ for this build.
Old unknown brand front bumper:
New Barnes 4wd bumper and Champion winch:
Looks much better.
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #603 of 748 Old 10-06-2013, 02:08 PM Thread Starter
Jankoid
Finally got to do some wheeling today!
Jankoid is offline
post #604 of 748 Old 10-06-2013, 02:30 PM
JCJeep97
How's your **** work?
JCJeep97 is offline
post #605 of 748 Old 10-06-2013, 03:04 PM Thread Starter
Jankoid
It's hard to say yet.
It rides great on the trails, far better than it did before. The extra wheelbase, better suspension, outboarded shocks, and vertical coils help with that. Should ride even better once I put some quality shocks up front. Very pleased overall from that standpoint
I can't really say yet how well the suspension performs as I have yet to do any hard obstacles. I'll be able to tell more once I do the ledges next weekend at the jamboree (didn't want to risk doing those since I was out there by myself, they've gotten pretty rough lately).
Biggest complaint I have about the Jeep is actually unrelated to the stretch, and has been present since I built the Jeep last year. The check engine light is on (dont remember the codes), and occassionally the Jeep will stall out when the rpms drop, usually when coming to a stop. On road it never really bothered me (didn't drive it much anyway), but offroad it stalls out often. Even in first gear, as soon as you get on an obstacle and the tires bind up and the rpms drop under a grand, it stalls. It doesn't just putter out like when a car usually stalls out, the damn thing just dies. I'm clueless when it comes to motors and whatnot so I open to ideas on how to fix it. While it is very annoying that it stalls out, it is even more embarrassing than annoying because it makes me look like a total newb with a clutch.
Jankoid is offline
post #606 of 748 Old 10-06-2013, 07:00 PM
JCJeep97
Does it idle low or rough? I guess throttle position sensor.
JCJeep97 is offline
post #607 of 748 Old 10-17-2013, 10:42 AM Thread Starter
Jankoid
Got some good wheeling pictures from last weekend at URE. I omitted the best ones though for use in TJotM this month.
Jankoid is offline
post #608 of 748 Old 10-17-2013, 10:48 AM
kyle_craig
Looking perfect! Any other plans for it?
kyle_craig is offline
post #609 of 748 Old 10-17-2013, 12:05 PM Thread Starter
Jankoid
Not much really. I want to get some better shocks for the front and replace the worn out RC 2.5" coils and 2" spacers with the RC 4" coils I'll be removing from the front of my LJ soon. It also needs rear flares to match the front. I mainly just want to keep it in one piece while I focus on upgrading the LJ, so no more major mods for a while.
Jankoid is offline
post #610 of 748 Old 10-17-2013, 12:17 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Nice photos man! Rig is looking great, nice and classy looking. Glad to see you out using it and it looks like it's working good. As far as your stalling issue.... the first thing I would do is pull the code, and look it up. One thing I REALLY like about Dodge / Jeep, is that the diagnostic trouble codes usually DO lead you to the problem. If I was making an educated guess though I would say you have an intermittent crank shaft position sensor problem that manifests itself at low RPM. Luckily that part is easily changed and inexpensive. If not that then as the other member suggested, I'd be looking at the TPS, although when I've seen them fail you usually get an abnormally HIGH idle RPM.
gst95dsm is offline
post #611 of 748 Old 10-25-2013, 01:12 AM
SOWEGA TJ
Had a friend that works at a machine shop custom make an engine skid for me. I gave him the measurements and it took him all of five minutes to make. I had it made from 3/16" steel. I just need to add a lip to the front edge and make some mounting brackets for the front and it will be good to go. Better than spending $300 on a UCF skid.
Attachment 413421
sweet TJ! do you have any specs on the skid after you finished it?
SOWEGA TJ is offline
post #612 of 748 Old 10-25-2013, 01:42 AM Thread Starter
Jankoid
What kind of specs are you wanting? It's just a simplified copy of a UCF engine skid and is functionally identical.
Jankoid is offline
post #613 of 748 Old 10-25-2013, 04:24 AM
SOWEGA TJ
the skid looks identical to theirs and I have access to a break so it would save a ton. Not one in my area has one to measure to copy so I didnt know if you did since you had one made
post #614 of 748 Old 10-25-2013, 08:33 AM Thread Starter
Jankoid
I had measurements initially but they have disappeared, otherwise I would've had more made. I'll try to get some for you later.
Jankoid is offline
post #615 of 748 Old 10-25-2013, 04:46 PM
SOWEGA TJ
Thanks man!
nc guys , needs to clean the garage
My 2002 WJ then and now! Jeepers26 Jeep Builds 13 04-12-2010 07:36 PM
2002 Tj 6stringboarder Jeep Builds 16 02-02-2009 06:28 PM
My new 2002 TJ Troy591 Jeep Builds 9 11-20-2007 11:20 PM
My 2002 TJ elkfan2 Jeep Builds 4 04-09-2007 09:19 PM
2002 Tj GenXSlkr Jeep Builds 0 02-18-2003 08:26 AM
