2002 TJ budget rebuild - Page 3 - JeepForum.com
post #31 of 748 Old 03-19-2012, 08:15 PM Thread Starter
Jankoid
Progress has lagged some. I didn't get much done over the weekend. On Saturday I pulled the front axle I'm going to be using (LP D30 from a '99 4cyl TJ). It needs some work, but it's from a Jeep I already have, so I can't complain too much.
Most obvious is the surface rust it has all over. Nothing too major to keep it from being used though. Since it is from a '99 model it has the old style rotors, and the hub assembly and axle shafts have some rust issues. To solve this I am pulling the shafts and everything from the 3.73 D30 I pulled from the frame I'm using and swapping them to the 4.10 axle. I finished the passenger side on Sunday (yesterday), but still need to do the driver side. I'm also pretty sure the driver side tube is bent from the wreck it was in though, so that will get fixed while the shaft is out. I also pulled the cover yesterday to check the gears and they looked pretty good. The axle also needs a new passenger side upper control arm mount and driver side lower control arm mount. If I have time I hope to get the axle done tomorrow, but I have a lot of work to get done at the shop so I don't know if it will happen or not.
I still have yet to pick up the Rubi D44 rear from a friend of mine. It is currently mostly dissasembled (long story) and he has been so swamped with work that he hasn't been able to get all the parts together for me. It's looking less and less like I will have this Jeep together in time for my URE trip on the 31st.
Jankoid is offline
post #32 of 748 Old 03-21-2012, 09:14 AM Thread Starter
Jankoid
Picked up my rear axle yesterday. Still don't have the shafts or brakes yet, but I can at least get it painted and swung under the jeep. I plan on getting it washed and painted after classes today, along with the front axle, and then installing them tomorrow.
Jankoid is offline
post #33 of 748 Old 03-21-2012, 08:22 PM Thread Starter
Jankoid
Front axle has been straightened, passenger upper and driver lower mounts have been replaced, and the rear axle has a new driver side lower mount and shock mount.
Paint goes on first thing in the morning, followed by installation of both axles!
Jankoid is offline
post #34 of 748 Old 03-21-2012, 09:35 PM
Sgt.Fuzz
Sum beach, another Jank build. Right on bro.
My build:
Sgt.Fuzz is offline
post #35 of 748 Old 03-23-2012, 11:37 AM Thread Starter
Jankoid
Both axles are in. All the bolts still need to be tightened, but that is the easy part. Gonna get that taken care of today after school, and then get the frame pressure washed. Then tomorrow morning I am going to paint the frame first thing, and once it dries the tub is going back on!
I'll get pictures of the axles uploaded later.
Jankoid is offline
post #36 of 748 Old 03-23-2012, 09:07 PM
G Beasley
And here I was patting myself on the back for welding up a fairlead mount today ... while you march through another major build . Ahh to be young again !
G Beasley is offline
post #37 of 748 Old 03-25-2012, 07:52 PM Thread Starter
Jankoid
Teaser shot:
Jankoid is offline
post #38 of 748 Old 03-26-2012, 08:48 AM
JCJeep97
Teaser shot:
Must really be nice to have forklifts and ****
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #39 of 748 Old 03-26-2012, 01:35 PM Thread Starter
Jankoid
I have a lot of updates, hopefully I will have time to get everything posted tonight.
Here is what I just did half an hour ago right after school:
Got all 4 of my tires mounted and balanced on a set of Eccos. I've always liked Eccos, so I figured I would try them on this rig.
Jankoid is offline
post #40 of 748 Old 03-26-2012, 08:43 PM Thread Starter
Jankoid
I have been slow with uploading pictures.
Here is how you straighten an axle without some fancy press:
Front axle installed:
Rear axle installed:
Frame painted:
Jankoid is offline
post #41 of 748 Old 03-26-2012, 08:52 PM Thread Starter
Jankoid
I already posted the picture of the tub hanging above the frame. Here is a picture from not too long afterwards:
I worked the rest of the day mounting the fenders, grill, under-hood components, and the dash. Starting to look like a Jeep again:
Jankoid is offline
post #42 of 748 Old 03-26-2012, 08:59 PM Thread Starter
Jankoid
Today I got the front end finished up. I didn't notice until I had removed it, but the steering that was on the frame I'm using has a badly bent drag link. Good thing I replaced the whole thing with my old LJ steering.
Stock TJ on top, V8 ZJ on bottom:
Got the steering on, installed rotors, and bought new calipers:
Got the front end on its own weight:
Started on the rear axle, but only got as much done as seen here:
Work resumes tomorrow!
Jankoid is offline
post #43 of 748 Old 03-27-2012, 07:52 AM Thread Starter
Jankoid
Back when I swapped my Rubi axles into my LJ, I had to replace one of the locker pumps. It costed about $100 for the one pump. I thought that was a reasonable price.
Fast forward one year. I need a locker pump for the rear axle I swapped into this TJ. Called up the parts dealer I use, tried to order the pump, and he tells me you can no longer order the pumps individually. You have to buy both pumps and the mounting bracket together for $330!
Looks like I am going to rob a pump from a wrecked Rubicon I will be fixing up to sale sometime in the future. I will try to find a used one for that Jeep.
Edit: Just found one online, but it won't get here in time for me to use it this weekend, so I'm just going to get it from the rubi anyways, and put a new one in that Jeep.
Jankoid is offline
post #44 of 748 Old 03-27-2012, 08:26 AM
JCJeep97
So is it gonna be ready by the weekend?
JCJeep97 is offline
post #45 of 748 Old 03-27-2012, 08:46 AM Thread Starter
Jankoid
Hopefully. Its getting close. I actually hope to get it running and driving today.
Jankoid is offline
nc guys , needs to clean the garage
My 2002 WJ then and now! Jeepers26 Jeep Builds 13 04-12-2010 08:36 PM
2002 Tj 6stringboarder Jeep Builds 16 02-02-2009 07:28 PM
My new 2002 TJ Troy591 Jeep Builds 9 11-21-2007 12:20 AM
My 2002 TJ elkfan2 Jeep Builds 4 04-09-2007 10:19 PM
2002 Tj GenXSlkr Jeep Builds 0 02-18-2003 09:26 AM
