2000 XJ "build" - Page 2 - JeepForum.com
post #16 of 49 Old 01-08-2012, 05:22 PM
Back_In_Black
its a casting flaw.
Back_In_Black is offline
post #17 of 49 Old 01-08-2012, 06:45 PM Thread Starter
matt62485
Originally Posted by Back_In_Black View Post
its a casting flaw.
[]IIIIII[]
matt62485 is offline
post #18 of 49 Old 01-08-2012, 06:53 PM
Back_In_Black
isnt that what you just asked?
post #19 of 49 Old 01-08-2012, 08:07 PM
Chrisp929
I'm following. I just got my new to me 2001 xj last month. Thankfully i don't have a cracked head YET.
I have a couple questions for you if you don't mind.
What lift kit is that and how high is it.
What size tires are those ?
thanks man ..
sweet jeep.. my cousin owned a black one like yours till he smashed it up in a drunk driving accident. He eventually had it fixed at a body shop but then sold it since he had no license. I wanted a black one but was sold on mine, having been so clean inside and little to no rust other than the doors.
LOVING mine .. did a ton of work on her over the last couple weeks. Fixed the horribly leaking oil filter adaptor o rings the other day. Not fun but not that bad. I bought a Torx kit from harbor freight for like 11 bucks and cut the T60 in half to fit on a 3/8" breaker bar and got the adaptor loose that way. now all i have to do is eventually do the rear main seal but that will wait till late spring i think.
Please take pictures of your head/possible engine swap .. i'm interested .. as a shade tree mechanic myself, i plan to keep my xj for EVAR. Eventually i'll need an engine swap and i would love to see your progress on yours.
Good luck.
Chrisp929 is offline
post #20 of 49 Old 01-09-2012, 02:39 AM Thread Starter
matt62485
how can you tell by looking at that pic whether or not it's a casting flaw or a crack? b/c i got the thing sitting right in front of me and i can't tell. obviously, the 0331 before the TUPY's were "flawed" causing cracking if overheated. im saying, i can't tell if it's a flaw in the casting that looks like a crack, or if it's an actual crack.
where else would the crack be? b/c i don't see anything else. ofcourse it could be so small i can't see it, but looking at other pics online, many of them crack in the same spot mine appears to be.
[]IIIIII[]
post #21 of 49 Old 01-09-2012, 06:31 AM Thread Starter
matt62485
Thanks man. Its just a 2" budget boost and some 245/75/16 Kevlar mtrs Yea ill do my best to take pics and update as I go.
thanks man ..
Good luck.
[]IIIIII[]
post #22 of 49 Old 01-09-2012, 01:35 PM
Back_In_Black
you highlighted it yourself....
and if that is between cylinders 3 and 4 then yes, its most likely from the casting flaw.
post #23 of 49 Old 01-10-2012, 11:41 AM Thread Starter
matt62485
lol. i know that's where most of them crack b/c of a casting flaw, but when i said flaw, i meant as in an uneven finish in the cast, not a crack, but more so a raise.
but yea, its defniitely cracked.
magnaflux...
[]IIIIII[]
post #24 of 49 Old 01-15-2012, 12:54 PM Thread Starter
matt62485
so, it'll be a lil while til i get all the parts i need ordered/acquired b/c of working so much, so figured i would start cleaning up the wiring/loom, etc and do a lil cleaning/painting in the bay.
starting moving stuff out the way and taking old loom/tape off... what a friggen rats nest.
think i've cleaned about 50 of these out when i removed the front clip
pile of crap. jeep cleaned up a lil
[]IIIIII[]
post #25 of 49 Old 01-22-2012, 02:46 PM Thread Starter
matt62485
cleaned up, fresh paint and some new wire loom. still lots to do on this side. then work my way to the drivers side
[]IIIIII[]
post #26 of 49 Old 01-22-2012, 02:59 PM
02greytj
looks really clean with the moabs on there! i have a 01 xj with 130k on it. Im afraid to pull the head and check for casting flaws
2001 cherokee sport 5 speed with 31s
02greytj is offline
post #27 of 49 Old 01-22-2012, 03:01 PM Thread Starter
matt62485
id just be religous with checkin the coolant, keeping an eye on the temp and keeping it clean. i bought this one with the head cracked, so i kinda knew what i had on my hands.
[]IIIIII[]
post #28 of 49 Old 01-22-2012, 03:05 PM
02greytj
yeah i just installed a new radiator and t stat, so hopefully it will be good
02greytj is offline
post #29 of 49 Old 01-23-2012, 04:06 AM Thread Starter
matt62485
sweet. mine has a new radiator on it too. putting a new water pump, inlet tube, hoses and t-stat on it as well.
[]IIIIII[]
post #30 of 49 Old 02-11-2012, 09:59 PM Thread Starter
matt62485
[]IIIIII[]
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
MG's 2000 2Dr Build "Greyhound" mg2000xj Jeep Builds 76 10-17-2012 08:54 PM
2000 TJ "Chili Pepper Edition" cbrookerd Jeep Builds 11 10-03-2010 04:13 PM
2" or 3" lift on 2000 Jeep Wrangler marineman428 Jeep Builds 3 09-09-2010 12:31 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
