2000 TJ build thread - JeepForum.com
post #1 of 43 Old 11-18-2010, 09:01 AM Thread Starter
timmytimm3
I bought the Jeep 12/14/08 with 114k miles on it. The motor had been replaced under warranty at around 90k, so the 6 banger is fresh.
Came with a 2.5" Rancho lift and 32 BFG ATs
The day I bought it
Front bumper build
Rear bumper build
Booger welds
1" motor mount lift and 1" body lift
timmytimm3 is offline
post #2 of 43 Old 11-18-2010, 09:01 AM Thread Starter
timmytimm3
33 BFG Mud Terrains on black steelies
LED tail lights
Lined the tub with Monstaliner
AA Slip Yoke Eliminator and new driveshaft
Undercover Fab 1" skid (in etch primer)
Had to modify my tcase shifter linkage and dent the tub to clear
Currie short arms (running Rokmen rear uppers because I couldn't get enough pinion angle w/ Currie)
Gas tank skid was shot.
Rokmen skid
This winter:
HP30 w/ 4.88's and ARB, regear rear D44 w/ 4.88's and ARB, 35 MTR w/ kevlar, rock sliders, outboard rear shocks, etc...
post #3 of 43 Old 11-18-2010, 09:15 AM Thread Starter
timmytimm3
My toys
post #4 of 43 Old 11-18-2010, 09:25 AM
99NHWrangler
I love seeing examples of things people fabricate themselves. Very nice!!
99NHWrangler is offline
post #5 of 43 Old 11-18-2010, 09:36 AM Thread Starter
timmytimm3
My brother's truck
Built 383
465/205
D60 lockrite, 14bolt detroit 5.13s
39 boggers
Full cage
post #6 of 43 Old 06-27-2011, 07:05 AM Thread Starter
timmytimm3
Some updates:
I drilled a 1" drain hole in the bottom of each frame rail and made mini fish plates to prevent them from cracking.
Then welded a nut offset on the end of a rod, stuck it inside the frame and hooked the other side to a drill. It banged around like crazy and knocked a bunch of rust loose (My Dad's idea). I also used a needle scaler on the outside.
Then I pressure washed the inside down and pulled over a gallon of rust scales out of the frame.
After it was all cleaned out I shot 3 cans of Eastwood's internal frame coating in the frame rails. Coverage was great.
Then I wire wheeled the whole frame down and hit it with 2 coats of Chassis Saver satin black.
New parts:
35 MTRs on Black Classic II, Currie front trackbar, Antirock, YJ front brake lines, Currie bumpstops, Bilstein front shocks, BDS 3" coils, Undercover Fab low profile tcase mount.
Driveway wheeling
I still need to do a complete alignment on the front (control arms, trackbar, steering etc) and add another exhaust hanger.
post #7 of 43 Old 09-29-2011, 04:53 PM
kvesi122
the frame looks so clean!!!
kvesi122 is offline
post #8 of 43 Old 09-29-2011, 08:50 PM
Prryan45
Wow,a gallon of rust.I better check mine.
Prryan45 is offline
post #9 of 43 Old 09-30-2011, 06:53 AM Thread Starter
timmytimm3
Thanks, I still need to finish the back, but waiting until I outboard the shocks so I'm not breathing in melting paint.
post #10 of 43 Old 09-30-2011, 06:54 AM Thread Starter
timmytimm3
I was shocked how much rust came out.
Stick a hose in the front and blast it towards the back. Stick your finger in a hole ( ) and see if you can feel rust scales.
post #11 of 43 Old 09-30-2011, 04:05 PM
2000GrayTJ
^^this, you'll likely be surprised how many pieces you have to break up in order to get out :O
good from far, far from good.
'99 TJ frame-off rebuild: http://jeepforum.com/forum/f22/99-tj-frame-off-rolled-bold-1199954/
2000GrayTJ is offline
post #12 of 43 Old 10-01-2011, 12:00 PM
kvesi122
do you still feel like the frame is strong enough after pulling all the scales out?
kvesi122 is offline
post #13 of 43 Old 11-04-2011, 06:31 AM Thread Starter
timmytimm3
It should be fine. I used a needle scaler on the hardest setting on the outside and didn't see any weak areas. I think I caught it just in time.
post #14 of 43 Old 11-28-2011, 10:00 AM Thread Starter
timmytimm3
Went wheeling Saturday at a friends property. 60 degrees in November. Doors off, top down.
Hopefully building my axles in a month or so (HP30/D44/4.88/ARBs)
post #15 of 43 Old 11-28-2011, 12:31 PM
2000GrayTJ
Great build so far! Very similar path to mine, everywhere from the 3" BDS lift to the Chassis Saver/Monsta
2000 TJ Sport Build Thread timdastis Jeep Builds 8 03-03-2012 04:15 PM
2000 Sahara Build Thread Logan Jeep Builds 24 08-17-2010 12:09 AM
Yellow 2000 TJ Build Thread odwaud Jeep Builds 2 05-09-2010 06:36 PM
2000 Wrangler Sahara - Yet another build thread BigGreenTJ27 Jeep Builds 4 10-08-2009 06:38 AM
