2000 Stroked Xj - JeepForum.com
post #1 of 69 Old 12-19-2012, 09:24 AM Thread Starter
Showtime3492
2000 Stroked Xj
Hey Everyone
Decided that i should make a new build thread since the old one was cluttered up between the old jeep and the knew one and people kept asking why i only painted half of it So ill jump right into it
So this is my old jeep it was a 98 xj basically got rid of it due to frustration. And i found a new jeep a 2000 xj thats the silver one
281946_1994807115445_1401465462_31981178_6158895_n.jpg   294056_2208234610999_1401465462_32175937_332691727_n.jpg
--1998 XJ "Mater"- RIP
2000 XJ--- 4.6 stroker. Saved from the grave- everything swapped or modded. I hate this thing :)
Showtime3492 is offline
post #2 of 69 Old 12-19-2012, 09:26 AM Thread Starter
Showtime3492
I bought the 2000 knowing that it had a blown motor and the trans was questionable. So i kept the entire driveline out of my 98 and sent the rest to the junkyark.
399772_2620019825372_1401465462_32370131_1521960314_n.jpg   305887_2286935978484_1401465462_32226222_308124187_n.jpg   377720_2286931538373_1401465462_32226219_400219271_n.jpg
post #3 of 69 Old 12-19-2012, 09:32 AM Thread Starter
Showtime3492
After about a total of 3 months i had the whole driveline swapped over and was ready to fire it up for the first time. Well after firing it up about ten minutes into running the engine started to choke out and then rev'd up to about 3000 and started knocking from the bottom end. I wouldnt find out what actually happened untill i pulled the head off. I kept the intake off the 2000 and put it on my 98 engine and apparently when the 2000 blew up it sent pieces of piston ring up through the original head and into the intake manifold, and my recently swappend good running 4.0 just sucked a few of them down and forced a spun bearing.
post #4 of 69 Old 12-19-2012, 09:33 AM Thread Starter
Showtime3492
so here we are again. Gutting the block and pulling the trans off it. :
post #5 of 69 Old 12-19-2012, 09:36 AM Thread Starter
Showtime3492
Started looking for a set up for a stroker and found the crank and rods that i needed. Snagged those and it was off to the machine shop where i had the block bored .030 and .015 milled off the top. Also had the block line honed and the crank turned and rods reconditioned. Even bought a new head for it and port matched the intake and exhaust. The resulting product was this a 4.6L stroker. I added the orange valve cover cuz it just wasnt obnoxious enough
More details on the stroker
258 crank and rods
New head from clearwater cylinder heads
New cam
9.45 static comp ratio
8.14 dynamic comp ratio.
Should run on 89-93 octane
post #6 of 69 Old 12-19-2012, 09:42 AM Thread Starter
Showtime3492
It spent about 5 months in the machine shop and once i got it back i didnt waste much time starting to get it back together.
post #7 of 69 Old 12-19-2012, 09:45 AM Thread Starter
Showtime3492
Along with the stroker i had to change some other things to compensate for that as well. I added an AEM wideband o2 sensor to monitor the air to fuel ratio, a map sensor voltage adjuster, and 24lb 4 hole injectors to supply it with the added fuel it needs.
Picture is of the homemade map sensor voltage adjuster
post #8 of 69 Old 12-19-2012, 09:50 AM Thread Starter
Showtime3492
I have rough country long arms on the front and after this project i couldnt stand dropping the long arm crossmember everytime i needed to work around the transmission so i made it center section removeable. I also took advantage of this being off and welded on the TNT customs frame stiffeners then welded the link mounts to them.
579847_3815966203284_895119170_n.jpg   xmem drill.jpg   xmember.jpg   52527_3940602119104_1085570271_o.jpg   385446_2286939378569_1401465462_32226224_2065155341_n.jpg
post #9 of 69 Old 12-19-2012, 09:56 AM Thread Starter
Showtime3492
I also got rid of the factory Low pinion 30 and swapped in the 98 high pinion 30. Added some brown dog offroad motor mounts and a few other things during the engine install.
The rundown on the suspension is 4.5 springs front and rear, shackles relocated in the rear, long arm front. The steering is mostly factory right now minus a v8 tierod and an old man emu stabilizer. I just picked up stuff to do a wj steering and brakes conversion though an that is coming soon. Got the akebono calipers and crossover steering
post #10 of 69 Old 12-19-2012, 09:57 AM Thread Starter
Showtime3492
pretty much the way it looks now.
post #11 of 69 Old 12-19-2012, 10:17 AM Thread Starter
Showtime3492
Only real rust on the whole jeep.
post #12 of 69 Old 12-19-2012, 10:21 AM Thread Starter
Showtime3492
Floor repaired with 12 gauge
post #13 of 69 Old 12-19-2012, 10:28 AM Thread Starter
Showtime3492
This is the gauge pod I threw together for like $3 and 30 mins of time.
And just a few other pictures.
This is the amount if material that had to come off the exhaust manifold to be matched up with the gasket. There was definitely some restriction there
post #14 of 69 Old 12-19-2012, 10:34 AM Thread Starter
Showtime3492
Ill fix the giant photos as soon as i get a chance.
post #15 of 69 Old 12-19-2012, 10:34 AM
DoctorTim
looks like a handful! let me know how you like the frame stiffeners i've been looking into getting some but still weighing my options..
add: Is that a Hobart 140? those are beast I got one myself. Heard they are the best you can buy for 110V
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
