1998 5.9 Build - Jeep #3 - Page 6 - JeepForum.com
post #76 of 85 Old 11-25-2012, 04:47 PM Thread Starter
csouers
It's great. No complaints whatsoever. We don't have emissions testing here, so I can't help you there. No CEL.
Put in a new water pump and tstat today. Sometime within the next few months, it's getting some front end work; ball joints, rotors and pads up front as well as fixing the 4wd linkage.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #77 of 85 Old 11-25-2012, 04:52 PM
maztj
Nice jeep!
maztj is offline
post #78 of 85 Old 01-09-2013, 03:03 PM
5point9Limited
5point9Limited's Avatar
Hey, I saw you put on a new PCV grommet. I just did valve covers the other day... Wish I would have done the PCV then! You said it was a real pain to get in, any tips or tricks? Nice Niner, BTW!
1997 TJ 4.0, 5 Speed, Stock
Sold: 1998 Grand Cherokee 5.9 Limited
5point9Limited is offline
post #79 of 85 Old 01-10-2013, 10:32 AM Thread Starter
csouers
Yeah. It was a pain. Glad I did it though.
Thanks man. Come spring, she's getting all kinds of love.
csouers is offline
post #80 of 85 Old 03-03-2013, 11:57 PM Thread Starter
csouers
Bought a tcase linkage repair kit from jeep4x4center and put in the new torque shaft bearing and bushing. Was a major pita, but I finally have my 4wd linkage working again! I also installed a set of clear corner lights up front. eBay special for $23.
Took some photos the other day.
Nikon D7000 + 85mm f/1.8 AF-S
D7000 + 11-16mm F/2.8 Tokina ATX PRO
Bought a few things from detailedimage.com to clean up the tailpipe.
Chemical Guys Grime Reaper A.P.C. - 16 oz
Klasse All In One (AIO) - 500 ml
Optimum Metal Polish - 8 oz
Before:
During Cleaning with the APC which I diluted to 1 Part APC 5 Parts water. Spray on, let it set, wipe it off, repeat. I even went as far as to spray on a heavy coat and brush the pipe with #0000 (super fine) steel wool to bring up anything chemicals along wouldn't get. It worked great.
After 2 coats of Optimum metal polish and glazing with Klasse.
Much better. It's not perfect, but I think I'll need to pull it off to properly fix it. Now to work on my piping again. That bumper really need replaced. Ugh.
csouers is offline
post #81 of 85 Old 05-31-2013, 10:50 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
I still love this thing.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #82 of 85 Old 09-04-2013, 09:34 PM Thread Starter
csouers
Me too.
In the past 3 months, she's gotten the intake manifold plenum pan replaced, fuel injectors, and some front end parts. I've driven her about a total of 1000 miles this summer. Lame.
Oh yeah. A new picture.
csouers is offline
post #83 of 85 Old 10-15-2013, 03:49 AM Thread Starter
csouers
Put in XRF ball joints about a month ago. I've been chasing down a front end pop and some general looseness. New trackbar, ball joints, all sway bar hardware and bushings, as well as all 4 control arms and bushings. I STILL have a noise. Turns out my BRAND NEW ball joints (the upper is the culprit), with less than 900 miles on them, have about 1/4" of play up and down. That's too much for my taste and it's allowing the lower ball joint to slam into the axle-c repeatedly. Bought a set of Spicer BJs from Amazon (came from 4WD in the end) and will be putting those in.
Luckily the ebay seller of the XRF joints is going to give me a full refund as they have a lifetime warranty.
Also, something in my rear diff is fubar. Makes a damn racket when turning, I hope to god it's not a broken R/P. I can deal with spider gears or maybe a worn out LSD (which work perfectly now so I doubt it).
csouers is offline
post #84 of 85 Old 07-12-2014, 12:16 AM Thread Starter
csouers
- Installed a set of Spicer ball joints some time ago. Had to knurl them to press fit. I think once these wear out, it's getting a new axle housing as I'm sure they will no longer press fit regardless of what I do.
- Did a brake job. These brakes are great. The warmer they get, the better they stop.
- Replaced the power steering pump. Third pump was the charm. The last two new ones leaked.
- Got new tires. Destination LE2s in 235/70/16. Great snow traction and rain. Dry is damn good too.
- Had a brake popping noise when first setting off each day. Put in the abutment clips on the tops of the brake pads to fill in the gap from the knuckle divots. Seems to have solved that. Only did it on the front left side.
Next big thing is headliner. Only if I could get the screw for the overhead off. It's seized. Hell.
A picture.
csouers is offline
post #85 of 85 Old 07-12-2014, 12:54 AM
Aaleck
2011 JK Wrangler
Slowly but surely! Looks good
Aaleck is offline
1998 TJ Sport Build Smitty98TJ Jeep Builds 53 06-21-2013 05:52 AM
My 1998 Jeep Grand Cherokee build thething Jeep Builds 10 02-27-2011 09:34 PM
1998 Jeep Wrangler Build Kittie Jeep Builds 35 10-18-2010 01:31 PM
My 1998 xj 2dr build JobForaCowboy Jeep Builds 40 05-03-2010 10:39 PM
1998 XJ Build YMEOFCR Jeep Builds 10 01-20-2010 07:30 PM
