1998 5.9 Build - Jeep #3 - Page 3 - JeepForum.com
post #31 of 85 Old 01-18-2011, 10:59 PM Thread Starter
csouers
Emailed Jeep to ask for the build sheet. Got it a few days later!
Sales Code Description
*ML Leather Trimmed Bucket Seats
-AZ Agate
AFFP Luxury Group
AHX Trailer Tow Group IV
APAS Monotone Paint
ARPP Limited Decor Group
ARVP Plus Decor Group
A07P 5.9L Engine(EML)/4Sp Auto Trans(DGT)
BA6P 150 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BRGS Anti-Lock 4-Wheel-Disc Brakes
CACS Low Back Bucket Seats
CFNS Rear 60/40 Folding Seat
CGWS Next Generation Front Air Bags**
CKDS Floor Carpet
CKNS Cargo Compartment Carpet
CKRS Cargo Net
CKTS Cargo Tie Down Loops
CLES Front & Rear Floor Mats
CSAS Spare Tire Cover
CSCS Cargo Compartment Cover
CSRS Passenger Assist Handles
CUDP Mini Overhead Console
CUFS Full Length Floor Console
DGB All 4-Speed Automatic Transmissions
DGTS 4-Spd. Automatic 46RE Transmission
DHAS Lock-Up Torque Converter
DHRP Single Speed On Demand Transfer Case
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Rear Axle Ratio
DRKP Dana 44/226MM Rear Axle
DSAP Anti-Spin Differential Rear Axle
EAAC All Engines
EML 5.9L V8 MPI Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGP Deep Tint Sunscreen Glass
GEPS Flipper Liftgate Glass
GFAS Rear Window Defroster
GNCS Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GR3P Left Power Fold-Away Mirror
GS3P Right Power Fold-Away Mirror
GT3P Power Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GWAP Power Sunroof
GXMS Remote Keyless Entry
HABP Air Conditioning w/Auto Temp Control
HGAS Hood Insulation
HGDS Deluxe Insulation Group
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JKAS Locking Glove Box
JPAS Power Windows
JPBS Power Locks
JPMP Heated Front Seats
K4SS STRIPE/BADGE/MOLDING/COLOR
K5SP STRIPE/BADGE/MOLDING/COLOR
LACS Illuminated Entry
LAGS Warning Chime
LAZP Vehicle Information Center
LBBS Courtesy Lamps
LBCS Glove Box Lamp
LBDS Ash Tray Lamp
LCBP Door Courtesy Lamps
LDAS Underhood Lamp
LDBS Cargo Compartment Lamp
LETP Traveler/Mini Trip Computer
LEWP Radio/Driver Seat/Mirrors Memory
LMGP Automatic Headlamps
LNJP Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
MDA Front License Plate Bracket
MFNP Body Color Grille
MHAS Black Windshield Moldings
MVAP Limited Badge
MVBP Grand Cherokee Badge
MVCP Jeep Badge
MVDP 4X4 Badge
MVEP V-8 Badge
MWAP Roof Rack
NAA Federal Emissions
NF5S 23 Gallon Fuel Tank
NHMS Speed Control
NMCP Heavy Duty Engine Cooling
NMXP Maximum Duty Engine Cooling
PS4 Bright Platinum Metallic Clear Coat
QS4S Bright Platinum Clear Coat
RAAC All Radio Equipped Vehicles
RAZP AM/FM Cassette Compact Disc Radio
RCMP 18 SPKRS SRT High Perf Audio
RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCLP Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SUAS Tilt Steering Column
TBBP Full Size Spare Tire
TBLS Inside Mounted Spare Tire
TRPP 225/70R19.5G All Pos Traction Tires
TZAS Goodyear Brand Tires
WDUP 16X7.0 Aluminum Wheels
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
XGDP Universal Garage Door Opener
YAAS Build To U.S. Mkt. Specifications
Turns out that Jeep didn't put transmission coolers on any of the 98 Jeeps, even if it has the towing package. Jeep, for some reason, didn't think it needed it. The odd part is, that the part numbers for all of the cooler lines and all, are in the 98 zj parts catalog. Odd...
As far as getting her going, she needs:
  • Torque Convertor
  • Tranny Rebuild
  • Overdrive Rebuild
  • Rear Axle Shafts
  • Finish setting up the D44a
  • PCV Valve/Grommet @ valve cover
  • Install new CV Boots
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #32 of 85 Old 01-18-2011, 11:14 PM Thread Starter
csouers
Pics and videos. Got the tow hooks installed. The GOR is not broken in any place, which is surprising. Notice the nice sounds of the main overdrive bearing.
Da video.
csouers is offline
post #33 of 85 Old 01-19-2011, 02:53 PM
squashman702
1994 ZJ
  • Torque Convertor
  • Tranny Rebuild
  • Overdrive Rebuild
  • Rear Axle Shafts
Only cooler involved is the one on the side of the radiator, probably why the lines are available.
After you rebuild the tranny, make sure you install the biggest GVW plate-style cooler that you can afford. I had a 30k GVW cooler on my old 5.9. Make sure that you eliminate the check valve in the original cooler lines. Cooler supposedly adds a lot of life to the 46RE. How much are you paying for a rebuild or are you doing it yourself?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #34 of 85 Old 01-19-2011, 04:04 PM Thread Starter
csouers
I know there's a cooler in the radiator. I'm talking aux. cooler, which you already know.
From reading KOR articles and such, it seems that the threads are different between the 5.2/5.9. I am definitely thinking of putting one on it, I'm just not sure when I'll do it or what I'll put in.
We're doing the rebuild ourselves. Our neighbor is an auto transmission new/used parts dealer. We can get good parts for a decent price from him. For example, we got a governor pressure sensor and solenoid for $45. He practically gave us the sensor. The (new) sensor is a Borg Warner product and is the heavy duty unit. Very cool.
csouers is offline
post #35 of 85 Old 01-27-2011, 05:42 PM Thread Starter
csouers
Paid for a set of used shafts for the 44a and should have those next week.
Things left to do-
  • Setup and assesemble Rear-End
  • Rebuild and install transmission and overdrive
  • Install new CV-boots upfront
  • Swap remote start over to 5.9
  • Put dash back together
  • Reinstall front bumper
  • Swap trailer hitches
  • New OEM key cut
  • Install PCV system with new grommet
csouers is offline
post #36 of 85 Old 01-31-2011, 09:07 AM
jlipka98zj
Things left to do-
  • New OEM key cut
Sounds like you found the elusive PCV grommet? Just curious, what did you get and where?
'98 5.9 Limited - Got some stuff done to it...
jlipka98zj is offline
post #37 of 85 Old 01-31-2011, 09:56 AM Thread Starter
csouers
No. Unfortunately, Dad hasn't been able to get to the dealer to see if they can get it. I asked him if he thought he could get there this week. He said would try.
Got the (ring and pinion) rearend setup, but 3 of the parts (pinion nut, oil slinger, and lockpin) are for the wrong diffs. 2 parts for the d30 and 1 for d35. I'm Gonna call drivetrain today and try to order the right parts.
csouers is offline
post #38 of 85 Old 01-31-2011, 10:10 AM
jlipka98zj
Bum deal on the R&P parts.
As far as the grommet, allow me to try and help. Taken from the factory parts catalog that I happen to have for the 98 ZJ, here are some part numbers. Quoted prices are from Moparpartsamerica.com, your local dealer will probably be slightly more:
PCV Valve: 53051135 - $5.13 ($6.35 list)
PCV Grommet: 53030017 - $3.64 ($4.50 list)
Breather Grommet: 02946079 - $4.12 ($5.10 list)
Those are factory parts so they should work. I didn't have time when I was doing my Mopar cast aluminum covers to wait for the correct grommets to come in, so I just got what they had to make it work. Now I am not so sure the factory grommets would have worked anyways. Good luck and let me know how it turns out. If its not too much trouble, could you post a picture of whatever grommet you wind up using? If it works for you, it might work for me.
post #39 of 85 Old 02-01-2011, 01:13 AM Thread Starter
csouers
Oh. We have the part numbers (I have the 98 ZJ catalog as well), it's just that Dad hasn't gotten around to going. He has to go get new keys cut (the title/Jeep is in his name), so he's gonna get it/order it when he's there.
I'll let you know how it goes.
csouers is offline
post #40 of 85 Old 02-01-2011, 07:42 AM
jlipka98zj
Im just gonna shut my mouth then.
post #41 of 85 Old 02-13-2011, 01:24 PM Thread Starter
csouers
-Got the rear diff finished. Just need to fill it with fluid/modifier and mount the tires.
-Tranny parts arrived yesterday. Getting all the stuff cleaned up and rebuilding it. Overdrive hasn't been rebuilt yet, so ONE MORE week until it's all done. We've had it for almost 2 months and it's still not done...
-Put the dash back together along with the remote starter. Gauge cluster got its needles painted.
-Reinstalled bumper cover with brand new nylon blind rivets. (if anybody's interested in these, I can tell you where to get them.
-Sandblasted/painted the diff cover and tag. Looks much better than rust.
-Front shafts are out and ready for cv boot install. It's had its hubs replaced recently. They're awfully shiny.
Some pictures because I was bored...
csouers is offline
post #42 of 85 Old 02-13-2011, 02:09 PM
aircruiser
aircruiser's Avatar
dude youre so lucky! i want a niner so bad!
aircruiser is offline
post #43 of 85 Old 02-15-2011, 02:27 PM Thread Starter
csouers
I love it. 5 days til I get to take it for a spin!
All transmission parts are cleaned up and ready for a rebuild. Overdrive unit is back from our tranny guy and ready to go.
Made a write-up on how to refinish the cluster needles. Looks much better than the old faded.
http://www.jeepforum.com/forum/f13/z.../#post10983862
csouers is offline
post #44 of 85 Old 02-18-2011, 09:52 PM Thread Starter
csouers
Got the blank keys cut for free. The left key is correct...no wonder the lowes copied keys (right) didn't work!
Also got the elusive PCV grommet from jeep, but couldn't get it installed. Too damn stiff.
csouers is offline
post #45 of 85 Old 02-23-2011, 08:14 AM Thread Starter
csouers
What we did this weekend-
  • Rebuilt and installed transmission
  • Installed transfer case
  • Reinstalled PCM and overflow bottle
  • Got the pcv system in. The grommet was a *****. (I'll leave it at that...)
  • Filled everything with fluid
  • Change oil with Mobil 1 10w30 HM / Purolator One filter
  • Started it - it sounded sexy
Once we put the fluid in the transmission it started to leak. We figured it was just the overflow vent, but that seemed unlikely. Worst case scenario, we had to pull it back out and put a new o-ring on the oil pump.
WELL, dad drove it to get gas and said it shifted fine. Doesn't leak anymore.
HOWEVER, the transfer case makes noise, similar to that of a bad rear overdrive bearing. He also said that the VC appears to be bad. Looks like a 242 swap will be happening sooner than later.
csouers is offline
1998 TJ Sport Build Smitty98TJ Jeep Builds 53 06-21-2013 05:52 AM
My 1998 Jeep Grand Cherokee build thething Jeep Builds 10 02-27-2011 09:34 PM
1998 Jeep Wrangler Build Kittie Jeep Builds 35 10-18-2010 01:31 PM
My 1998 xj 2dr build JobForaCowboy Jeep Builds 40 05-03-2010 10:39 PM
1998 XJ Build YMEOFCR Jeep Builds 10 01-20-2010 07:30 PM
