1990 YJ build "Juxtapose" - JeepForum.com
post #1 of 40 Old 01-06-2014, 05:19 PM Thread Starter
thatguy383
post to come from iphone if i can find this page on there... I'm Tim, from MN
97 TJ 4squirrels, 2001 WJ Lim. Used to have a cool signature before limit
thatguy383 is offline
post #2 of 40 Old 01-07-2014, 02:22 PM Thread Starter
thatguy383
Picture in the snow was before the lift, it was parked and has gotten 2.5zone springs, cad eliminated and locked front Dana 30 with a lunchbox style. Next a koz off-road cage and 235 85 16 mud tires on steels
post #3 of 40 Old 01-07-2014, 02:26 PM Thread Starter
thatguy383
It came with these wheels but it threw **** all over the sides and broke mirrors so I said screw it, put gamblers on with 30s but then the disease set in, stock flair widths fine that's why im going tall and skinny for a change
post #4 of 40 Old 01-11-2014, 12:26 AM Thread Starter
thatguy383
Got my tires, thunderer mts 'ramger' 235/85/16
post #5 of 40 Old 01-11-2014, 12:31 AM Thread Starter
thatguy383
post #6 of 40 Old 01-12-2014, 09:57 AM Thread Starter
thatguy383
Now
post #7 of 40 Old 01-12-2014, 05:22 PM
lovett86
nice jeep
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #8 of 40 Old 01-13-2014, 10:50 PM Thread Starter
thatguy383
Originally Posted by lovett86
nice jeep
thanks
post #9 of 40 Old 01-14-2014, 10:40 PM Thread Starter
thatguy383
Installed koz off-road front cage.
post #10 of 40 Old 01-17-2014, 06:36 AM
HaskiE
HaskiE's Avatar
nice ground....? are you gonna remove that chunk later? passenger is gonna smack themselves!
why not just c-clamp your ground to the tubing if it cant get around it?
now, I'm in for the sub!
#theneverendingaxe
HaskiE is offline
post #11 of 40 Old 01-17-2014, 10:43 AM
JWBooth
I'm sure he'll leave it right there. Y'know, in case he ever needs to weld on it again.
Dig the wheels.
Please Note: My actual location is a lead box in Sassafras Cove.
-Proud Co-Founding Member of the Dirtbag Brotherhood
-Ringleader of the WhiteTrash Circus.
**LONG LIVE 4-LOW**LONG LIVE 4-LOW**LONG LIVE 4-LOW**
JWBooth is offline
post #12 of 40 Old 01-17-2014, 10:44 AM Thread Starter
thatguy383
it came off easy i moved it around even, just tacked it enough to be a good ground, yeah the ground clamp on my buddys welder wouldnt open wide enough
post #13 of 40 Old 01-17-2014, 11:20 AM Thread Starter
thatguy383
Originally Posted by JWBooth View Post
I'm sure he'll leave it right there. Y'know, in case he ever needs to weld on it again. Dig the wheels.
thank you very muchm they are 2000 era crown vic cop car wheels, 4/1/2 backspacing, 16 inch heavy duty. slight modification needed as the hub in jeeps is a tiny bit bigger
post #14 of 40 Old 01-17-2014, 12:50 PM
HaskiE
HaskiE's Avatar
I'd just use a C-clamp... no need to cut a weld just to move the ground...
how'd your floor mounts come out? have you figured out how you're going to tie into the frame? I didn't mean to kill your other thread, I guess I'm good for that though lol
#theneverendingaxe
HaskiE is offline
post #15 of 40 Old 01-17-2014, 01:07 PM Thread Starter
thatguy383
for now on each side i've got 4 half inch grade 8 bolts/nuts and as big grade 8 washers as i could fit, larger washers on the bottom almost equal to the size of the plate i was going to make.
