1990 XJ 4.0 Renix build CODENAME: MUDD - JeepForum.com
post #1 of 78 Old 03-12-2013, 04:23 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Project MUDD
Specs:
1990 Cherokee Limited 4.0L AT 156XXX
4.5" Procomp lift
31x10.50" Cooper Discoverer STT
Np242 with a loose chain
Gutted floors, bed liner painted floors with a few nice rust holes peaking to the ground
tail light busted, side marker busted, driver blinker IN-OP, no rear bumper, lift gate shocks ripped from hole
$900 purchase price
Parts to date 5/2:
$95 Rear drums and shoes
$53 Front LED 27W spot lamp
$15 3 yards of RealTree camo fabric
$35 Starter
$64 2 Epistar LED light bars
$7 6 40A realys
$12 Brake light
$26 both turn signals and marker lenses
$75 4x4" 58" steel rear bumper
$70 3"x7" 5ft steel front bumper
MuddSnapper is offline
post #2 of 78 Old 03-12-2013, 04:26 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
I have replaced the broken tail lamp and turn signal but I cant get the drivers side to flash, Pass works fine..
Installed a new stereo
Replaced the headliner with CAMO
post #3 of 78 Old 03-12-2013, 09:59 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Spent the evening in the garage trying to find the cause of my rough, low 300-500rpm surge and possibly why I am getting 6 miles to the gallon on 31's (if you can call a single car apartment stall half full of toolbox and crap a garage) Current temp 26 degrees.
This First picture of the engine bay shows 2 issues I found Both vacuum lines. The small one was broken clean and wrapped with duct tape that crumbled when I took it off, Fixed with heat shrink.
The second was closed off with electrical tape and I cannot figure out where she should be going..
Either way, after that and cleaning out the throttle body as well as I could leaving it connected and a slight adjustment of the idle screw she is purring a nice 775+-
Also found a mystery (to me) ground that had a section or wire about 20" wired into it very poorly with butt connectors so I removed and soldered the wires back together. I need to find a diagram for my relay centers and fuse panel. Its looking pretty gnarly down there and I dont know where to get started
post #4 of 78 Old 03-13-2013, 03:33 PM
jesse12296
1994 XJ Cherokee
Your injectors could be gumbed up. Seafoam it
Sent from my G'ZONE COMMANDO using JeepForum
3 inch RC Lift. 220k Trail Digger M/T 31x10.5x15 Crager Rims Dirtbound offroad Extreme Winch bumper
http://www.jeepforum.com/forum/f22/1994-jeep-cherokee-slow-highschool-build-1398809/
jesse12296 is offline
post #5 of 78 Old 03-15-2013, 12:40 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
I fixedthatvacuu m leak and the idle calmed right down. Replaced rear CCV grommet and she runs great. put 4 gallons in and have gone 35 mi and barely moved the needle to Ill update when i get a milage reading
post #6 of 78 Old 03-16-2013, 09:48 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Seafoam procedure
I picked up some seafoam tonight, Ive been told to put 1/3 in the gas tank, 1/3 in the oil, and final 1/3rd I was not told where to put it. I have used the vacuum line to the brake booster in the past but the is no brake booster on the Jeep.. Afet 50 miles I will change the oil and throw in some Oil stabilizer.
post #7 of 78 Old 03-16-2013, 10:19 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
SO I have been driving it all week to work and back. Before I fixed the vacuum leak and the grommet I was getting about 6 mpg. Now after fixing the vacuum and taking a rag to the TB to clear all the crap off. I averaged 14 this week and didnt hesitate to romp a few laps through our make shift mud slide on the way to work. Pushing 31's I am assuming thats pretty decent?
Picked up a CB at walmart that will fit in the overhead garage door opener slot. I will do a write up when I get started. I am trying to do more to the outside, but since Im still stuck in the snow Ill be tackling the inside first.
Stripped the EEP and ordered a new blacked out one. It looks good naked. Thinking about taking all the original badges off but curious to know if the side 'CHEROKEE' and the rears have the holes though the metal too. Someone has done some painting to the Jeep in its early rears because I have HUGE gouges from someone having taken off them off, J included so I know it wasn't from me taking the rest off.
post #8 of 78 Old 03-17-2013, 08:00 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Well since I have been under a storm advisory for a few inches of snow and stuck below freezing all weekend I skipped changing fluids and was stuck doing cosmetic stuff. CB still in the box, Lights haven't been delivered yet and haven't located a welder to do my floor pans yet.
I decided to begin blacking everything out, starting with the grill and headlamp bezels.
1000 grit wetordry and some Rustoleum Camo Black non-reflective paint
post #9 of 78 Old 03-18-2013, 09:31 AM Thread Starter
MuddSnapper
1990 XJ Cherokee
Finished product (covered in snow)
I feel like i should take the top trim piece and the far side plastics and paint them as well... time will tell
post #10 of 78 Old 03-24-2013, 10:30 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Pulling my buddy out in his big old DODGE
Posin
1990 Renix XJ 'Rusty Blue'
4.5" Procomp
31" Copper STT
Life begins at the end of your comfort zone
post #11 of 78 Old 04-04-2013, 12:13 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Its starting to warm up here in the Great White North.
Bought a 4x4" 1/4" steel tubing and drilled the holes and attached it to the stock bumper mounts. Painted flat back and will be mounting the CB antenna and some lights.
Finaly got my lights from China. 27W LED spot beams for $23 each (shipping included). They look great and since I was skeptical about their quality so I only ordered the front spots. Now I have to wait another month to get 4 flood beams for the roof.
IMG_20130401_135939_775.jpg   IMG_20130403_165353_840.jpg   IMG_20130403_162235_733.jpg   7550.jpg.jpg
4.5" Procomp
31" Copper STT
post #12 of 78 Old 04-18-2013, 03:48 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Finally got a break in this ice weather and got some dirt to throw around
Got my LED lights from china and got them hooked up. Got them wired to the stock fog lamp harness but I need to figure out a way to wire up both light so they arent sharing power (one shines brighter alone than both) Got a chance to seal the hole in my drivers side floor pan
4.5" Procomp
31" Copper STT
post #13 of 78 Old 04-24-2013, 08:03 PM
jesse12296
1994 XJ Cherokee
Looking Sweet man! Guessing the Injector issue is Fixed?
post #14 of 78 Old 04-24-2013, 08:19 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
So after some research and not being able to figure out how to rewire my fog lights to have constant power as opposed to needing my head lights on I just purchased 4 40A relays with harnesses ($2 ech), 2 new 36W Epistar LED light bars from Hanma auto. $32 A PIECE!! SCORE. Shipping is costing 45 but hey its direct from the manufacturer, that is still half the price of buying them from anyone else. Powering these puppies will be an 8 fuse distribution block ($14) which my current lights will get wired through.
4.5" Procomp
31" Copper STT
post #15 of 78 Old 04-24-2013, 08:28 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Yeah she is running good. I took the throttle body off and cleaned her out and she ran right after that.
4.5" Procomp
31" Copper STT
