1990 Jeep Wrangler YJ - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 1990 Jeep Wrangler YJ
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 10-22-2014, 08:30 PM   #1
wheela10
So to start I'll give a little background information. Bought this bad boy when I was 16 for my first vehicle. A 1990 jeep wrangler yj for $4500. Not more than a year later I found out one of the piston heads had cracked and the motor needed to be rebuilt or replaced. Bought a brand new Jasper crate motor to replace the previous 4.2 straight 6. Tore apart the front clip, replaced the motor and got everything running like clockwork. A couple years later I decided I was ready to start tearing everything back apart to restore/upgrade the jeep. I'll walk you through everything I did, I could have taken more pics but I still have quite a few.
wheela10 is online now   Reply With Quote Quick reply to this message
Unread 10-22-2014, 08:35 PM   #2
wheela10
First came tearing out the interior.
Unread 10-22-2014, 08:40 PM   #3
wheela10
Then the windshield frame, the fenders, dash, and steering column.
20131223_131425.jpg   20131226_163325.jpg   20131229_153943.jpg   20131229_153958.jpg
Unread 10-22-2014, 08:45 PM   #4
wheela10
Next, out came the roll bar and after removing some stubborn body mount bolts, the tub was lifted off. With two men it was a little difficult to get the tub off.
20140105_145702.jpg   20140105_155606.jpg   20140105_161745.jpg   20140105_161811.jpg
Unread 10-22-2014, 08:48 PM   #5
wheela10
Off come the tires and axles to get cleaned up.
Unread 10-22-2014, 08:54 PM   #6
wheela10
After needle scaling the frame and axles, painting them, and putting the new BDS 3.5" lift with new shocks she started to take shape again. Put the gas tank back in it, and bought some 33" master craft coursers from a buddy and threw them on.
20140208_161603.jpg   20140208_161626.jpg   20140209_153302.jpg   20140215_160200.jpg
Unread 10-22-2014, 08:56 PM   #7
wheela10
Put the new smittybilt rear bumper on and the barricade front bumper on.
Unread 10-22-2014, 08:57 PM   #8
wheela10
Cleaned the grill up as well.
Unread 10-22-2014, 09:00 PM   #9
wheela10
Finally the fiberglass tub, hood, and fenders came in from shell valley.
Unread 10-22-2014, 09:03 PM   #10
wheela10
Got to work cutting out the firewall. Used a piece of cardboard to trace the firewall from the original tub and convert it to the fiberglass. This method worked surprisingly well.
Unread 10-22-2014, 09:08 PM   #11
wheela10
Started to put the body onto the frame and line everything up. This was a pain in the rear. Got it fit together nicely though!
Unread 10-22-2014, 09:11 PM   #12
wheela10
After this was done, it was torn back apart and sent into a local paint shop for an orange crush finish. While this was going on we painted up the roll bar with some bedliner.
Unread 10-22-2014, 09:13 PM   #13
wheela10
Then we finally got the beaut back! It was love at first site
Unread 10-22-2014, 09:19 PM   #14
wheela10
Without hesitation the beast started going back together. Put in some new speakers in the rear in-between the roll bar and wheel well. Also put the rest of the rear bumper on. Brand new seats were set too.
20140622_162604.jpg   20140629_154613.jpg   20140629_154628.jpg   20140706_152510.jpg   20140706_185441.jpg
Unread 10-22-2014, 09:23 PM   #15
wheela10
Put in the new auto meter jeep gauges. The wiring was a nightmare because we were going from the gauge cluster to individual gauges. They look amazing though, the headaches were definitely worth it.
