1989 Comanche Rebuild - Page 7 - JeepForum.com
post #91 of 126 Old 10-23-2012, 08:36 AM Thread Starter
Jankoid
Forgot to add this. Discovered the other day that it has cruise control. It doesn't work, but it has it. I always assumed it didn't have it because, well, why would it? That is pretty awesome though that it does have cruise control since this is my daily driver. I haven't even begun to diagnose it yet, but I would like to get it working relatively soon. If anyone knows any common fixes for the early XJ/MJ cruise controls I would love to hear them.
Also, I GOT THE AIR CONDITIONING WORKING!!! Doesn't matter much at this time of year, but that is going to be NICE next Summer. It was just a blown fuse (more like a melted fuse). On high it blows cold enough to freeze your brains out.
Jankoid is offline
post #92 of 126 Old 10-23-2012, 10:07 AM
rymanrph
1997 MJ Comanche
If it isn't a 44 (I need to double check but I'm pretty sure it is) I'm going to find an 8.25 with 3.55s.
If you need an 8.25, I already have one set up for a Comanche with 3.55 gears just in case you need one.
rymanrph is offline
post #93 of 126 Old 10-23-2012, 10:11 AM Thread Starter
Jankoid
Did you ever get shafts for it? That would be awesome, then I wouldn't have to weld perches on the XJ axle. I'm not going to be wheeling this Jeep so the strength increase of a 44 over an 8.25 is a non issue.
Jankoid is offline
post #94 of 126 Old 10-23-2012, 10:19 AM
rymanrph
1997 MJ Comanche
Yep, I have shafts for it now. I would reuse the e-brake cables from the 35 because they are longer than the XJ 8.25 cables. The only thing I don't have are the drums. The ones that came with it were no good.
rymanrph is offline
post #95 of 126 Old 10-23-2012, 10:25 AM Thread Starter
Jankoid
The drums are the same as what I have now arent they? I can just pull them off of the axle I have now and swap them over. Is it open or lsd?
I need to try out my 4wd. I discovered one of the lines going to the vac disco was unplugged, so hopefully that is the only problem. Not that I'll ever really need 4wd anyways, but since I have it I want it to work.
Jankoid is offline
post #96 of 126 Old 10-23-2012, 11:10 AM
rymanrph
1997 MJ Comanche
I can't say if the drums will swap over or not; I'd have to check the part numbers. Its open. There is a write up about how to shim the vac disconnect so its always engaged. That way you don't ever have to worry about it.
rymanrph is offline
post #97 of 126 Old 10-23-2012, 11:45 AM Thread Starter
Jankoid
If the drums won't swap over I have a 27 spline 8.25 (3.07 gears so it is useless to me) that I can steal the brakes from.
As long as the 4wd works I don't mind having the vac disconnect. If it is there I might as well benefit from it. Like I said, hopefully it is just because the plug was undone. If the vac disco is a problem, I'll just find a non disco housing when I switch to 3.55s.
Jankoid is offline
post #98 of 126 Old 02-10-2013, 05:30 PM Thread Starter
Jankoid
Going to Gulches ORV in Laurens County, SC next weekend. Don't want to waste money on fuel to haul my LJ 3 and half hours down there, so I'm taking the Comanche. I'm just going to ride b seat, but they do have some easy trails, so I want to get the 4wd working. Just getting the truck to the campsite requires 4wd at that place. Going to try shimming the vac disco and see if that solves the problem. Also going to try getting the cruise control to work. It would be nice to have on such a long drive.
Jankoid is offline
post #99 of 126 Old 02-10-2013, 06:55 PM
tyvanwie
I love MJ's and this is a nice one
Sent from my iForum using JeepPhone
tyvanwie is offline
post #100 of 126 Old 02-10-2013, 06:59 PM
yamaha225
You could just rig up or buy a posi lock and make it manual. That's probably what I would if i had one.
1997 TJ, 2.5 4 cyl, AX-5, Hella 700's
Black Jeep Society, Eagle Scout Jeepers
yamaha225 is offline
post #101 of 126 Old 02-10-2013, 07:26 PM Thread Starter
Jankoid
Thanks!
Originally Posted by yamaha225 View Post
You could just rig up or buy a posi lock and make it manual. That's probably what I would dogfighting had one.
I would, but I don't plan on having this axle in here for too much longer. I want to swap in an axle with 3.55s, the stock 3.07s suck. When I swap the rear axle, I'm going to put in a later model HP30 without a vac disco.
Jankoid is offline
post #102 of 126 Old 02-11-2013, 11:31 AM
yamaha225
Thanks!
Ah I see, we'll good luck getting it working
post #103 of 126 Old 02-11-2013, 12:02 PM Thread Starter
Jankoid
Actually I just finished shimming the shift fork. Was actually really easy. Haven't driven it yet, but both front tires spin together now!
Jankoid is offline
post #104 of 126 Old 02-11-2013, 12:05 PM
yamaha225
Nice!
post #105 of 126 Old 02-11-2013, 12:08 PM
rymanrph
1997 MJ Comanche
I've still got that rear 8.25 whenever you're ready for it. Be sure to get some shots of the MJ in action.
rymanrph is offline
1989 YJ Resto/Mod dukesrn Jeep Builds 2 01-13-2011 09:50 AM
FREE 1989 comanche sport projectmayhem Jeep Builds 5 09-08-2010 08:07 PM
1989 YJ 2.5 Underhood pics please fishwater2 Jeep Picture Requests 0 10-09-2009 08:12 AM
1989 Yj jeeps4now Jeep Builds 6 03-26-2009 09:05 AM
