#1 | |
1988 YJ w/ Mopar 360 :) *built a full cage*
Started out as a stocker 88 YJ with the 4.2L engine, 5speed manual, np231, dana 30 front, 35 rear.
Engine was tired so my brother rebuilt the engine for me while I watched and helped where I could (not good with engines). Installed a more aggressive cam and pistons. Installed a Motorcraft carb. and HEI ignition. Ran like a raped ape! Installed a 3.5" BDS lift kit and slapped on some 33x12.5x15Mud Rovers. Ran it like that for a year or so than the craziness began. Picked up a set of axles: Dana 44 and Ford 9" out of a 78 F-150. Went threw them and installed 4.56 precision gears R&P, for the front I threw in a Detroit limited slip (tru torc? Its the gears...), for the 9" I put a Detroit locker, 31 spline moser shafts, custom disc brakes, and a Dayton pinion support. Tore the jeep down to the bare frame. Ground and wire wheeled the rust off the frame and used Chassis Saver paint. Fabricated my own shackle reversal, stretched the front ~2", and also cut out the flimsy C channel in the rear and replaced with box steel. Installed a Mopar 360 V8 out of a 78' Magnum with a carb, summit block huger headers, TF-727 trans, dana 300 thats flipped and twin sticked. than I sucked water in the trans so I rebuilt that with a stage 3 B&M shift kit, 2,000rpm stall torque converter. Later on I blew the engine so rebuilt that for more power I'm not in the process of doing body work, and I just stretched the rear 6" back, installed a Fuel cell, and working on getting a full cage built. I also ran the intake through the firewall into the passenger compartment behind the rear speaker. how it sits now ![]()
#2 |
Sounds beastly dude, nice video clip!
#3 |
thank you! I'm wanting to go true duals instead of a Y pipe. Mainly to help cut down on the heat issue I have that builds under the hood. The driver side pipe wraps under the oil pan and connects to the passenger side. This is a biig heat source. If I go duel and run it straight back on both sides and install an H pipe, this will clear a lot of that up.
#4 |
Was out in the garage all yesterday and got a lot of work done on the wiring and re-installation of my MSD box and megasquirt computer.
Also you can see where my intake is routed to ![]() ![]() ![]() ![]() ![]() Also I used rustoleum semi gloss black and brushed it on to the firewall to get ride of the yellow. |
#5 |
Just built a full cage .... for pics visit http://s2.photobucket.com/albums/y39/Plato2k5/
#6 | |
looks good
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S 1987 YJ Laredo |
#7 |
you gonna repaint it, i almost got a red rocket from that sound clip lol
#8 |
haha thanks guys.
They pics are huge that is why I just posted a link to my photobucket......didn't feel like going through the hassle of resizing them. Yes I am going to repaint it. I have a metallic canyon blue that I'll shoot. I'd love to do black but I already bought this paint. If i don't like it, I can use it as a nice base. I would love to put a true dual exhaust with an X pipe, but I have other more important things to focus on first. I do need to get the exhaust to dump out from under the jeep as you get annoying exhaust drone. I'll have more pics up of other mods within a few weeks again, thanks for the compliments! |
#9 |
Just painted the jeep Metallic Canyon Blue.
#10 |
Wow its def time for some bigger meats.
#11 |
RC 4.5" with ADJ. Trac Bar 33" Pro Comp Xtreme M/T on Cragar Soft 8's FlowMaster HD Super 44 with Dual Turndowns 2 12" Alpine Type R's - 2600W Amp |
#12 |
ha I know! I'm not sure how well my front dana44 will hold up though. Maybe 37 or 38s
#13 |
I swear i'll update this over the weekend. I have a list of updates
#14 |
Was that a digital tach in the space above the glove box. If so where did you get it?
89 YJ with a 5.2l V8, 5 Speed ax-15, RC aals giving me 1.5" of lift plus 1" lift shackles giving me a total of 2.5" of lift, 31x10.5x15 A/T tires, no carpet, rinolined tub, Family style roll bar. My motor swap thread |
#15 |
Nice job! That thing sounds wicked!
I think thats A/F ratio.
Daniel 1 Ton WJ Build In Progress The Daily: 2011 Chevy Cruze Eco - Bone stock and 37 MPG Newest Addition: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers and more to come... YouTube. - My Video Channel facebook. - Wheeling pictures and videos. The Jeep Wave. Bringing it back. For Sale Now: - Clayton 6" Springs - Bilstein 5100 Series Shocks (6" lift) For Sale Later (once I get my swap done): - Brand New WJ JKS Track Bar - Stock WJ Suspension Components - KOR 2.5" BB Lift - Many WJ Drivetrain Components (PM for details) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
