1987 Comanche Long Bed Engine Rebuild. - Page 3 - JeepForum.com
post #31 of 49 Old 09-11-2013, 11:38 AM
ZSXJ430
2015 KL Cherokee
What caused the issue in the first place? I had a toe amputated in the winter this year...that sucked and it still causes me problems.
'15 Trailhawk - Eco Green, V6, Nav, Tow, Cold Weather. Wrangler All-Terrain ProGrades 245/70R17.
ZSXJ430 is offline
post #32 of 49 Old 09-11-2013, 03:09 PM Thread Starter
supertaco
Well that's a long story. but the short version. I fell through a ceiling, spread my arms out to stop my fall, i grabbed a light blub on the way down, landed on my back / hips. The light bulb broke in my hand and lacerated both flex-or tendons in my ring finger,/ 2 years and 5 surgeries later and countless months in physical therapy. I have 2 semi functioning fingers my ring fingers last joint doesn't contract. and my pinky's middle joint doesn't contract. however the tendon attached to the last joint is strong enough to do the rest of the fingers jobs and pull the finger into a fist
supertaco is offline
post #33 of 49 Old 09-11-2013, 05:34 PM
ZSXJ430
2015 KL Cherokee
Ouch! That sucks man. Glad it is making progress. I had my right foot crushed by a 5,000 lb plus pound Air Force pallet on the ramp of a C-130. They had to cut off my ring toe. I start therapy next week (finally). It broke my big toe and caused serious trauma to the rest of my foot. Now I have to wear wide toe shoes, can't squat long and can't pivot on my right toes...the ones that remain. So I kinda feel your pain. Hope you heal up and get back at the build man.
ZSXJ430 is offline
post #34 of 49 Old 09-12-2013, 07:46 PM
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Nice work! Looking forward to seeing the progress of your Comanche!
My Jeep Build!
Nik-Nak is offline
post #35 of 49 Old 09-15-2013, 04:02 AM Thread Starter
supertaco
well i got my stitchs out friday... and the motor mounts bolted down on a saturday! pix soon
post #36 of 49 Old 09-19-2013, 03:12 AM Thread Starter
supertaco
here we go!
sorry for crappy pix . left my cell camera at home this was from a crappy evo not my droids 8 megapixel . long live droids!
for those of you who havent tried. putting a motor in on grass sucks. straight up sucks. soon however. my stepdad / engine builder guy is moving to a place with a real shop on his property. than .. than the suspension begins!!
post #37 of 49 Old 09-21-2013, 10:14 AM
lovett86
thats a nice looking engine
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #38 of 49 Old 09-22-2013, 08:28 PM
ZSXJ430
2015 KL Cherokee
Coming along well man! Looking good. I am not that far along...but you know I am in a different order than you are. How is the hand feeling?
ZSXJ430 is offline
post #39 of 49 Old 09-25-2013, 04:35 AM Thread Starter
supertaco
hands doing ok.. sadly its contracting again. but hopefully enough splinting will keep it straight. or at least a no worse..
post #40 of 49 Old 09-26-2013, 07:23 PM
ZSXJ430
2015 KL Cherokee
Hope you can get healed up man. The build must go on.
ZSXJ430 is offline
post #41 of 49 Old 10-07-2013, 08:47 PM
ZSXJ430
2015 KL Cherokee
Status check...
ZSXJ430 is offline
post #42 of 49 Old 10-21-2013, 03:04 AM Thread Starter
supertaco
ok sorry for the lack of updates. lifes been happening. heres the low down. motor runs STRONG.. when it runs. now it doesnt want to start. it ran for about 10 minutes. header paint smoked off of course. i drove it around the property and it died. i assumed it was out of gas. got back from the gas station. crank crank crank. turns out. no spark. ( timing light hooked up to coil or spark plug one = no results ) so i think its part of my relay area ( i hear them clicking uncontrollably sometimes ) or my coil it self. it got left in the rain one day.
post #43 of 49 Old 10-27-2013, 03:08 AM Thread Starter
supertaco
ok after some serious head scratching im at a loss. im getting no spark. from the coil. the coil has power going in. ive replaced the coil. swapped brains. tried a new(used) CPS that may or may not be good. switched out all the relays. cleaned the c101 connector. still just cranks cranks cranks. no spark. plenty of fuel. it ran great for 20 minutes. now its just dead. ideas???? ive got 2 good grounds ( dipstick to battery , and firewall to intake manifold). and i get continuity from the battery to the fire wall so i know its grounding there. is there another ground im missing somewhere? some fuse or fuse-able link that will kill spark? or are both my CPS's bad? the both read 200 - 235 ohms on the meter. and when plugged in and cranking the engine. i read .2 and .01 vac on my meter. somewhere i read that they should put out .5 vac ? any renix gurus out there care to chime in ??? help !
post #44 of 49 Old 10-27-2013, 07:37 AM
ZSXJ430
2015 KL Cherokee
Damn, I got nothing. I just dropped my engine in last night.
Have you checked all the sensors? Crank position, throttle position, cam position? Maybe they are tied into the computer??
ZSXJ430 is offline
post #45 of 49 Old 11-19-2013, 05:03 PM
ZSXJ430
2015 KL Cherokee
Dude how are you coming along on your build?
ZSXJ430 is offline
