1983 CJ7 Rebuild - Page 2 - JeepForum.com
post #16 of 134 Old 07-26-2012, 11:33 PM Thread Starter
Crawlerkid
Saving up for a 3 core rad, shocks and axle universals (or whatever you want to call them.)
Found a 1985 Mercedes 300CD with a blown shock tower, running. Talked to the guy and he said it's mine for $300. So the CJ7 will be getting the OM617 diesel swap in the near future (I'll be using an external slave ax15 for the tranny and a clocking ring to mate to the d300)
Crawlerkid is offline
post #17 of 134 Old 08-02-2012, 07:36 PM Thread Starter
Crawlerkid
Bought the Mercedes, and man did it take forever to get out. All 4 wheels were rusted tight so we had to jack the front of the car up and dig trenches for the dolly to ride under the front tires
Got it home though
The starter is set and won't crank but the engine spins free so it's not set up.
image-593134476.jpg   image-1541718587.jpg   image-2652353111.jpg   image-181723871.jpg   image-1630729096.jpg
post #18 of 134 Old 08-02-2012, 07:49 PM
8pitcher
8pitcher's Avatar
Way to go grant.
8pitcher is offline
post #19 of 134 Old 08-11-2012, 07:20 PM Thread Starter
Crawlerkid
The Mercedes purrs like a kitten! Chased the rats nest of wiring and she fired right up! Got the front driveshaft under the jeep, and got to take it for its first drive! Not it's time for getting the brakes in and fuel system buttoned up. Then all the little things will surface.
So stoked! I can't wait to get it on the road.
Also, the adapter from Mercedes 4x4 adapters mates the om617 to an ax15 bell housing and clutch. According to what I've read, my existing t4 has the same pattern as the ax15, with the difference potentially being in the pilot shaft diameter. I have a lathe so I can turn a bushing to adapt the two if need be. Using my t4 is attractive because I don't need to purchase a clocking ring for the ax15 and setup for hydraulic clutch, new tranny mounts, ect. Obviously the ax15 is superior to the t4 in terms of durability but the Benz engine makes comparable hp to my current setup but with less tq, so I think I'm fine for a while.
Let me know what you think!
post #20 of 134 Old 08-11-2012, 07:23 PM
8pitcher
8pitcher's Avatar
Stick with the t4 and save up for a better tranny later.
8pitcher is offline
post #21 of 134 Old 08-28-2012, 02:08 PM Thread Starter
Crawlerkid
Almost on the road, but need a rad, shocks, and some odds and ends.
Does anyone have some used shocks that will work with my 2.5" lift they would be willing to sell? Used is okay
post #22 of 134 Old 09-13-2012, 01:27 PM Thread Starter
Crawlerkid
Decided to go a different route, and pulled the engine. My shocks and radiator came and fit great, though I will need to buy/make some shackles to give me another 1" up front
I bought the Mercedes engine adapter and will be installing it ASAP.
post #23 of 134 Old 09-16-2012, 09:50 PM Thread Starter
Crawlerkid
Pulled the engine from the Mercedes, power washed and cleaned it, and installed the adapter. Next up is mocking mounts! The MB om617 is about 4 inches shorter than the I6, and roughly the same weight. I will have to clearance the oilpan, and maybe do a little more lift up front. The mounts just about line up to the jeep mounts too
image-1792717873.jpg   image-2267260027.jpg   image-1407267554.jpg   image-4249081738.jpg
post #24 of 134 Old 10-05-2012, 09:52 PM Thread Starter
Crawlerkid
Mounts were made and engine was dropped in. Wiring was converted to the simple diesel, and just about everything was put back in. I made some shackles that raised the front a good 2-3 inches and now I have an inch of room between the pan and front diff. (Still need to clearance pan.) I have the shutoff solenoid in, and the glow plug relays in, and it's now turn key. She makes over 80PSI of oil pressure cold. This engine is a TRUE mechanical diesel, as you can pull the battery out, pop one hose off the shut off solenoid, bump start and you're off. The mercedes' shut off is vacuum operated, which is kinda neat to me, as you shut the key off and a second later the engine quits (a slight delay in between.) To those that bash it for being gutless off the line I have to disagree, a simple screw turn on the pump makes a HUGE difference. ("Ups" the off-boost fuel delivery.) I actually forgot my e-brake was on and was turning around with one of the rear tires dragging, and that's just idling, it's a pretty torquey engine for only 3L.
My first drive! No idea what youtube did, but it tried to fix the camera shake and made a few parts really wavy.
post #25 of 134 Old 10-06-2012, 05:51 AM
78FordF150
1983 CJ7
I like it. Not many 17 year olds can take on a project like that.
Good luck on getting it finished up.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #26 of 134 Old 10-06-2012, 05:52 AM
243
1978 FSJ Cherokee
Very, very cool
Dave's 78 Build
243 is offline
post #27 of 134 Old 10-06-2012, 06:18 AM
kw89425
^^x2
86 cj7 496 powered 465/205 ton axles 38.5 boggers
kw89425 is offline
post #28 of 134 Old 10-06-2012, 07:50 AM
8pitcher
8pitcher's Avatar
Lookin good grant. Hope to see ya on the road some day.
8pitcher is offline
post #29 of 134 Old 10-06-2012, 01:49 PM
Turtle71
1983 CJ7
Good job! Looking forward to more progress.
My 83 CJ7 Build:
Turtle71 is offline
post #30 of 134 Old 10-06-2012, 05:43 PM
contdevelop
nice
contdevelop is offline
Carter Carb BBD rebuild on 1983 CJ7 caryfh Jeep CJ Forum 19 12-10-2016 12:16 PM
1983 Jeep CJ7 Rebuild Thread JKM3134 Jeep CJ Forum 65 11-20-2016 08:31 PM
1983 CJ7... Need some rebuild advice! TheGunny Jeep CJ Forum 5 12-02-2010 07:18 AM
My 1983 Jeep Rebuild shortgoroper Jeep CJ Forum 2 05-26-2010 10:22 AM
1983 CJ5 top MJSJeep Jeep CJ Forum 6 09-06-2004 08:07 PM
