1980 CJ-7 Refrurb on the cheap.. well, sorta cheap. - JeepForum.com
post #1 of 16 Old 08-24-2010, 02:30 PM Thread Starter
knowlwk@snowhill.com
1980 CJ7
I've had my CJ-7 for about 6 years now.. when I first picked it up, it ran ok but needed some bondo and paint. I spent 6 or 8 weeks fixing it up, filling rust holes with bondo, tub liner, rattle-can rustoleum paint, etc. I was actually pretty happy with it and have been driving it to work at least once a week (25 miles one way, so can't afford it as daily driver).
Well, the sun was starting to take its toll, and the rust was catching up with me, so it was time to sell it, or do something about it.
I took a few pictures along the way... not really documenting it properly, but its turning out nice enough that I'm kicking myself for not making a better record.
So here we go.. if I can do it, anyone can...
Before I began... these shots are from when I was putting out a Craigslist ad, so they are the most flattering angles. There is a lot of rust hiding under the rhino liner (I didn't know that till I started stripping it off), and there are 1/8 inch plates bolted over the rust spots under all the roll cage mounts.
Also.. the pictures don't show the rust bubbles all around, the 6 years old bondo, or the totally shot windshield frame....
'80 CJ7, 258 W/Autojuicer, MC 2100, TFI, SummitRacing CDI, MORE SRS, Moser 1-pc, YJ tub on 1" body lift, YJ family cage.
knowlwk@snowhill.com is offline
post #2 of 16 Old 08-24-2010, 02:37 PM Thread Starter
1980 CJ7
So I was actually just going to do the windshield frame, and maybe upgrade to Yj power brakes... next thing you know.. she's in pieces all over my yard...
post #3 of 16 Old 08-24-2010, 02:40 PM Thread Starter
1980 CJ7
I didn't take too many before shots.. but you get the point.
I started with the frame... wire wheeled all the rust and scale, welded in a new rear crossmember, picked up a shackle reversal kit off the net, new stainless brake lines and fuel lines, etc.
post #4 of 16 Old 08-24-2010, 02:44 PM Thread Starter
1980 CJ7
Frame started to look pretty nice.. although I didn't paint it right, and the coating is a little on the brittle side.. too late now.
post #5 of 16 Old 08-24-2010, 02:48 PM Thread Starter
1980 CJ7
Cut all the rust out of the tub, and started welding in new metal... didn't take long to realize I'm not a welder, and the tub has too much rust in all the seams to ever get ahead of it... fate steps in and gives me a decent YJ tub and fenders for a good price...
post #6 of 16 Old 08-24-2010, 02:54 PM Thread Starter
1980 CJ7
The next step was to learn how to paint... umm.. and sand and sand and sand some more. I didn't get any pics of the original hood, but after stripping off the paint and the hidden surprise bondo, it looked like someone beat it with a hammer. Took me two weeks of evening to get it presentable.
I painted everything Arctic White (Omni AU MAE w/hardener), out in my yard, using a 21 gallon harbor freight compressor and a $14 Hf paint gun. yes there are bug legs, tree bark, moth wings, etc in the paint.. but it actually turned out pretty good... much better than I expected.
post #7 of 16 Old 08-24-2010, 02:57 PM Thread Starter
1980 CJ7
Then the fun begins.. putting her back together. Much more tedious than taking her apart...
post #8 of 16 Old 08-24-2010, 03:02 PM Thread Starter
1980 CJ7
and SHE LIVES!
Still have a number of things to finish.. gotta get the hood on this week, and get some glass put in the windshield frame... but she runs. I've only got about a mile on the clock, and that was doing 5mph around the back forty, so I don't know how the new shackle reversal handles at speed, but I'm very pleased that she still runs. I had a hell of a time getting all the lights to work again; seems I may not have lined the ignition switch up correctly when I rebuilt the steering column... took about 4 tries to get it correct.
All in all, I think I have about 350-400 hours in it so far over 5 months, and maybe $3k if you include the extra tools I needed to buy (that's my story and I'm sticking to it.)
Here is how she looked this weekend.. loading the kids up for our first test ride.
post #9 of 16 Old 08-24-2010, 03:07 PM
BPJOOP93
looks nice so far. what did you use to paint it, and are you painting in the sand????? howd that work out for ya??? just askin cause i painted mine in a garage all sealed up and STILL got small marks on it.
BPJOOP93 is offline
post #10 of 16 Old 08-24-2010, 04:12 PM Thread Starter
1980 CJ7
Yep... painted her out in the yard... wet sanding is your friend. Equipment-wise I used a $159 harbor freight 110v compressor and their $14 hvlp gravity feed gun. Protective gear was a SAS Bandit disposable mask (2 actually), goggles, tyvek shoot suit, headsock and gloves.
Paint was PPG Omni AU MAE acrylic enamel with hardener. Arctic White. I sprayed it over a sealer coat of white Omni Epoxy primer. I went with the acrylic enamel because I was originally going to shoot it without the hardener (iso's), but ended up getting the hardener anyway mostly for the extra durability and fuel-proofness.
I painted it out in the yard, as it was going to be too difficult to move all the parts around (I painted it in parts). I was never looking for a show quality finish, just something shiny and durable. I got what I was looking for and the white really hides the paints imperfections. I did have one panel that had some solvent-pop and should really be resprayed, but I'm going to keep it as is for now.
I did end up with a fair amount of trash and several runs in the paint, but since I went with a solid color, a little wet sanding and some rubbing compound has taken care of most of my issues. The paint is no where near perfect, but it was my first paint job and I like it. Would I do it again... probably not.. LOL too much sanding to keep me interested
post #11 of 16 Old 08-31-2010, 08:43 AM Thread Starter
1980 CJ7
Just about done....
post #12 of 16 Old 08-31-2010, 10:34 AM
dooboy2112
Looking good....
2000 Grand Cherokee Limited
2000 Wranger Sport SOLD
1979 Wagoneer SOLD
dooboy2112 is offline
post #13 of 16 Old 12-16-2010, 08:10 AM Thread Starter
1980 CJ7
An updated pic, new shoes all around...
post #14 of 16 Old 12-16-2010, 09:32 AM
ZeroGravity
Are you rear lens upside down?
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #15 of 16 Old 12-16-2010, 11:52 AM Thread Starter
1980 CJ7
They were in those shots... found my mistake when re-wiring the lights.. couldn't get my blinkers and brake lights to match what the control stalk was doing till I turned them around and then all was well... LOL
Project Cheap Jeep tj98 Jeep Builds 16 05-10-2014 06:00 PM
99' White LCG Build by a Cheap Guy MattGATRTJ Jeep Builds 282 10-27-2013 11:59 PM
Lifting for cheap jeepskeet22 Jeep Builds 6 04-29-2010 12:51 PM
My little build-up for cheap randyandy Jeep Builds 0 03-12-2010 03:10 PM
Saving Whitey - 97 TJ Cheap Jeep Build. Muratus Jeep Builds 32 09-25-2008 10:26 PM
