1979 cj-7 - JeepForum.com
post #1 of 7 Old 11-10-2015, 06:08 AM Thread Starter
tuxthetitan
1979 CJ7
1979 cj-7
I bought this jeep from a guy down the road. It had been sitting for a long time and most of the seals and gaskets had rotted out and it wouldn't run. I took about 6 months overhauling and rebuilding it. Now I've got something really fun to drive and the cool factor is off the charts. I have a few sets of tops for it and I have a set of steel doors that I'm trying to sell. I don't have much use for them here.
My next step is installing the BDS 2.5" suspension lift and putting in a new steering stabilizer and wheel spacers.
11755702_10153433751049827_1444022655324752478_n.jpg   11752603_10153433751394827_8912096437374930752_n.jpg   11745702_10153433751804827_3145674216405102562_n.jpg   11030271_10153433751209827_7566906014980526268_n.jpg   11143639_10153433752059827_4755232633738927797_n.jpg
11866204_10153500021889827_4590690957577826499_n.jpg   11888117_10153500021554827_7815356193295337957_n.jpg
tuxthetitan is offline
post #2 of 7 Old 11-10-2015, 07:26 AM
Wisconsinite
1981 CJ5
Nice looking CJ7 you have there. Don't tell me you got ALL the gauges to work??
Wisconsinite is offline
post #3 of 7 Old 11-10-2015, 08:41 AM
dadzrig
Good job. Looks good!
Sent from my SM-G386T1 using Tapatalk
dadzrig is offline
post #4 of 7 Old 11-10-2015, 10:20 AM
84jeepcj7rock
Great looking CJ
84jeepcj7rock is offline
post #5 of 7 Old 11-10-2015, 10:31 AM
GAPATRIOT
1977 CJ5
Looks good!
GAPATRIOT is offline
post #6 of 7 Old 11-12-2015, 07:07 PM Thread Starter
tuxthetitan
1979 CJ7
Haha it was a pain but I got them all working. I'm an electrician by trade so it just took a lot of troubleshooting. I've noticed that the grounding on these is very finicky. I ended up grounding all the gauges to the dash using a screw to bare metal then I ran and extra strand to a spot I sanded down to bear metal on the floor pan. This seemed to fix all the grounding issues.
As for powering everything I just ran all new leads in parallel for powering gauges and ran a separate circuit for the lights.
The only thing I'm still troubleshooting is the gas gauge. I put a new fuel sending unit in and I don't think its calibrated correctly. It runs out of gas when the gauge is on 1/2-3/4. I guess I just need to bend the float or something. I'll search around on here for some info.
Latest updates on the CJ are new black hood hardware, black high flow scoop. I rebuilt the carb and finished running most of the engine wiring so it doesn't look like a rat's nest under there.
Next move; Install dual battery tray, Install BDS 2.5" suspension lift, Weld receiver tube onto the exsisting U shaped hitch and Find some rear bumper corners.
Thanks for all the compliments!!
post #7 of 7 Old 01-11-2016, 06:09 AM Thread Starter
tuxthetitan
1979 CJ7
I finally installed my suspension lift. I didn't take into account that the stock suspension was sagging so bad, it turned into about 6" higher than when I got it. It's a BDS 2.5" lift with 3/8" BDS Shackles front and rear. I wasn't to bad to do by myself and looks damn good.
12507268_10153792924719827_8355776298201555666_n.jpg   12494960_10153792925099827_6124808866345337665_n.jpg   12510395_10153792924994827_8373021964692860330_n.jpg
