1975 CJ 6 on the skinny.... - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 1975 CJ 6 on the skinny....
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 04-24-2012, 10:09 PM   #31
castorriver
Subscribed!!
Registered Nurse Jeep Club Member #1 (I think...
Winter is coming.
castorriver is offline   Reply With Quote
Unread 04-26-2012, 02:33 PM   #32
danc9
1975 CJ6
26 April 2012
Wire wheeled the drivers side this morning. It is far worse than the passengers side for sure. Got the rear quarter done......
Till next time, DAN
danc9 is offline   Reply With Quote
Unread 04-27-2012, 02:25 PM   #33
danc9
1975 CJ6
27 April 2012
I didn't feel like working on the tub today, so I played with the front end. I got a good start on it!
DAN
Unread 05-02-2012, 04:36 PM   #34
danc9
1975 CJ6
2 May 2012
I ordered the gasket set for the exhaust this morning. Bolted on the rear cross member on the frame and got it wire wheeled and primed. The rear support for the bed got welded in. That got primed and I got a little seam seal spread out.
good day!
Hope to get the exhaust started tomorrow. Maybe some top coat on the bottom of the tub!!!!!!
DAN
Unread 05-03-2012, 04:08 PM   #35
danc9
1975 CJ6
3 May 2012
Wire wheeled the easy stuff on the back of the frame. Got that primed. Flipped up the tub and got the bottom painted! Had a little paint left so I painted the bottom of the front fenders as well......
Need to go pick up my manifold gaskets!
DAN
Unread 05-05-2012, 06:46 AM   #36
danc9
1975 CJ6
4 May 2012
Got the manifolds bolted back on. Picked up a muffler and got that bolted on....
DAN
Unread 05-08-2012, 12:45 PM   #37
danc9
1975 CJ6
8 May 2012
Worked on getting the carb cleaned up. I'll pick up a rebuild kit Friday, and hope to bench test the engine this week end. It's Mothers Day, and I don't know if I'll have time!
Got the shocks cleaned up as well, but didn't get any pictures of them....
DAN
Unread 05-11-2012, 11:09 AM   #38
danc9
1975 CJ6
11 May 2012
Got the carb rebuilt. Picked up a new lower hose.....and hooked up the battery!!!! Turns over good. No fuel.....pulled the fuel pump, worked it by hand, filled it with gas......got fuel!!!! No fire.... checked the coil, checked out O.K. Pulled a plug, double checked the fire, none. Pulled the distributor cap, the points were not grounding.....sanded the points, put it all back together and it fired the very first time!!!! Runs smooth, smokes a little....over 100000, it's O.K.!!!!!
I know I'm jumping around a lot, but with as much to do as I have, OH Well!
Really need to get back on the tub. I saved the worse for last. I hope the easy stuff has me a little more practiced at the body work stuff. Just some days I have to do some thing that makes me feel like I got some thing done!!!
DAN
Unread 05-11-2012, 08:39 PM   #39
G Beasley
Sawzall Surgeon
G Beasley's Avatar
Beautiful work on the tub .
Ball joints are teh debil !
Just another LJ build
June 2013 Moab Trip
Wrangler tub trailer build
G Beasley is offline   Reply With Quote
Unread 05-14-2012, 04:15 PM   #40
danc9
1975 CJ6
14 May 2012
It stopped raining! I think we got about two inches in total. Didn't feel like pulling out all the tools, so I just cleaned the frame a little more and got that primed as well as the breast plate.
"...my tub may be a bit wavy, but it's all steel!" ⁰lllllll⁰
DAN
Unread 05-15-2012, 03:05 PM   #41
danc9
1975 CJ6
15 May 2012
I got back on the tub today, worked on the front drivers side...
Hope to get the tub done this week, we will see....
DAN
Unread 05-16-2012, 03:35 PM   #42
danc9
1975 CJ6
16 May 2012
Good day!!!
Got some more seam sealed and primed. I think I see light at the end of the tunnel here, and I like it!!!!
DAN
Unread 05-16-2012, 08:45 PM   #43
G Beasley
Sawzall Surgeon
G Beasley's Avatar
A small amount of skim coat and you will have a slick surface to paint . Do you think you have hit the 50% mark yet for new steel ?
June 2013 Moab Trip
Unread 05-16-2012, 10:00 PM   #44
BennettZJ
wow looks great cant wait to see it all done
BennettZJ is offline   Reply With Quote
Unread 05-17-2012, 05:05 AM   #45
82CJ5er
great work so far, can't wait to see more updates.
82CJ5er is offline   Reply With Quote
