1975 CJ 6 on the skinny.... - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 1975 CJ 6 on the skinny....
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Unread 03-29-2012, 05:05 AM   #1
danc9
1975 CJ6
This is my first jeep. I drove my little brothers CJ 5 in the early eighties and I loved it! I was looking for a CJ 5, but timing and cash price leaned me towards the CJ 6. My first thought was to cut it down to a 5, but then a little more study and sleeping on it I decided to keep it a CJ 6.
Well... AMC 258 I6, T - 14 three speed trans, Dana 20 transfer case, Dana 30 front end, and a Dana 44 rear. I'm going to keep the front drum brakes, and only replace initially what has to be. It will be a fair weather seasonal, that is I'm not going to invest into doors and top. I plan on still building a CJ 5, and it will have a hard top and doors, but that is another thread!
So far I'm really happy with what I got. There is plenty of rust but nothing that can't be gone through. The whole rear end (body) was rusted out and the PO did some strange tail gate and 4X4 bumper with tire rack thing that only made it worse. Enough said, pictures are worth a thousand words.....
This is how I found it. Look to me like it was begging for me to take it home, so I did.
Again, the rear end is in bad shape. I'm going to have to repair it before I can even get the tub off. I'm going through a lot of little things. The wiper motor needed a wire repaired and insulated. The blower motor was hard to turn, a few shot of wd40 and some spinning by hand loosened it up. Hook it to the battery as well and spins great!
The speedo works so I decided to black out the bottom and clean it up. I copied the idea from another image I found. The fuel gauge had already been replaced with a dash mount, as well as the temp. I like the gauges vs the warning lights.
Enough for now, plenty more to come, DAN
danc9 is offline   Reply With Quote
Unread 03-29-2012, 05:38 PM   #2
danc9
1975 CJ6
29 March 2012
Got to repair the air box today. I laid a layer of fiberglass on the inside edge. Built up the low spots with JB Weld, and laid another layer of glass on top. Still taking things apart and I'm pleasantly surprised at all the fasteners. I've only had to cut off three so far. (Knock on wood) Got the wiring harness out. Got my steel for the rear end repair, hope to do some welding Saturday. There are only 500 holes drilled in this poor thing, going to take a while to get them all filled.
Plenty more to do,
DAN
Unread 03-30-2012, 04:05 PM   #3
danc9
1975 CJ6
30 March 2012
Estimating how much steel I'm going to need to get the tub were it should be. I'm coming in at about 32 square feet, and I wonder how much is in a CJ 6 to begin with? All the wires are out. Steering column is out, hood is free. Excited about working on the rear end tomorrow...
DAN
Unread 03-31-2012, 12:41 PM   #4
danc9
1975 CJ6
31 March 2012
Got started on the rear end. Ran a one inch square tube for the top, and covered it with one panel. Things were going great then I ran out of wire! Oh well, feel like I got something done today.
I'll get some more wire!
DAN
Unread 03-31-2012, 01:08 PM   #5
djflyy
Adventure Is Out There
djflyy's Avatar
Looks like lots of potential is to be had here. Props for the restoration of a classic Look forward to seeing more.
Boston Jeep Build Thread
North Shore Jeeps Website
Originally Posted by StuddMuffinz View Post
dj, it amazes me how your jeep can always make me happy in the pants <3
djflyy is offline   Reply With Quote
Unread 04-02-2012, 04:37 PM   #6
danc9
1975 CJ6
2 April 2012
Got me some wire today and away I went. I love tinkering with body work. It is very time consuming, but when you back up and look at it....Wow! This tub is going to take a long time to finish, but I think it's worth every minute!
Till tomorrow,
DAN
Unread 04-03-2012, 04:02 PM   #7
danc9
1975 CJ6
3 April 2012
Did a little fab work today. First I started on the drivers seat bracket. The PO had some 3/8" stuff I set out for the scrap man, weighed in about 40 lbs or so. (Maybe he weighed a little more than me?) Bent the tubing and blind welded the bottoms, then I started on the passenger side. I seen a picture of a pivot tubing somewhere on line and liked the idea. So on mine the center of the tube pivots for lifting off the under seat storage. They both now get 1 1/4 X 3/16 inch tying the brackets together, and something to bolt the seats to.... DAN
Unread 04-04-2012, 02:54 PM   #8
danc9
1975 CJ6
4 April 2012
No images today..........I got the trans and differential cover off. The Dana 20 shifter was very loose, the shifter base where it is welded to the pivot bearing is broke loose. (Easy fix) Cut off a few body mount bolts, and cut out the bad parts of the dash. Covered it all up before it began to rain.....
DAN
Unread 04-05-2012, 04:17 PM   #9
danc9
1975 CJ6
5 April 2012
I got the front end off today. The bottom center is in bad shape, same as the rear end.
Played with an old crane winch I've had for a hundred years, bench tested it and it works just fine.
Good day,
DAN
Unread 04-05-2012, 04:28 PM   #10
Sundowner
Part-Time Swami
Sundowner's Avatar
Man, what a project! Officially Subscribed. I love the 6's...so, good choice on your part.
The build, the gear, and the mileage: The Wasteland Survival Guide
Sundowner is online now   Reply With Quote
Unread 04-06-2012, 03:44 PM   #11
danc9
1975 CJ6
6 April 2012
Worked on the front end today. Got the center bottom of the grill worked out...
The left fender was the worse. Several cracks and dents got repaired...
The right was not as bad...
They are ready to start wire wheeling tomorrow. Need to finish the seat brackets then as well...
Till then,
DAN
Unread 04-06-2012, 05:07 PM   #12
pure82cj
Sweet! Keep up the good work!
pure82cj is offline   Reply With Quote
Unread 04-06-2012, 05:40 PM   #13
y2julia619
Wow, what a project!! Lookin' good
y2julia619 is offline   Reply With Quote
Unread 04-07-2012, 10:23 AM   #14
danc9
1975 CJ6
7 April 2012
Worked on the seat brackets today....
Till next time..... DAN
Unread 04-07-2012, 10:26 AM   #15
Ripper3494
AUTASTIC
Ripper3494's Avatar
amazing work, crawled. cant wait to see where this goes
build thread:
http://www.jeepforum.com/forum/f22/9...-spud-1218315/
1997 ZJ limited - BONE stock
http://www.jeepforum.com/forum/f12/a...te-up-1301614/
http://www.jeepforum.com/forum/f12/t...ation-1417686/
RC vs BDS
http://www.jeepforum.com/forum/f12/r...s-bds-1461555/
Ripper3494 is online now   Reply With Quote
