1972 cj5 rebuild from frame up - Page 12 - JeepForum.com
post #166 of 2041 Old 08-19-2012, 01:46 AM
Dadamsnv
1977 CJ5
Originally Posted by 8pitcher
The hat on my head. But I usually work at night from bout 9-1 or 2
Same here, that's about when its tolerable
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #167 of 2041 Old 08-19-2012, 11:07 PM Thread Starter
8pitcher
8pitcher's Avatar
Gettin the trailer back tuesday or Wednesday so I will be gesturing the frame out to get blasted finally. Ordered bearings and seals for my axles yesterday. Did I say that yesterday? I don't remember haha.
8pitcher is offline
post #168 of 2041 Old 08-21-2012, 10:27 PM
straightsixjeep
If you ever need a hand let me know. Your build sounds awesome, cant wait to see it run
straightsixjeep is offline
post #169 of 2041 Old 08-21-2012, 10:30 PM Thread Starter
8pitcher
8pitcher's Avatar
Ok I will let you know. Any crazy experience with anything like this?
8pitcher is offline
post #170 of 2041 Old 08-21-2012, 10:34 PM
straightsixjeep
What are you working on?
post #171 of 2041 Old 08-21-2012, 10:37 PM Thread Starter
8pitcher
8pitcher's Avatar
Rebuilding the engine and axles.
8pitcher is offline
post #172 of 2041 Old 08-21-2012, 10:39 PM
straightsixjeep
I have basic knowledge, tearing an engine down, cleaning it, then putting it back together with new parts. Are you going with new rods, pistons,...? Also, what are your plans for the axles? I have a local jeep friend whos literally a master mechanic, his cj3 has the same axles as your cj. He put a locker in his amc 20, my locker should be here tomorrow
post #173 of 2041 Old 08-21-2012, 10:44 PM Thread Starter
8pitcher
8pitcher's Avatar
No new rod and pistons they are all good. I'm doing valves and cleaning it all up and painting it all. And axles I'm just rebuilding because they were all rusted and regearing from 2.73 to 3.54
8pitcher is offline
post #174 of 2041 Old 08-21-2012, 10:51 PM
straightsixjeep
Heres some info - http://www.jeepforum.com/forum/f9/re...tj-d44-970997/
and
http://www.jeepforum.com/forum/f8/ho...a-30-a-990109/
You will need new carriers for the front and rear if you regear. If you want a locker now is the time to do it. If you get a full locker it will completly replace the carrier, where the aussie locker I bought only replaces the spider and side gears. And are you just doing new valve seals and what not or are you replacing the valves? Is the engine already torn apart?
post #175 of 2041 Old 08-21-2012, 10:59 PM Thread Starter
8pitcher
8pitcher's Avatar
and
I have carriers from a spare d30 and amc20 that were 3.54 gears so I'm swapping those from the narrow to the wide axles.
And I'm just doing the valve seats and cleaning them up. Engine is torn apart been apart for about a month and a half.
I have no money for lockers. No job currently. But I do want one
8pitcher is offline
post #176 of 2041 Old 08-21-2012, 11:15 PM
straightsixjeep
Well if you already have the heads off it should be real easy. Do you have a valve spring compressor?
post #177 of 2041 Old 08-21-2012, 11:18 PM Thread Starter
8pitcher
8pitcher's Avatar
Not yet.
8pitcher is offline
post #178 of 2041 Old 08-21-2012, 11:25 PM
straightsixjeep
Iv got one, just got to find it lol. It clips on to the spring then you twist the top and it compresses. Should just be some keepers you have to remove then the spring slide right out. Iv replaced springs in another engine, have yet to tear into the xj. Im thinking about putting new lifters in soon.
post #179 of 2041 Old 08-21-2012, 11:30 PM Thread Starter
8pitcher
8pitcher's Avatar
Ya 20$ and I will use it when I rebuild a 258 I have laying around.
8pitcher is offline
post #180 of 2041 Old 08-21-2012, 11:34 PM
straightsixjeep
258s are great engines, I had a weber on mine
1972 Jeep Commando Build accidentprone Jeep Builds 37 12-17-2014 04:37 PM
My XJ Rebuild HankyDanky Jeep Builds 17 01-07-2013 05:30 PM
1972 jeep truck torn on color and motor swap med511 Jeep Builds 0 09-02-2011 08:51 PM
83 CJ8 On Frame Rebuild Pelirojo73 Jeep Builds 7 01-04-2011 02:15 PM
1972 Newbie nichboy Jeep Builds 4 02-20-2010 11:54 PM
