1970 CJ5 Help with new build !! - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 1970 CJ5 Help with new build !!
The Boss is away but Erin is here to STAY with a F.Y.S. SaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 09-17-2014, 06:44 PM   #1
J-reg
1970 CJ5
I picked up a 1970 CJ5 few days ago and by far its the oldest jeep I've owned thus far. My questions are: What's the most common Problems with jeeps this old? Is the "Dauntless" 225 a motor worth keeping or is a engine swap in order? What is the best lift kit to get for a jeep this old? Its has a 4 peed with a granny 1st. I want to use it for some trail/roc crawling. Any help would be great.
Thanks
J-reg
J-reg is offline   Reply With Quote Quick reply to this message
Unread 09-17-2014, 07:32 PM   #2
84jeepcj7rock
I had a '69 CJ5 with the Dauntless. Swapped in a Ford NP435 and it was a great combo
The 225 has a really heavy flywheel which allows it to chug through a lot especially if it's geared right. I loved that engine till I tried to get fancy and put it on propane. My '69 had a read D44 with 2 piece axle shafts like the AMC 20. Swapped the front and rear out for '72 axles with open knuckles in front, 1 piece axles and stock 4.27 gears
As for lifts, I like to keep them low and stable. I'd hate to see an old CJ cut up, but if the body isn't great then start cutting. Those springs are really short and when you put a lot of arch in them, they get really stiff.
84jeepcj7rock is offline   Reply With Quote Quick reply to this message
Unread 09-17-2014, 08:05 PM   #3
J-reg
1970 CJ5
Ya I had a CJ7 that I lifted about 12'' and is was a stiff mother. So your leaning to the motor swap idea? if so I was thinking of doing a newer 5.7 "hemi" along with all the rest of the running gear maybe getting an 08 or newer donor truck(s). As for the lift I also built a XJ with a 6.5 long arm kit witch I loved so I'm with you low and stable. When it comes to cutting it up I would rather not but the front fenders are kinda askin for it since they are a little holy in all the right places but cant do the front with out doin the back.
Unread 09-17-2014, 09:27 PM   #4
J-reg
1970 CJ5
And on a side note my gauge cluster is like this oOo "little gauge big gauge little gauge" and two more little gauges right under the other little gauges. right around the steering column all the pics I find on the webs are in the center? is this common or not thanks.
