1964 CJ6 long term restomod - JeepForum.com
 9Likes
post #1 of 149 Old 10-07-2014, 07:44 AM Thread Starter
y2k-fxst
1964 CJ6
Finally decided to start my build thread. Where I started from was a plan to build a Cummins powered CJ6 from scratch. Original plans was for an aluminum tub with tube fenders a 4bt with a NV4500 and NP205.
Well I came up with a 1964 CJ6 sitting on a 1978 full size Ford Bronco frame. With no motor, trans or transfer case. Looks like previous owner jumped into a project and after starting figure out it was not going to work.
The person I bought it off bought it for the 40" tires that was on it, the put the rest up for sale.
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
Last edited by y2k-fxst; 07-02-2017 at 04:44 PM. Reason: Photobucket removed picture
y2k-fxst is offline
post #2 of 149 Old 10-07-2014, 07:52 AM Thread Starter
y2k-fxst
1964 CJ6
Think one of the biggest problems the original builder found was the original position of the motor in the Bronco would be way forward of position in the jeep body. To move the motor back would also mean that the trans cross member would have had to be moved back also. This would remove support from the front suspension mounting points. In my mind this would make the entire suspension unsteady. In this picture I am pointing to the original radiator support mounting location. The cross member shown in front of the grill should be under the front of the motor in the Bronco.
y2k-fxst is offline
post #3 of 149 Old 10-07-2014, 07:58 AM Thread Starter
y2k-fxst
1964 CJ6
Was hoping to keep the outside of the CJ6 looking as stock as possible but, after measuring I came to the conclusion that with the length of the 4bt in there I would only have 1.5" behind the grill for the radiator, and the inter cooler would have to be mounted in front of the grill. Since I don't have a frame yet I have decided to go with a later front clip to gain an extra 3" behind the grill.
y2k-fxst is offline
post #4 of 149 Old 10-07-2014, 08:11 AM Thread Starter
y2k-fxst
1964 CJ6
I will be reusing the 9" Ford rear end that was under the Bronco frame narrowing it to match my front axle but, the Dana 44 under the front has to go. Has the pumpkin on the drivers side, wrong for a CJ, also in 1978 Ford went to a large casting that incorporates the inner-C and the wedges for the mounting points for the radius arms that makes it very difficult to narrow.
The solution, bought a 1977 Wagoneer shell that still had that axles under it. Took the front Dana 44 and steering box then scrapped the rest. After scrapping the shell my total cash out for a Dana 44 and a steering box was a whole $26!
I am saving the front hubs, rotors, and lockouts to make my 6 lug Jeep axle a 5 lug. With the help of some Chevy spindles. Wish I could have found a 1976 Wagoneer, they should have the small bearing spindles I need to run the Ford hubs.
Last edited by y2k-fxst; 07-02-2017 at 04:48 PM. Reason: Photobucket blocked picture
y2k-fxst is offline
post #5 of 149 Old 10-07-2014, 08:17 AM Thread Starter
y2k-fxst
1964 CJ6
Here I have the tub unbolted from the frame, probably a good thing they never got this thing on the road. The tub was only held on with 4 x 3/8" carriage bolts and 6 x 5/16" carriage bolts! Wish I had taken a picture of the dash, someone had welded a piece of sheet metal over the factory dash, than chopped a large square hole to fit gauges out of a 1990's Chevy in it.
Last edited by y2k-fxst; 07-02-2017 at 04:49 PM. Reason: Photobucket blocked picture
y2k-fxst is offline
post #6 of 149 Old 10-07-2014, 08:24 AM Thread Starter
y2k-fxst
1964 CJ6
So here is where I currently am, I now have a tub sitting on saw horses that I am hoping to save, and both axles that both need narrowed. Once I make sure there is no measurements that I need I am planning on selling the front clip that came with the CJ6 as there is probably some body need them.
The more I have done the more areas that I am seeing on the tub that has Bondo on it.
Last edited by y2k-fxst; 07-02-2017 at 04:52 PM. Reason: Photobucket blocked picture
y2k-fxst is offline
post #7 of 149 Old 10-10-2014, 04:06 PM Thread Starter
y2k-fxst
1964 CJ6
Finally came up with my motor yesterday, bought a complete running truck. This way I have all the small parts that I may or may-not get buying just a motor. Now I have a VE pump 4btaa, both axles that need narrowed, and the tub that needs some body work. Pile of parts getting bigger, just hope I get it all together before I get frustrated!
Paid about $1000 less than just a motor is going for currently on eBay, Figure I have over $1000 worth of parts and scrap I can sell to boot.
Last edited by y2k-fxst; 07-02-2017 at 04:56 PM. Reason: Photobucket blocked picture
y2k-fxst is offline
post #8 of 149 Old 10-12-2014, 06:51 AM Thread Starter
y2k-fxst
1964 CJ6
Got more Bondo ground out of the body than I figured would be there. Figured out whoever did the bodywork last had a torch, braising rods, and a large supply of Bondo. Probably ground out 2 gallons worth! What is sad is they put so much heat into the body with the torch the panels that are not rusted are so warped that I am contemplating replacing most of the steel!
They warped the bod so bad that they did not even have to grind the mounts for the spare tire carrier clear down. They are sticking out still over 1/8" and the Bondo was over the top thick enough they could not be seen.
Here they were not even able to fill in the patch completely, This is where the front of the drivers side wheel tub mounts to the body.
Last edited by y2k-fxst; 07-02-2017 at 05:00 PM. Reason: Photobucket blocked picture
y2k-fxst is offline
post #9 of 149 Old 10-12-2014, 06:56 AM Thread Starter
y2k-fxst
1964 CJ6
Originally Posted by y2k-fxst View Post
Finally came up with my motor yesterday, bought a complete running truck. This way I have all the small parts that I may or may-not get buying just a motor. Now I have a VE pump 4bt, both axles that need narrowed, and the tub that needs some body work. Pile of parts getting bigger, just hope I get it all together before I get frustrated!
Had a guy ask me today about buying the body for a storage shed, Quoted him $1500 for what I don't use. He told me to get a hold of him when I ready. That would put me down to $875 for the motor and adapter plate. I don't need the Chevy adapter plate since I am planning on running a Dodge trans, have seen them go for $300-$500 on eBay!
y2k-fxst is offline
post #10 of 149 Old 10-13-2014, 10:21 AM Thread Starter
y2k-fxst
1964 CJ6
Drove the donor truck home 110 miles yesterday. As good as the little 4bt drags that big thing around. can't wait to feel it in a little CJ!
y2k-fxst is offline
post #11 of 149 Old 11-01-2014, 07:47 PM
axxxgijoexxxa
Wow you got lots of work ahead! Should be a sweet jeep with a 4bt!
1988 YJ Laredo (Ford 5.0, AOD, np231, teraflex ssye, 8.8)
axxxgijoexxxa is offline
post #12 of 149 Old 11-02-2014, 11:58 AM Thread Starter
y2k-fxst
1964 CJ6
Just wish someone would do a re-pop on the CJ6 extension panels. Been looking at the ones I have, looks like they will be the hardest part to fix. Waiting for the money to go further, wife's gas buggy got replaced last month. Kind of hurt the check book.
y2k-fxst is offline
post #13 of 149 Old 11-10-2014, 10:51 AM Thread Starter
y2k-fxst
1964 CJ6
Doing more sanding, between the 3-5 layers of paint and the rattle-can DIY bed liner inside the tub, on the firewall, and underneath have decided to get the tub media blasted. Have located some people locally that do it, one even is portable and will soda blast right in my driveway. Waiting to hear back from them as to the cost.
y2k-fxst is offline
post #14 of 149 Old 11-27-2014, 08:52 PM Thread Starter
y2k-fxst
1964 CJ6
Well this will slow me down even more than I already am! Going to be a long 6 weeks!
y2k-fxst is offline
post #15 of 149 Old 11-29-2014, 03:41 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Ouch - How did you do that?
NashvilleTJ is offline
