1959 fc 150 - JeepForum.com
post #1 of 18 Old 08-25-2015, 08:50 AM Thread Starter
mjf251
1997 XJ Cherokee
1959 fc 150
Hi All, Ive been a member on here with my multiple cherokees a few times, but I am now working on a 1959 Willy's Jeep FC150. Is there any specific area on here for them? Or anyone with experience with this model? I picked the build section since its rocking a Ford 302 and is currently under some construction.
Thanks all!
mjf251 is offline
post #2 of 18 Old 08-25-2015, 11:02 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Willys are grouped with the early era jeeps here > Early era Jeeps
But since we all like the classic Willys, you might as well post some pictures here and make this a build thread.
***Chris***
chris87xj is offline
post #3 of 18 Old 08-25-2015, 11:41 AM Thread Starter
mjf251
1997 XJ Cherokee
Excellent, I'll take some good ones tonight. So the story is my father in law bought the truck in the late 90's from a farm that had a giant field spraying rig attatched to it. He restored the truck back into a normal pickup, but felt it lacked the power it deserved, and looked like it was going to fall over on the stock 150 frame. So he got an fc170 chassis and whacked it down to the 150 length. He then mated a Ford 302 crate engine to the factory t90 3 speed and Dana/Spicer D18 transfer case, as well as installed a 2 speed warn overdrive. I think it has a Dana 53 rear, not sure on the front axle.
The truck was hardly driven, then parked in the Barn in 2008, until I pulled it out 2 weeks ago for a car show and was told it could stay in my garage, so I'm sort of its caretaker for the foreseeable future. I'll attach more pictures of it this week. It's a bit of a bear to drive...ill go over my plans/ things i need to repair in another reply.
1997 Jeep XJ Cherokee 2door 5 speed
1959 Willy's Jeep FC 150 w/ Ford 302 and T90 3 speed
mjf251 is offline
post #4 of 18 Old 08-25-2015, 11:46 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Wow that's in awesome shape!
***Chris***
post #5 of 18 Old 08-25-2015, 12:09 PM Thread Starter
mjf251
1997 XJ Cherokee
Overall its in very good condition. The only paint blemishes are from when a tree fell on the barn....which caused a florescent light inside the bard to fall off the roof and scratch the front of it. The interior needs some work. Just some finishing.
My to do list:
It overheats, probably do to the small radiator and big engine....trying to work that one out flushed everything out new thermostat going to see what happens
Shifting...it doesn't like to. There's a home made linkage to side shift the t90 that i need to iron out. Granted the t90 I hear isnt always the easiest to shift anyway
Speedo, and gas gauge don't work. I think the speedo it out of a CJ. Gas tank came out of another car, so sender might need some work. Might install new guages and rewire the dash
Interior:lots to do here. Missing door panels, heater box,(not all of them had one), the dog house needs paint, as well as some insulation since it gets red hot. the Valve cover sits an inch away from your side....so its hot in there. And it has no seat belts for the driver.
Weatherstrips are shot
front drive shaft just ever so slightly hits the starter the way its positioned.
----So thats just a small list. I document more as I go. I washed a boatload of dirt out of it so far from sitting with the windows open. I'll post up more pics tonight.
mjf251 is offline
post #6 of 18 Old 08-25-2015, 12:13 PM
Jim1611
Jim1611's Avatar
I'm really looking forward to this!
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #7 of 18 Old 08-25-2015, 12:51 PM
cj7ox
Sounds like an awesome project! Looking forward to your progess reports!
cj7ox is offline
post #8 of 18 Old 08-25-2015, 01:44 PM
84jeepcj7rock
Love these things. Def want to see more.
84jeepcj7rock is offline
post #9 of 18 Old 08-26-2015, 08:36 AM
JShwin14
That thing is awesome! Post up more pictures!
My '93 YJ Build ->
JShwin14 is offline
post #10 of 18 Old 08-26-2015, 09:04 AM Thread Starter
mjf251
1997 XJ Cherokee
more pictures
The bed was home built by my father in law, one of the best builders i've ever seen. There's a picture of the valve cover breather in relation to where you sit as well. And finally, a couple at the car show i made it to.
mjf251 is offline
post #11 of 18 Old 08-26-2015, 09:12 AM Thread Starter
mjf251
1997 XJ Cherokee
pics didnt load....lets try this again....
20150815_144847.jpg   20150815_170954.jpg   20150825_200514.jpg   20150825_200607.jpg   20150825_200712.jpg
mjf251 is offline
post #12 of 18 Old 08-30-2015, 08:35 PM Thread Starter
mjf251
1997 XJ Cherokee
So tonight Ive encountered my first major issue again....OVERHEATING. I need a lot of help on this one guys, so im taking suggestions. The attached pictures show then engine, and the radiator. As you can see I have a very small area to work with. The radiator in it now looks like its fairly thick, but the truck still over heats. ( I've already repaired it once with solder when the water neck cracked, then threw a sealer over it.) It wont over heat right away, It'll run for a while before it does.....but it always does. My father in law had a theory on this that i'm going to share to see what your opinions are. Because the radiator is so small, and the engine so big, he believes the water pump is pushing the coolant too quickly through the radiator. To slow the flow down he had pinched the lower radiator hose, which restricted flow, but the truck didn't over heat as badly. what is you all's take on this?
And what cooling options should I try? I found a 3 pass radiator that I think might fit it out of another style willy's truck.....or should I attempt to remote mount one somewhere? and if so, where? Thanks for the assistance!
20150830_202433(1).jpg   20150830_202433.jpg   20150830_202440.jpg   20150830_202445.jpg
mjf251 is offline
post #13 of 18 Old 08-31-2015, 06:55 AM
Lamer321
It sounds like it is working, just not as efficiently as it could...
Maybe its not that you need more radiators, but perhaps its poor condition of the current radiator?
- is it "clean water" coming out of it?
- clean water going into it?
- build up on the forward side prohibiting/blocking air flow?
- Temp sensor blocked up? these don't take much to cause them to deviate from proper function.
Check the cooling requirements for the motor vs cooling potential of the radiator?
just my 2 cents. you mentioned you replaced the temp sensor, was the old one dirty? fouled? damaged?
Lamer321 is offline
post #14 of 18 Old 08-31-2015, 07:53 PM Thread Starter
mjf251
1997 XJ Cherokee
Well i think its just that eventually the max efficiency is reached and it just over heats from that point. I flushed the system and replaced the tstat. I think the issue is the radiator is about 16" x 16". the cooling tunnel just isnt big enough for anything bigger. I Think the next thing im going to try is getting a radiator thats longer, so I get more surface area. Im checkign the clearences now and will post my solution. In the mean time, if anyone has any tips or help let me know
mjf251 is offline
post #15 of 18 Old 09-01-2015, 11:26 AM Thread Starter
mjf251
1997 XJ Cherokee
Possible solution
after spending half the night looking at radiators and learning more about then than Ive ever known before.....I think i came up with a design in my head. I'm going to take an aluminum radiator from a 1966 Ford mustang. (closest dimensionally I could find)...cut the brackets off...fab up my own....and install a shroud and Air damn to divert more air to it. Between the bigger tubes in the radiator and more air that should hopefully help. Naturally, I'll be documenting everything in this post in the coming weeks.
mjf251 is offline
