1950 Willys Truck re-rebuild - Page 93 - JeepForum.com
post #1381 of 1674 Old 09-28-2013, 11:03 PM Thread Starter
50wllystrk
Originally Posted by Jeff88 View Post
Awesome!
Nice view out of your shop door too!
Wait, are we still in flashback mode on the pictures?
Just so I can follow along, what is the status of the truck today? Is it all primed and in mock up still?
Yes, still in mock up. I'm trying to focus on every possible thing or change I want to make before paint stage. For example, I keep looking at the bed from the view of opening the drivers door. I just kept thinking the inside bed sides need something. Finally I got an idea, what sucks is if I'd stop getting ideas I'd be painting by now. On the other hand, if I didn't do all the extras now, I'd regret not taking a few extra months to finish the truck exactly how I want it to be.
This is a picture from Thursday night. To some this may seem like an awful lot of work assembling most of the truck but now is the time to check all panel alignment and bolt hole alignment.
Same night with the hood on.
Progress is real slow right now, I'm trying to detail many areas to make assembly after paint easier.
Don't worry, I've still got pics of the process of a few areas that may become helpful in the future.
50wllystrk is offline
post #1382 of 1674 Old 09-29-2013, 10:22 AM
berettajeep
1947 CJ2A
That is awesome!
'74 Cherokee 401
berettajeep is offline
post #1383 of 1674 Old 09-29-2013, 10:31 AM
LA-Sahara
So have you decided on shark teeth for the grill?
LA-Sahara is offline
post #1384 of 1674 Old 09-29-2013, 11:47 AM
Jeff88
I saw a 1951 chevy pickup for sale at a farm near me yesterday.
Cool old truck, first thing I noticed was how crappy the rolled tubes look from the back with no caps.
Jeff88 is offline
post #1385 of 1674 Old 09-29-2013, 12:44 PM Thread Starter
50wllystrk
berettajeep, Thanks, it's pictures like these that help keep me motivated knowing I'm heading in the direction to get the end result I'm looking for.
LA-Sahara, I wish I could have settled on a design that I could live with that wasn't too far off the beaten path. I was also having issues getting the look from the front to look as good from a side view. I did however go to a grill that is different from the one I had pictured before. This one is a true '57 grill, the other one was a '55-'56. It is a matter of personal preference and I'm not saying this one looks better as a matter of fact I have a fit issue that I have to live with. I do like the idea that is is designed on a horizontal aspect vs a vertical aspect, this can help the truck look lower and wider.
Sometimes swapping grills can be a unique thing to do but in the case of the '57 chevy truck if you do a google image check, many people have made the swap, so by going back to the '57 grill, it still identifies the truck as a '57 and it is almost more unique to stick with the original style.
Jeff88, I have to agree, it's like an unfinished area when they are left open. Although those looking to keep a truck all original, open is the right way to go.
post #1386 of 1674 Old 10-01-2013, 10:46 PM Thread Starter
50wllystrk
How about we move to the interior, the project I thought would take a couple weeks, then lasted 2 months.
When I look at other interiors I often find a bench set out of a newer truck with all it's foam and cushion. I'm sure they are very comfortable, but not the look and feel I'm looking for.
A couple issues were since there is no tunnel, the shifter is gonna sit way too low. Same with the seats, I've got to raise them up about 6 inches.
Although I'm using 2 bucket seats I'm gonna build one large frame to support both seats. Using one large frame will help keep the height of both seats the same.
I've tried to use the original seat bolt holes to keep from drilling any extra holes in the floor. Plus the original holes have reinforcement plates from the factory in place already.
post #1387 of 1674 Old 10-02-2013, 01:42 PM
Jeff88
Are those seats fixed position on the frame, or do they have sliders?
Might be difficult if you had a short driver that needed to pull the seat up?
Jeff88 is offline
post #1388 of 1674 Old 10-02-2013, 10:46 PM Thread Starter
50wllystrk
We're in good shape, the seats are on tracks that will allow them to move forward 4 to 5 inches. I haven't attached the adjuster lever yet. I was afraid with the amount of times I've put in and removed the seats that I would bend them.
I'm gonna post a pic from almost exactly 1 year ago. The truck had an after market floor shifter and had the same problems that many people have. Since the truck has a flat floor and the seat sits up quite a bit, it either needs a long shift handle or a way to space the shifter up to match the seat height.
I'm hoping this was meant to be a quick fix in the past, they used long lengths of 5/16" threaded rod to raise the shifter base.
Here is the situation I am in now with the new shifter, way too low.
Now I do realize there are long handle shifters out there but they do not offer one thing I want in my new shifter, I want one that has a ratchet mechanism capability.
Here is where making the frame work one continuous base helps, I'm able to build forward to create my own tunnel. I used the wood blocks to get a feel for the exact height I want the shifter to be, then build from there.
For this interior I wanted the shifter to be the main focal point. I also wanted to build the tunnel, I wanted to create a feel that as the driver you are in your own cockpit so to speak. A far different feel than it did when it had a bench seat.
post #1389 of 1674 Old 10-03-2013, 10:40 PM Thread Starter
50wllystrk
When you look at a finished build the details never show through, such as the thought in design to get everything to fit together.
Such as in this seat frame that goes forward into a tunnel. I didn't want one solid framework, I wanted to be able separate the tunnel and the seat frame.
You can see the attaching points where the tunnel meets the seat frame. I've also taped some small 1/4" pieces on the bottom of the framework, I know later I'll want to put down carpet and sound deadner, by prefiguring for the thickness of these materials I won't back myself into a corner later.
The shifter lever goes way forward when in park. In the above picture it's in neutral. In the next picture it's in park, once I noticed this issue I made the shifter mounting plate angle downward in the back. The plastic covering that comes with the shifter has extra material so I was able to trim it for the angle difference.
post #1390 of 1674 Old 10-06-2013, 10:43 PM Thread Starter
50wllystrk
The tunnel became a main focus once the seat height and location was figured.
In the back of my mind I knew the was one item I wanted to have in this truck.... cup holders, yes cup holders. I have another car that I enjoy abusing once in a while, problem is, I don't have a safe place to keep a cup and it's a manual trans, so once in a while I go thirsty since I need my right hand for shifting.
I had space in front of the shifter, perfect, 2 cup holders.
I started with a piece of construction paper then used the paper to use the torchmate to cut the sheet metal.
After bending the sides and trimming the back to match the shifter cover, I have cup holders.
Good picture of how the frame work ended up when done. You can also see towards the front on the floor I welded a stud to the floor, then a flange on the tunnel to attach to to the floor.
I bought a bead roller to add to the look of the sheet metal, it did ok, my original plan was to paint the tunnel.
post #1391 of 1674 Old 10-07-2013, 07:33 PM
Jeff88
I used to have a little BMW 318is and it was a fun little car to drive, and it had no cup holders.
Who would make a car with no cup holders? BMW I guess.
They are imperative.
Jeff88 is offline
post #1392 of 1674 Old 10-07-2013, 07:34 PM
Jeff88
Double post due to Slowwwwww Jeepforum.
Jeff88 is offline
post #1393 of 1674 Old 10-07-2013, 10:25 PM Thread Starter
50wllystrk
I ponder the year that they became common in cars, mine is a 1965, cup holders, what the heck are those??
The next part of the build is one that is commonly forgotten til it has to be addressed, the fuse block. If I figure it's location now I can save my self from drilling and scratching the firewall. As a matter of fact, I don't want to use the firewall anyway, I want it accessible, yet up out of the way.
The only solid piece of metal under the dash in this area is the brake pedal pivot mount, this will work.
I'm making the fuse block bracket in two pieces, I hate trying to pry wires out of the way to remove something. With a two piece bracket I can install and remove the pedal pivot later when needed.
Now with the fuse block backing in place.
And done. Now I have no holes and no extra wires going through the firewall, I have space all around to run the wires where needed.
post #1394 of 1674 Old 10-10-2013, 01:04 PM Thread Starter
50wllystrk
One item that needed attention was the fit of the front bumper. Since the front frame has been changed to a Camaro, the front frame extensions had to be fabricated to accept the original bumper mounts.
When I got the truck the bumper ends were pointed more downwards than I preferred, also I wanted raise the bumper about a half inch.
I ended up cutting the mount from bottom to top, this allowed me to reset the height by welding the two halves together at different places. This change and trying to rotate to ends of the bumper changed the angles where the bumper holes met the bumper mounts.
What I'm referring to is... I want the mounting tabs of the mounts to be flush and true with the bumper, if the tabs and the bumper do not meet flush, as I tighten the bumper bolts I will bend the bumper at the mounting holes and crack the chrome in that area.
Here is the bracket after the cuts to change it's profile, I've changed the height with the long cut and by cutting the tabs and weakening them I was able bend them as needed to match the bumper itself.
After welding and filling, you all know I went to the 4 1/2" grinder with a 40 grit flap disc. All I need to do now is sandblast to remove all grinding marks and get a good surface for primer to stick to, then satin black paint.
post #1395 of 1674 Old 10-14-2013, 09:14 AM Thread Starter
50wllystrk
Next on the interior was door panel work. The original door panel is steel with an outward bead pressed into it. This adds rigidity to the panel and also has a nice looking shape how it follows the panel.
Most people, including how I was going to redo it was to paint and maybe accent the bead with a pinstripe or two tone paint.
I'm not trying to go overboard with my changes on this truck but I felt I could try something different. I also knew I wanted black in the cab. With the amount of chrome and polished aluminum in the cab I didn't want to bring the silver paint into the cab, it doesn't have the "pop" that the polished and chrome items have.
I've getting more into the usage of stainless steel, it requires some labor but the end result it a nice polished finish that lasts a long time. Stainless it will be, labor intensive, you betcha, but the end result is a one of a kind finished product.
Here's the comparison, I wish the stainless trim wasn't on the original door panel in this picture but you get the idea of the change. I haven't glued the vinyl material down yet, once glued, the wrinkles will be gone.
My first concern was how well the stainless would bend, then how would it polish after being heated red hot. It was very cooperating on both accounts.
I kept heating and bending til I got the shape of the original bead edge.
Shaping the rod is the easy part, next is..... how am I going to attach it to the door without having the attachment shown?
A Willys!!! 32oz Jeep Builds 2 09-20-2012 08:09 AM
The 1950 M38 sidescrollin Jeep Builds 17 06-20-2012 10:25 PM
Pic of my 46 willys CJ2a Jeep Builds 3 01-21-2012 06:07 PM
BIG willys kwkouki Jeep Picture Requests 12 01-16-2011 03:55 PM
1951 willys truck wehunt38 Jeep Builds 6 09-27-2010 08:54 PM
